Jerry Avins wrote:> > Rob Judd wrote: > > > ... > > > Open-air triode?? Do tell, you have me fascinated... > > > > Rob > > I wrote of it before, so I'll be brief and hope I'm not boring. An > open-coil hot plate with a ceramic holder to support and contain the > nichrome element as filament*. Topped with galvanized window screening, > the zinc removed with muriatic acid so as not to noxiously sublime, > resting on the ceramic as (literally!) grid. Small glass beads -- around > 1/16" -- scattered on it to create a gap and hold the screening flat. > Atop that, a pie tin weighted with cooling water to serve as > (literally!) plate. With 700 volts on the plate, I got measurable > current on my 1000 ohm/volt meter. At -90 volts on the grid, the current > was too small to read. The gain was enough to sustain oscillation.Tr�s bizarre! Rob
Automatic RF noise cancellation and audio noise measurement
Started by ●August 5, 2003
Reply by ●August 10, 20032003-08-10
Jerry Avins <jya@ieee.org> writes:> > P.S. to Rick: That was before my time. >Hey, Rick! Stop pickin' on the ol' guy!! ;-) Ciao, Peter K. -- Peter J. Kootsookos "Na, na na na na na na, na na na na" - 'Hey Jude', Lennon/McCartney
> > That bulb was probably an old coiled 'Edison' type . They were /areknown to> > form a tuned circuit resonating in the old TV band 1 ( about 48 - 62MHz)> > acting as a TX when power is applied. > > > > Frank GM0CSZ / KN6WH > > Thank you thankyouthankyou! I've been called a crazy liar more than once > over that bulb. There was no channel 1 when that incident happened, but > I suppose that a small change of geometry could raise the frequency. The > explanation in QST had it that the frequency was swept over a fairly > large range as the voltage varied during a cycle.I found such a bulb in the loft of the garage of a house we were renting in the mid-1950s. I had read an article about them somewhere, so I took it inside, screwed it into a lamp near the TV, and, voila, instant Channel 3 TVI (that was the main channel in Milwaukee, WI, then). I put it in a box in my shack, and didn't think about it for some time. I put up a tower and 20 meter beam. Before the coax was in the house, a neighbor sent his kid over to complain about TVI. I invited him to come over and see that the TV in my shack was not showing any interference, but he declined, and continued to complain over the next few months. While preparing to leave for two weeks vacation, I had a flash of inspiration. I put the bulb in a lamp, connected a timer to the lamp, and put it in a closet (so the light couldn't be seen in an otherwise dark house). The timer turned the bulb on during evening TV hours. I left it on for several days after our return. The neighbor never complained of TVI again. 73, John - K6QQ, glad for the statute of limitations.
Reply by ●August 11, 20032003-08-11
Jerry Avins wrote:> An > open-coil hot plate with a ceramic holder to support and contain the > nichrome element as filament*. Topped with galvanized window screening, > the zinc removed with muriatic acid so as not to noxiously sublime, > resting on the ceramic as (literally!) grid. Small glass beads -- around > 1/16" -- scattered on it to create a gap and hold the screening flat. > Atop that, a pie tin weighted with cooling water to serve as > (literally!) plate. With 700 volts on the plate, I got measurable > current on my 1000 ohm/volt meter. At -90 volts on the grid, the current > was too small to read. The gain was enough to sustain oscillation.Now **that's** Homebrew!
