I am trying to understand Bispectrum by doing some simple examples. I have looked at most of the literature but few of them give any simple examples. Suppose I have an FIR filter (NMPhase). Then it's z-transfer function spectrum I can find easily suppose a(z^-1)=1+a1z^-1 and it is driven with zero-mean non-Guassian white noise unit variance. P(z^-1)=a(z^-1)a(z) It's Bispectrum - is it P(z1^-1,z2^-1)=a(z1^-1)a(z2^-1).a(z1+z2) so if a(z^-1)=1+2z^-1 its Bispectrum is (1+2z1^-1)(1+2z2^-1)(1+2(z1+z2)) which one multiplies out. Also, to find the Bispectrum from data I read that you can get it from the Cumulant (no 3). I assume you then need the 2D FFT to get the BiSpectrum? But I saw this B(w1,w2)=a(w1)a(w2)a*(w1+w2) P(w1,w2) =!X(n1)!!X(n2)! X!(n1+n2)!* (sorry I don't have the pipe symbol on this keyboard). So do you use a 1D FFT and a 2D FFT?
Bispectrum
Started by ●February 22, 2014
Reply by ●February 22, 20142014-02-22
On Sunday, February 23, 2014 11:36:29 AM UTC+13, gyans...@gmail.com wrote:> I am trying to understand Bispectrum by doing some simple examples. I have looked at most of the literature but few of them give any simple examples. > > > > Suppose I have an FIR filter (NMPhase). Then it's z-transfer function spectrum I can find easily suppose a(z^-1)=1+a1z^-1 and it is driven with zero-mean non-Guassian white noise unit variance. > > > > > > P(z^-1)=a(z^-1)a(z) > > > > It's Bispectrum - is it > > > > P(z1^-1,z2^-1)=a(z1^-1)a(z2^-1).a(z1+z2) > > > > so if a(z^-1)=1+2z^-1 its Bispectrum is > > > > > > (1+2z1^-1)(1+2z2^-1)(1+2(z1+z2)) > > > > which one multiplies out. > > > > Also, to find the Bispectrum from data I read that you can get it from the Cumulant (no 3). I assume you then need the 2D FFT to get the BiSpectrum? > > > > But I saw this > > > > B(w1,w2)=a(w1)a(w2)a*(w1+w2) > > > > P(w1,w2) =!X(n1)!!X(n2)! X!(n1+n2)!* > > > > (sorry I don't have the pipe symbol on this keyboard). > > > > So do you use a 1D FFT and a 2D FFT?actually that FFT calculation should read P(w1,w2) =!X(n1)!!X(n2)! X!(n1,n2)!*
Reply by ●February 23, 20142014-02-23
On Saturday, February 22, 2014 5:36:29 PM UTC-5, gyans...@gmail.com wrote:> I am trying to understand Bispectrum by doing some simple examples. I have looked at most of the literature but few of them give any simple examples. > > > > Suppose I have an FIR filter (NMPhase). Then it's z-transfer function spectrum I can find easily suppose a(z^-1)=1+a1z^-1 and it is driven with zero-mean non-Guassian white noise unit variance. > > > > > > P(z^-1)=a(z^-1)a(z) > > > > It's Bispectrum - is it > > > > P(z1^-1,z2^-1)=a(z1^-1)a(z2^-1).a(z1+z2) > > > > so if a(z^-1)=1+2z^-1 its Bispectrum is > > > > > > (1+2z1^-1)(1+2z2^-1)(1+2(z1+z2)) > > > > which one multiplies out. > > > > Also, to find the Bispectrum from data I read that you can get it from the Cumulant (no 3). I assume you then need the 2D FFT to get the BiSpectrum? > > > > But I saw this > > > > B(w1,w2)=a(w1)a(w2)a*(w1+w2) > > > > P(w1,w2) =!X(n1)!!X(n2)! X!(n1+n2)!* > > > > (sorry I don't have the pipe symbol on this keyboard). > > > > So do you use a 1D FFT and a 2D FFT?My exposure and use of bispectral analysis comes from non-redundant masking of telescopes in astronomy. If my telescopes are in a straight line, I use 1-D fourier analysis to get my closure phases. What you are doing is essentially the same, so I'd say you use a 1-D FFT. Clay
