On 5/27/14 1:20 PM, Tim Wescott wrote:> On Mon, 26 May 2014 23:03:53 -0700, gyansorova wrote: >>> I seem to remember them saying that if you sample too fast the >> poles can drift outside the unit circle. That sound like rubbish to me >> unless the original system is open-loop unstable in the first place. > > Even today, you still have to be mindful of the cost of high-rate > sampling, and some sensors (or drivers, if you're using PWM) choose the > sampling interval for you. So choosing a sampling interval, while not as > critical a tradeoff between cost (or straight feasibility) and > performance as it used to be, is still a task that must be undertaken. > > As RBJ mentioned, the higher your sampling rate, the closer all the poles > get to 1,i think gyansorova mentioned that...> ... and the more precision you need to distinguish them from 1. > That means that as your sampling rate goes up so does your required word > width. You can play tricks to alleviate the problem, but in the end you > still often need to go to wider data paths.maybe. if you replace all the cos(w0) with 1 - 2*(sin(w0/2))^2 and you're in single-precision floating point, and if you're careful to do the arithmetic with the smaller numbers first (and later start adding in the bigger numbers), you may very well not need to go to wider words. this cos(w0) issue shows up in audio when we make a decent DC-blocking filter or other filters tuned to around 20 Hz or lower and it shows up when you are trying to plot frequency response from the coefficients and the frequencies are very low. just remember that all of the frequency information lies in the *difference* cos(w0) is from 1. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
First Order Hold
Started by ●May 27, 2014
Reply by ●May 27, 20142014-05-27
On 5/27/14 1:29 PM, Rob Gaddi wrote:> > It's not that the poles of the transformed plant model sneak outside > the unit circle, it's that the poles of the controller do because your > numerical precision is insufficient to keep them in.but you should have enough numerical precision to express the inside distance your pole is *from* the unit circle, even with low precision words. of course, if the precision gets *way* too low (like 16-bits) you have all sorts of problems, but you should *still* be able to represent poles dancing close to the unit circle. and you do that by re-arranging your difference equation, which is a lot like changing the "form" or topology of the filter or controller from a DF1 or DF2 to something else. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Tue, 27 May 2014 14:01:18 -0400 robert bristow-johnson <rbj@audioimagination.com> wrote:> On 5/27/14 1:29 PM, Rob Gaddi wrote: > > > > It's not that the poles of the transformed plant model sneak outside > > the unit circle, it's that the poles of the controller do because your > > numerical precision is insufficient to keep them in. > > but you should have enough numerical precision to express the inside > distance your pole is *from* the unit circle, even with low precision > words. of course, if the precision gets *way* too low (like 16-bits) > you have all sorts of problems, but you should *still* be able to > represent poles dancing close to the unit circle. and you do that by > re-arranging your difference equation, which is a lot like changing the > "form" or topology of the filter or controller from a DF1 or DF2 to > something else. > > -- > > r b-j rbj@audioimagination.com > > "Imagination is more important than knowledge." > >Can and did are very different things. Doubly so in educational environments. -- Rob Gaddi, Highland Technology -- www.highlandtechnology.com Email address domain is currently out of order. See above to fix.
> > > > > Reminds me of complaints about early CD playes which used one DAC, > > > multiplexed between two channels. The result is a half sample delay > > > between the two. >>> > > > Unless you are very careful where you put your head, you won't notice > > > a half sample delay. > > >probably not a problem when listening with speakers.. but it might matter with headphones and it will certainly matter if the the two channels are combined back to mono because it will create comb filtering Mark
On Tue, 27 May 2014 13:55:09 -0400, robert bristow-johnson wrote:> On 5/27/14 1:20 PM, Tim Wescott wrote: >> On Mon, 26 May 2014 23:03:53 -0700, gyansorova wrote: >> >> >>> I seem to remember them saying that if you sample too fast the poles >>> can drift outside the unit circle. That sound like rubbish to me >>> unless the original system is open-loop unstable in the first place. >> >> Even today, you still have to be mindful of the cost of high-rate >> sampling, and some sensors (or drivers, if you're using PWM) choose the >> sampling interval for you. So choosing a sampling interval, while not >> as critical a tradeoff between cost (or straight feasibility) and >> performance as it used to be, is still a task that must be undertaken. >> >> As RBJ mentioned, the higher your sampling rate, the closer all the >> poles get to 1, > > i think gyansorova mentioned that... > >> ... and the more precision you need to distinguish them from 1. >> That means that as your sampling rate goes up so does your required >> word width. You can play tricks to alleviate the problem, but in the >> end you still often need to go to wider data paths. > > maybe. if you replace all the cos(w0) with 1 - 2*(sin(w0/2))^2 and > you're in single-precision floating point, and if you're careful to do > the arithmetic with the smaller numbers first (and later start adding in > the bigger numbers), you may very well not need to go to wider words. > > this cos(w0) issue shows up in audio when we make a decent DC-blocking > filter or other filters tuned to around 20 Hz or lower and it shows up > when you are trying to plot frequency response from the coefficients and > the frequencies are very low. just remember that all of the frequency > information lies in the *difference* cos(w0) is from 1.You can play tricks like that and stretch the usability of single- precision math to some extent. But ultimately, even if you solve the problem of distinguishing your coefficients from 1, you still need to have wide enough words in your data so that the distinction is not lost. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On Wednesday, May 28, 2014 6:54:43 AM UTC+12, Tim Wescott wrote:> On Tue, 27 May 2014 13:55:09 -0400, robert bristow-johnson wrote: > > > > > On 5/27/14 1:20 PM, Tim Wescott wrote: > > >> On Mon, 26 May 2014 23:03:53 -0700, gyansorova wrote: > > >> > > >> > > >>> I seem to remember them saying that if you sample too fast the poles > > >>> can drift outside the unit circle. That sound like rubbish to me > > >>> unless the original system is open-loop unstable in the first place. > > >> > > >> Even today, you still have to be mindful of the cost of high-rate > > >> sampling, and some sensors (or drivers, if you're using PWM) choose the > > >> sampling interval for you. So choosing a sampling interval, while not > > >> as critical a tradeoff between cost (or straight feasibility) and > > >> performance as it used to be, is still a task that must be undertaken. > > >> > > >> As RBJ mentioned, the higher your sampling rate, the closer all the > > >> poles get to 1, > > > > > > i think gyansorova mentioned that... > > > > > >> ... and the more precision you need to distinguish them from 1. > > >> That means that as your sampling rate goes up so does your required > > >> word width. You can play tricks to alleviate the problem, but in the > > >> end you still often need to go to wider data paths. > > > > > > maybe. if you replace all the cos(w0) with 1 - 2*(sin(w0/2))^2 and > > > you're in single-precision floating point, and if you're careful to do > > > the arithmetic with the smaller numbers first (and later start adding in > > > the bigger numbers), you may very well not need to go to wider words. > > > > > > this cos(w0) issue shows up in audio when we make a decent DC-blocking > > > filter or other filters tuned to around 20 Hz or lower and it shows up > > > when you are trying to plot frequency response from the coefficients and > > > the frequencies are very low. just remember that all of the frequency > > > information lies in the *difference* cos(w0) is from 1. > > > > You can play tricks like that and stretch the usability of single- > > precision math to some extent. But ultimately, even if you solve the > > problem of distinguishing your coefficients from 1, you still need to > > have wide enough words in your data so that the distinction is not lost. > > > > -- > > > > Tim Wescott > > Wescott Design Services > > http://www.wescottdesign.comHere is some info from the net 10.6 CHOICE OF SAMPLING INTERVAL Whenever a digital control system is designed, a suitable sampling interval must be chosen. Choosing a large sampling time has destabilizing effects on the system. In addition, information loss occurs when large sampling times are selected. Also, the errors that occur when a continuous system is discretized increase as the sampling interval increases.
On Tue, 27 May 2014 12:13:33 -0700, gyansorova wrote:> On Wednesday, May 28, 2014 6:54:43 AM UTC+12, Tim Wescott wrote: >> On Tue, 27 May 2014 13:55:09 -0400, robert bristow-johnson wrote: >> >> >> >> > On 5/27/14 1:20 PM, Tim Wescott wrote: >> >> >> On Mon, 26 May 2014 23:03:53 -0700, gyansorova wrote: >> >> >> >> >> >> >> >> >>> I seem to remember them saying that if you sample too fast the >> >>> poles >> >> >>> can drift outside the unit circle. That sound like rubbish to me >> >> >>> unless the original system is open-loop unstable in the first >> >>> place. >> >> >> >> >> >> Even today, you still have to be mindful of the cost of high-rate >> >> >> sampling, and some sensors (or drivers, if you're using PWM) choose >> >> the >> >> >> sampling interval for you. So choosing a sampling interval, while >> >> not >> >> >> as critical a tradeoff between cost (or straight feasibility) and >> >> >> performance as it used to be, is still a task that must be >> >> undertaken. >> >> >> >> >> >> As RBJ mentioned, the higher your sampling rate, the closer all the >> >> >> poles get to 1, >> >> >> > >> > i think gyansorova mentioned that... >> >> >> > >> >> ... and the more precision you need to distinguish them from 1. >> >> >> That means that as your sampling rate goes up so does your required >> >> >> word width. You can play tricks to alleviate the problem, but in >> >> the >> >> >> end you still often need to go to wider data paths. >> >> >> > >> > maybe. if you replace all the cos(w0) with 1 - 2*(sin(w0/2))^2 and >> >> > you're in single-precision floating point, and if you're careful to >> > do >> >> > the arithmetic with the smaller numbers first (and later start adding >> > in >> >> > the bigger numbers), you may very well not need to go to wider words. >> >> >> > >> > this cos(w0) issue shows up in audio when we make a decent >> > DC-blocking >> >> > filter or other filters tuned to around 20 Hz or lower and it shows >> > up >> >> > when you are trying to plot frequency response from the coefficients >> > and >> >> > the frequencies are very low. just remember that all of the >> > frequency >> >> > information lies in the *difference* cos(w0) is from 1. >> >> >> >> You can play tricks like that and stretch the usability of single- >> >> precision math to some extent. But ultimately, even if you solve the >> >> problem of distinguishing your coefficients from 1, you still need to >> >> have wide enough words in your data so that the distinction is not >> lost. >> >> >> >> -- >> >> >> >> Tim Wescott >> >> Wescott Design Services >> >> http://www.wescottdesign.com > > Here is some info from the net > > 10.6 CHOICE OF SAMPLING INTERVAL > > Whenever a digital control system is designed, a suitable sampling > interval must be chosen. Choosing a large sampling time has > destabilizing effects on the system. In addition, information loss > occurs when large sampling times are selected. Also, the errors that > occur when a continuous system is discretized increase as the sampling > interval increases.Ah. Read carefully. They're talking about increasing the sampling _interval_, meaning the time between samples. So they're talking about _decreasing_ the sampling rate. I wouldn't say that choosing a too-large sampling time has destabilizing effects -- a more accurate way to put it would be that it makes it more difficult (or impossible) for a controller to achieve all of its goals, including stability. Aside from that quibble, what is said there is accurate: you sample more slowly, it's harder to stabilize, you're throwing away information you may need, and it's harder to get an accurate plant model at your (slow) sampling rate. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On 5/27/14 2:54 PM, Tim Wescott wrote:> On Tue, 27 May 2014 13:55:09 -0400, robert bristow-johnson wrote: > >> On 5/27/14 1:20 PM, Tim Wescott wrote: >>> On Mon, 26 May 2014 23:03:53 -0700, gyansorova wrote: >>> >>> >>>> I seem to remember them saying that if you sample too fast the poles >>>> can drift outside the unit circle. That sound like rubbish to me >>>> unless the original system is open-loop unstable in the first place. >>> >>> Even today, you still have to be mindful of the cost of high-rate >>> sampling, and some sensors (or drivers, if you're using PWM) choose the >>> sampling interval for you. So choosing a sampling interval, while not >>> as critical a tradeoff between cost (or straight feasibility) and >>> performance as it used to be, is still a task that must be undertaken. >>> >>> As RBJ mentioned, the higher your sampling rate, the closer all the >>> poles get to 1, >> >> i think gyansorova mentioned that... >> >>> ... and the more precision you need to distinguish them from 1. >>> That means that as your sampling rate goes up so does your required >>> word width. You can play tricks to alleviate the problem, but in the >>> end you still often need to go to wider data paths. >> >> maybe. if you replace all the cos(w0) with 1 - 2*(sin(w0/2))^2 and >> you're in single-precision floating point, and if you're careful to do >> the arithmetic with the smaller numbers first (and later start adding in >> the bigger numbers), you may very well not need to go to wider words. >> >> this cos(w0) issue shows up in audio when we make a decent DC-blocking >> filter or other filters tuned to around 20 Hz or lower and it shows up >> when you are trying to plot frequency response from the coefficients and >> the frequencies are very low. just remember that all of the frequency >> information lies in the *difference* cos(w0) is from 1. > > You can play tricks like that and stretch the usability of single- > precision math to some extent. But ultimately, even if you solve the > problem of distinguishing your coefficients from 1, you still need to > have wide enough words in your data so that the distinction is not lost.yes, i said "maybe". but to caveat your caveat, if the "trick" avoids the problem of subtracting two numbers that are nearly equal, i.e. forms an addition series that looks like c0 + c1*x + c2*x^2 + ... and that tiny difference between the two numbers you would otherwise be subtracting is x, then the "trick" rearranged your numerical problem into something that works with floating-point. and, since |x| is much smaller than 1, you start adding with the higher powers first. you can do that without making *all* of the words wider, unless it turns out that c1 and c2 are closely negatives of each other. then you do the factoring thing (i think it's called "Horner's rule"): c0 + x*(c1 + x*(c2 + ... ) ) all's i am saying with this "trick" is to identify what gets tiny when frequency is much much less than Nyquist. eventually, tiny numbers get added to bigger numbers. but if you can identify where all the tiny arithmetic is happening, then do that first and *then* add it to the bigger numbers. follow these principles and it might be surprizing how much you can get away with single-precision floats. a similar numerical "trick" (i just think it's numerical prudence) for FIR filters done in floating-point is to do the outer taps first since they will have the smallest coefficients. if it's linear-phase, the last tap you do is the center tap and if it's minimum-phase, the last tap you add in is the zeroth tap. Duane Wise did a paper a couple decades ago where he did a similar thing for fixed-point FIRs, but there was right-shifting of the sum of products after each group of taps. it helped him nail the frequency response with 16-bit "fixed"-point coefs in a way that you could not with a simple fixed-point FIR. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
