Hi, I have a DTFT function Y(w) which is also a function of a: Y(w,a) (it's actually a sum with a as coefficient) Another function Yl(w) is the l-fold convolution of Y: Yl(omega) = Y(w) * ... * Y(w) \ / l-times Now I want to take the derivative wrt. c, so I do: dYl(w)/dc = dYl(w)/dY(w) * dY(w)/dc Y and Yl are continuous functions, so the derivative operator is well defined (given it exists, of course!) However, now I have an N-periodic signal and therefore want to use the DFT. The equation then becomes (w=pi2k/N): dYr[k]/dc = dYr[k]/dY[k] * dY[k]/dc While "dY[k]/dc" is trivial, I don't know how to deal with "dYr[k]/dY[k]" - obviously this does not really make sense. But there must be a way to generalize this also for the DFT! Thanks Peter
derivative (chain rule) in DFT?
Started by ●July 9, 2014
Reply by ●July 9, 20142014-07-09
Hi, I am still in big hope that someone has an idea about this. Additional comments: First: In my post below I used both "a" and "c" for the coefficient. That's a mistake, there is just one coefficient (i.e., "a" and "c" are the same). Second: Meanwhile I tried two approaches. 1.) dYr[k]/dY[k] = dYr[k]/dk * (dY[k]/dk)^-1 = DFT{-j*n*yr[n])}/DFT{-j*n*y[n]} = DFT{n*yr[n])}/DFT{n*y[n]} What's problematic here is that I just apply the differentiation as if "k" would be a continous variable, i.e. I do as if I would use the DTFT. [1] suggests this should work. On the other hand, if I pretend that y[n] and yr[n] are infinite but periodic signals and I write it using the DTFT and do the math I get Sum_{-infty}^infty -j n y[n] e^(-jwn) which is not periodic any more, so I can't go back to DFT. 2.) Based on the first line I do the approximation dY[k]/dk \approx (Y[k+1] - Y[k])/(k+1-k) = Y[k+1] - Y[k] Then the result is (differently from above): dYr[k]/dY[k] \approx (Yr[k+1] - Yr[k])/(Y[k+1] - Y[k]) Unfortunately both approaches do not get me to the expected result and from these two (2) even less. Thanks, Peter [1] http://www.tricki.org/article/Use_Fourier_transforms_to_calculate_derivatives On 2014-07-08 23:35, Peter Mairhofer wrote:> I have a DTFT function Y(w) which is also a function of a: Y(w,a) (it's > actually a sum with a as coefficient) > > Another function Yl(w) is the l-fold convolution of Y: > > Yl(omega) = Y(w) * ... * Y(w) > \ / > l-times > > Now I want to take the derivative wrt. c, so I do: > > dYl(w)/dc = dYl(w)/dY(w) * dY(w)/dc > > Y and Yl are continuous functions, so the derivative operator is well > defined (given it exists, of course!) > > However, now I have an N-periodic signal and therefore want to use the DFT. > > The equation then becomes (w=pi2k/N): > > dYr[k]/dc = dYr[k]/dY[k] * dY[k]/dc > > While "dY[k]/dc" is trivial, I don't know how to deal with > "dYr[k]/dY[k]" - obviously this does not really make sense. > > But there must be a way to generalize this also for the DFT! > > Thanks > Peter >
On Tue, 08 Jul 2014 23:35:03 -0700, Peter Mairhofer wrote:> Hi, > > I have a DTFT function Y(w) which is also a function of a: Y(w,a) (it's > actually a sum with a as coefficient) > > Another function Yl(w) is the l-fold convolution of Y: > > Yl(omega) = Y(w) * ... * Y(w) > \ / > l-times > > Now I want to take the derivative wrt. c, so I do: > > dYl(w)/dc = dYl(w)/dY(w) * dY(w)/dc > > Y and Yl are continuous functions, so the derivative operator is well > defined (given it exists, of course!)Actually, I don't think that what you're trying to do is "fair". Yl(c, w) is not a function of Y(c, w) at w -- it is a function of Y(c, w) over all w. I think you'd be much better served by writing out the convolution integral for Yl, then investigating the effects of taking the derivative w.r.t c. It may be a "you can't get there from here" thing.> However, now I have an N-periodic signal and therefore want to use the > DFT. > > The equation then becomes (w=pi2k/N): > > dYr[k]/dc = dYr[k]/dY[k] * dY[k]/dc > > While "dY[k]/dc" is trivial, I don't know how to deal with > "dYr[k]/dY[k]" - obviously this does not really make sense. > > But there must be a way to generalize this also for the DFT!Again, your Yr(c, k) isn't a function of just Y(c, k) at k -- it's for all k. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●July 15, 20142014-07-15
On 2014-07-09 16:34, Tim Wescott wrote:> On Tue, 08 Jul 2014 23:35:03 -0700, Peter Mairhofer wrote: > [...] > Again, your Yr(c, k) isn't a function of just Y(c, k) at k -- it's for > all k.Hi Tim, Really great, thank you! You fixed it. I worked it out using the convolution integral and everything makes sense. Regards, Peter
