Hello, I am brushing up on the filter design method using Z-transform, pole/zero method. I believe the complexity of the filter is directly proportional to the number of poles and zeros I use to design a filter. Similarly, the better (precise) the frequency response, higher is the complexity of the filter. Can the experts weigh in here please. Also, more from a theoretical and conceptual perspective, I look at a filter more as a system that removes something we don't want. Given this understanding, when designing a filter, is it not enough if I just play around with zeros to make sure everything that is not needed is appropriately supressed?. Why is there a need to use poles? Thank you _____________________________ Posted through www.DSPRelated.com
Filter design complexity
Started by ●August 2, 2014
Reply by ●August 2, 20142014-08-02
On Saturday, August 2, 2014 6:48:58 PM UTC+12, SBR123 wrote:> Hello, > > > > I am brushing up on the filter design method using Z-transform, pole/zero > > method. I believe the complexity of the filter is directly proportional to > > the number of poles and zeros I use to design a filter. Similarly, the > > better (precise) the frequency response, higher is the complexity of the > > filter. > > > > Can the experts weigh in here please. > > > > Also, more from a theoretical and conceptual perspective, I look at a > > filter more as a system that removes something we don't want. Given this > > understanding, when designing a filter, is it not enough if I just play > > around with zeros to make sure everything that is not needed is > > appropriately supressed?. Why is there a need to use poles?If you require a lower-order filter then poles are the way. You need more zeros to approximate the effect of poles (for digital filters that is - for analogue we usually have poles and/or zeros) You can also get linear phase with FIR filters and this is far harder with poles.
On Saturday, August 2, 2014 2:48:58 AM UTC-4, SBR123 wrote:> Hello, > > > > I am brushing up on the filter design method using Z-transform, pole/zero > > method. I believe the complexity of the filter is directly proportional to > > the number of poles and zeros I use to design a filter. Similarly, the > > better (precise) the frequency response, higher is the complexity of the > > filter. > > > > Can the experts weigh in here please. > > > > Also, more from a theoretical and conceptual perspective, I look at a > > filter more as a system that removes something we don't want. Given this > > understanding, when designing a filter, is it not enough if I just play > > around with zeros to make sure everything that is not needed is > > appropriately supressed?. Why is there a need to use poles? > > > > Thank you > > > > _____________________________ > > Posted through www.DSPRelated.comSBR123, "Why is there a need to use poles?" Look in your text about why someone would use IIR filters rather than FIR filters. Dirk
On Sat, 02 Aug 2014 01:48:58 -0500, "SBR123" <100967@dsprelated> wrote:>Hello,Hello mysterious Mr. SBR123,>I am brushing up on the filter design method using Z-transform, pole/zero >method. I believe the complexity of the filter is directly proportional to >the number of poles and zeros I use to design a filter.That's a broad statement. Take care in making broad (what you think is always true) statements about digital filters. As soon as you make a statement that you think is always true, someone will give you an example where your statement is NOT true.(This has happened to me more than once.) For example, I can think of a linear-phase tapped-delay line FIR that has 100 zeros on the z-plane. That seems like a high-compexity filter, but it's not complicated at all. The block diagram of the (100-zeros) FIR filter I have in mind contains only one adder and *NO* multipliers.> Similarly, the >better (precise) the frequency response, higher is the complexity of the >filter. > >Can the experts weigh in here please.Well, you have not defined what you mean by the word "complexity." Does that word mean "the order of the numerator and denominator polynomials in a filter's z-domain transfer function"? Or perhaps your word "complexity" means the number of arithmetic operations needed to compute a single filter output sample. The FIR filter I mentioned above has a high-order polynomial in its z-domain transfer function, but it requires only one addition operation to compute a filter output sample. (Not to be too mysterious here, ...that filter is called a "comb filter.")>Also, more from a theoretical and conceptual perspective, I look at a >filter more as a system that removes something we don't want. Given this >understanding, when designing a filter, is it not enough if I just play >around with zeros to make sure everything that is not needed is >appropriately supressed?. Why is there a need to use poles?Well, to have high performance (flat passband response. narrow transition regions, high attenuation in the stopband) a filter is needed that has a long time-domain impulse response (many nonzero-valued samples). So how do we build digital filters having long impulse responses? Two ways. Either (1) a tapped-delay line FIR filter having many delay elements, or (2) an IIR filter with poles that are located close to the inside of the unit circle on the z-plane. The IIR filter will require fewer arithmetic operations per output sample than the FIR filter. However, the FIR filter can have linear phase which the IIR filter can never have. Pick your poison SBR123. Good Luck, [-Rick-]
