I am working with 3GPP AMR WB codec and I am able to successfully compile the encoder and decoder and also run it as mentioned in the document using their voice samples (tst.inp and dtx.inp). I want to implement the codec to encode and decode any general sound (.wav file). How can I do that ? I have tried to convert the .wav filr to .inp which is not happening and then I also tried to use wave file as input to encoder but am not able to implement it. Can I get some help in this regard. _____________________________ Posted through www.DSPRelated.com
Use of AMR-Wide Band Codec
Started by ●August 7, 2014
