Implementing a Time to Digital Converter in Discrete Time
Started by AWadood7 ●August 31, 2014
So I want to use a Time to Digital Converter(TDC) which is used in Time of
Flight Measurements. It normally uses delayed clock samples to achieve a
resolution down to pico second range. I'm not really clear about the
process.
So is it possible to implement a TDC in discrete time domain? I was
thinking of interpolation and low-passing to increase sampling rate.
Simply stated, the problem is this: If an event, (e.g,a leading-edge)
occurs between two leading edges of clock, then is it possible using DSP
techniques to specify the time of the event with a resolution greater than
the clock period?
I've tried to convey the problem but if's still not clear please ask.
Thank you for your guidance.
_____________________________
On Sun, 31 Aug 2014 12:17:08 -0500, AWadood7 wrote:
> So I want to use a Time to Digital Converter(TDC) which is used in Time > of Flight Measurements. It normally uses delayed clock samples to > achieve a resolution down to pico second range. I'm not really clear > about the process. > So is it possible to implement a TDC in discrete time domain? I was > thinking of interpolation and low-passing to increase sampling rate. > Simply stated, the problem is this: If an event, (e.g,a leading-edge) > occurs between two leading edges of clock, then is it possible using DSP > techniques to specify the time of the event with a resolution greater > than the clock period? > I've tried to convey the problem but if's still not clear please ask. > Thank you for your guidance.
Some sort of analog whiz-bang has to be there. It may be as simple as the lowpass filter that you alluded to, so that the "leading edge" is spread over several samples. It could be as complicated as an integrator that starts charging on the leading edge of the event, and is sampled by and ADC at a clock tick, and then stops. You can't just feed a square wave into a comparator, sample the comparator output, and get an answer to higher resolution than your sampling rate. You would probably need to take your event, clean it up to some well- defined amplitude with a really fast comparator, then low-pass the thing (a 1st-order lowpass should work as long as your repetition rate isn't too high, although it may not be best). Finally, take some samples with a nice stable high-precision ADC, and do some math to back out a time-of- arrival. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On 8/31/2014 2:33 PM, Tim Wescott wrote:
> On Sun, 31 Aug 2014 12:17:08 -0500, AWadood7 wrote: > >> So I want to use a Time to Digital Converter(TDC) which is used in Time >> of Flight Measurements. It normally uses delayed clock samples to >> achieve a resolution down to pico second range. I'm not really clear >> about the process. >> So is it possible to implement a TDC in discrete time domain? I was >> thinking of interpolation and low-passing to increase sampling rate. >> Simply stated, the problem is this: If an event, (e.g,a leading-edge) >> occurs between two leading edges of clock, then is it possible using DSP >> techniques to specify the time of the event with a resolution greater >> than the clock period? >> I've tried to convey the problem but if's still not clear please ask. >> Thank you for your guidance. > > Some sort of analog whiz-bang has to be there. It may be as simple as the > lowpass filter that you alluded to, so that the "leading edge" is spread > over several samples. It could be as complicated as an integrator that > starts charging on the leading edge of the event, and is sampled by and > ADC at a clock tick, and then stops. > > You can't just feed a square wave into a comparator, sample the comparator > output, and get an answer to higher resolution than your sampling rate. > > You would probably need to take your event, clean it up to some well- > defined amplitude with a really fast comparator, then low-pass the thing > (a 1st-order lowpass should work as long as your repetition rate isn't too > high, although it may not be best). Finally, take some samples with a > nice stable high-precision ADC, and do some math to back out a time-of- > arrival.
The OP has an idea of how to do this. He talks about delayed clock samples. This is possible in an FPGA using a DLL. I don't recall the details of how this works, but I know you can specify the delay down to some smallish number of picoseconds(50 ps maybe?). For a repetitive event this is duck soup. For a one shot event I'm not sure. I don't think you can generate more than one delay at a time. Another way is to step up your clock rate using the DLL. The leading edge can be clocked into a SERDES at some 16x the input clock rate (or more) and the word read out giving the location of the leading edge. Even so this will only give you resolution to 100 ps ballpark I expect. I don't know the exact upper limit of the typical SERDES in FPGAs. I do know they are in the GHz range and vary. If you can apply brute force like they do in flash converters, you can create a large number of delay lines and use one input per delay line. Then your precision is only limited by the consistency of the delay from the clock pin to the input FFs. I expect you can get down to the 10 ps ballpark without too much trouble, but don't really know. -- Rick
>lowpass filter that you alluded to, so that the "leading edge" is spread >over several samples. It could be as complicated as an integrator that >starts charging on the leading edge of the event, and is sampled by and >ADC at a clock tick, and then stops. > >You can't just feed a square wave into a comparator, sample the comparator
>output, and get an answer to higher resolution than your sampling rate. > >You would probably need to take your event, clean it up to some well- >defined amplitude with a really fast comparator, then low-pass the thing >(a 1st-order lowpass should work as long as your repetition rate isn't too
>high, although it may not be best). Finally, take some samples with a >nice stable high-precision ADC, and do some math to back out a time-of- >arrival. > >-- > >Tim Wescott >Wescott Design Services >http://www.wescottdesign.com
In the first para: 1)The leading edge itself is 2ns wide. How can I recover that with a low-pass filter? I don't understand the process in the last paragraph. Please elaborate. _____________________________ Posted through www.DSPRelated.com
>The OP has an idea of how to do this. He talks about delayed clock >samples. This is possible in an FPGA using a DLL. I don't recall the >details of how this works, but I know you can specify the delay down to >some smallish number of picoseconds(50 ps maybe?). For a repetitive >event this is duck soup. For a one shot event I'm not sure. I don't >think you can generate more than one delay at a time. > >Another way is to step up your clock rate using the DLL. The leading >edge can be clocked into a SERDES at some 16x the input clock rate (or >more) and the word read out giving the location of the leading edge. > >Even so this will only give you resolution to 100 ps ballpark I expect. > I don't know the exact upper limit of the typical SERDES in FPGAs. I >do know they are in the GHz range and vary. > >If you can apply brute force like they do in flash converters, you can >create a large number of delay lines and use one input per delay line. >Then your precision is only limited by the consistency of the delay from >the clock pin to the input FFs. I expect you can get down to the 10 ps >ballpark without too much trouble, but don't really know. > >-- > >Rick >
I know this could be implemented in FPGAs to 100ps(500ps would work fine for me.) I was asking about discrete-time domain, like a method involving offline processing of samles and then using math to increase the resolution. _____________________________ Posted through www.DSPRelated.com
On 8/31/2014 3:57 PM, AWadood7 wrote:
>> > I know this could be implemented in FPGAs to 100ps(500ps would work fine > for me.) I was asking about discrete-time domain, like a method involving > offline processing of samles and then using math to increase the > resolution.
I'm not clear on what you are thinking. What sort of "samples" could you process "offline"? If it is digital you need to have something to process. I think that is where the analog ideas come in. -- Rick
On 8/31/2014 3:47 PM, AWadood7 wrote:
>> Some sort of analog whiz-bang has to be there. It may be as simple as the > >> lowpass filter that you alluded to, so that the "leading edge" is spread >> over several samples. It could be as complicated as an integrator that >> starts charging on the leading edge of the event, and is sampled by and >> ADC at a clock tick, and then stops. >> >> You can't just feed a square wave into a comparator, sample the comparator > >> output, and get an answer to higher resolution than your sampling rate. >> >> You would probably need to take your event, clean it up to some well- >> defined amplitude with a really fast comparator, then low-pass the thing >> (a 1st-order lowpass should work as long as your repetition rate isn't too > >> high, although it may not be best). Finally, take some samples with a >> nice stable high-precision ADC, and do some math to back out a time-of- >> arrival. >> >> -- >> >> Tim Wescott >> Wescott Design Services >> http://www.wescottdesign.com > > In the first para: > 1)The leading edge itself is 2ns wide. How can I recover that with a > low-pass filter? > I don't understand the process in the last paragraph. Please elaborate.
I think he is saying to use a comparator to set a consistent trigger point and to give the waveform a sharp edge. Then use a filter to give it a well defined slope. Sample with an ADC and you get a measurement of the timing of the edge by measuring the voltage on that slope. Maybe you can do this with the existing pulse shape if it is consistent in shape and amplitude. 2 ns would be a reasonable rise time if you have a clock rate above 500 MHz. It won't take too much processing to get a time from the ADC output. You may want to correct for the exact shape of the pulse edge with a non-linear equation. -- Rick
On Sun, 31 Aug 2014 14:47:18 -0500, AWadood7 wrote:
>>Some sort of analog whiz-bang has to be there. It may be as simple as >>the > >>lowpass filter that you alluded to, so that the "leading edge" is spread >>over several samples. It could be as complicated as an integrator that >>starts charging on the leading edge of the event, and is sampled by and >>ADC at a clock tick, and then stops. >> >>You can't just feed a square wave into a comparator, sample the >>comparator > >>output, and get an answer to higher resolution than your sampling rate. >> >>You would probably need to take your event, clean it up to some well- >>defined amplitude with a really fast comparator, then low-pass the thing >>(a 1st-order lowpass should work as long as your repetition rate isn't >>too > >>high, although it may not be best). Finally, take some samples with a >>nice stable high-precision ADC, and do some math to back out a time-of- >>arrival. >> >>-- >> >>Tim Wescott Wescott Design Services http://www.wescottdesign.com > > In the first para: > 1)The leading edge itself is 2ns wide. How can I recover that with a > low-pass filter?
You don't recover the leading edge -- you purposely smear it out.
If you just sample a square edge you get a square edge, and you don't know when it happened. If you sample a square edge that's been low-pass filtered, then you get at least one -- possibly more -- samples between low and high. The amplitudes of these samples will vary with the arrival time of the edge in a known way. You measure the voltage of the samples, then use the known relationship between time and voltage to calculate time from voltage. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
AWadood7 <101492@dsprelated> wrote:
> So I want to use a Time to Digital Converter(TDC) which is used in > Time of Flight Measurements. It normally uses delayed clock > samples to achieve a resolution down to pico second range. > I'm not really clear about the process.
The ones I know charge a capacitor at constant current, then measure the voltage at the appropriate time using and ADC. I am not sure how they are calibrated. I could imagine a PLL system that keeps the charging current just right, but it might be that you just adjust the current as appropriate.
> So is it possible to implement a TDC in discrete time domain? > I was thinking of interpolation and low-passing to increase > sampling rate.
Not that I can think of, but maybe others can. You mean a digital low-pass filter, not an analog one?
> Simply stated, the problem is this: If an event, (e.g,a leading-edge) > occurs between two leading edges of clock, then is it possible using DSP > techniques to specify the time of the event with a resolution greater than > the clock period?
Some years ago, I was working on PET scanner design, which use TDCs to determine the time difference between the signal reaching two detectors to high resolution, though maybe not high accuracy. -- glen
On 31/08/14 18:17, AWadood7 wrote:
> So I want to use a Time to Digital Converter(TDC) which is used in Time of > Flight Measurements. It normally uses delayed clock samples to achieve a > resolution down to pico second range. I'm not really clear about the > process. > So is it possible to implement a TDC in discrete time domain? I was > thinking of interpolation and low-passing to increase sampling rate. > Simply stated, the problem is this: If an event, (e.g,a leading-edge) > occurs between two leading edges of clock, then is it possible using DSP > techniques to specify the time of the event with a resolution greater than > the clock period? > I've tried to convey the problem but if's still not clear please ask. > Thank you for your guidance.
http://www.ko4bb.com/~bruce/TDC.html
