On 9/24/2014 9:34 PM, robert bristow-johnson wrote:> > i have to confess, Bob, that i am not persuaded. i set up the question > a bit more with the start of an answer (in two modes, one using the > language of Hilbert Spaces and the other not). please take another look > at the page, if you want. > > L8r, >Hi, To borrow a quote from "Monday Starts on Saturday", "It's nonsense to look for a solution if it already exists. We are talking about how to deal with a problem that has no solution." The problem is that your problem in the general form as expressed in your initial post has no solution which is proved by a few counterexamples provided here. May be, it's prudent to provide some additional constraints. For example, simulations I've run indicate that your theorem seem to work IF the signals X, Y and Z are both even AND convex curves (within a period). It doesn't work if X,Y, and Z are only even but not convex. It doesn't work if X,Y, and Z are only convex but not even. Hope that helps. Evgeny.
so i have asked my very first question on the dsp stack exchange site...
Started by ●September 23, 2014
Reply by ●September 25, 20142014-09-25
Robert I've only spent a few minutes thinking about this so I'm likely not correct. I have one question though. The cross- correlation between any 2 of your 3 periodic signals could have a negative peak instead of a positive peak. In that case your formula for finding the location of the max Rxy would fail ( well your formula will give some answer but should you be looking for the location of the max abs(Rxy) instead ?) Bob
On 9/25/2014 2:31 PM, Evgeny Filatov wrote:> On 9/24/2014 9:34 PM, robert bristow-johnson wrote: >> >> i have to confess, Bob, that i am not persuaded. i set up the question >> a bit more with the start of an answer (in two modes, one using the >> language of Hilbert Spaces and the other not). please take another look >> at the page, if you want. >> >> L8r, >> > > Hi, > > To borrow a quote from "Monday Starts on Saturday", "It's nonsense to > look for a solution if it already exists. We are talking about how to > deal with a problem that has no solution." > > The problem is that your problem in the general form as expressed in > your initial post has no solution which is proved by a few > counterexamples provided here. > > May be, it's prudent to provide some additional constraints. For > example, simulations I've run indicate that your theorem seem to work IF > the signals X, Y and Z are both even AND convex curves (within a > period). It doesn't work if X,Y, and Z are only even but not convex. It > doesn't work if X,Y, and Z are only convex but not even. > > Hope that helps. > > Evgeny. >Oops. I've meant to say that a reasonable guess about the sufficient conditions for Robert's theorem is that the shapes of signals X, Y, and Z are both symmetrical and rise monotonously from their minimum to maximum values (within a period, that is). Even then you would have to deal with the ambiguity related to the fact that there might be more than one maximum in cross-correlation functions per period, so that's assuming there is only one. Evgeny.
