Hi all the experts, I would like to use Matlab to do short time fourier transform on a speech signal. May I know how can I use the windowing function and fft function to do the short time fourier transform? (I know there is a blockset to do that but I'm not allowed to use simlink to do the short time fourier transform. So please help! Thank alot. David
use matlab to do short time fourier transform
Started by ●July 16, 2003
Reply by ●July 16, 20032003-07-16
That would be called "Homework"? If you are looking for help with the easy questions you can rest assured that there is little you will ever learn. Try looking it up. You are quite welcome. Dirk Dirk A. Bell DSP Consultant "David" <april29@singnet.com> wrote in message news:bf2g7e$u84$1@mawar.singnet.com.sg...> Hi all the experts, > > I would like to use Matlab to do short time fourier transform on a speech > signal. May I know how can I use the windowing function and fft functionto> do the short time fourier transform? (I know there is a blockset to dothat> but I'm not allowed to use simlink to do the short time fourier transform. > So please help! > > Thank alot. > > David > >
"Dirk Bell" <dirkman@erols.com> wrote in message news:bf2joc$nju$1@bob.news.rcn.net...> > Try looking it up. >thanks dirk.... if ur using MATLAB, try using the help files. type help hanning for windows, and instructions on how to use the command will appear. try doing this for FFT too, a list will appear, and other commands taht might come in useful will be there (fftshift etc). most of these commands are easy to implement: fftsignal = fft (x) % performs the fft on a signal x, which usualy has a length of N samples. (MATLAB works with discrete vaules) and: windowed = hanning(fftsignal) % windows the fft-ed signal. quite easy to do, and MATLAB is a language that is easy to pick up. search around on google, and look for some source code from which to deconstruct, learn and understand, and then put it back the way you think the program will work for. try looking in the MATLAB newsgroup, that should provide you with more help, but i strongly reccomend looking in the help files that come with MATLAB, as this can solve a lot of your problems, and avoid being critised on here for not having looked in the first place! HTH phil
Phil, I just think coming here for a solution should not be the first thing someone does when given a problem, especially for homework. Most people are here to help, not do the work for others. It is also a shame that he apparently is using Simulink blocksets with no grasp as to what he is doing, and apparently has no interest in learning. If he can't start MATLAB and find 'Help' for obvious topics without help ... Dirk "Phil Newman" <phillenium2002@hotmail.com> wrote in message news:bf3r0l$5td$1@news8.svr.pol.co.uk...> > "Dirk Bell" <dirkman@erols.com> wrote in message > news:bf2joc$nju$1@bob.news.rcn.net... > > > > Try looking it up. > > > > thanks dirk.... > > if ur using MATLAB, try using the help files. type help hanning for > windows, and instructions on how to use the command will appear. trydoing> this for FFT too, a list will appear, and other commands taht might comein> useful will be there (fftshift etc). > > most of these commands are easy to implement: > > fftsignal = fft (x) % performs the fft on a signal x, which usualy has a > length of N samples. (MATLAB works with discrete vaules) > > and: > > windowed = hanning(fftsignal) % windows the fft-ed signal. > > quite easy to do, and MATLAB is a language that is easy to pick up. > > search around on google, and look for some source code from which to > deconstruct, learn and understand, and then put it back the way you think > the program will work for. > > try looking in the MATLAB newsgroup, that should provide you with morehelp,> but i strongly reccomend looking in the help files that come with MATLAB,as> this can solve a lot of your problems, and avoid being critised on herefor> not having looked in the first place! > > HTH > > phil > >
Reply by ●July 17, 20032003-07-17
"Dirk Bell" <dirkman@erols.com> wrote in message news:bf46mv$lrq$1@bob.news.rcn.net...> Phil, > > I just think coming here for a solution should not be the first thing > someone does when given a problem, especially for homework. Most peopleare> here to help, not do the work for others. It is also a shame that he > apparently is using Simulink blocksets with no grasp as to what he isdoing,> and apparently has no interest in learning. If he can't start MATLAB and > find 'Help' for obvious topics without help ... > > Dirk > >fair enough, but i've been on the receiving end of that before, and it's quite frustrating! I didnt give him the full solution, merely a guide, and where to find some information. any program language is dificult to learn straight off, but hopefully, he shall gain the basics from here and build on it. just wish he'd acknowledge my help :o( phil ps i dont know how to use simulink - doesn't mean i dont know something about DSP
