1/f noise generation
Started by Yu Xiaodong July 4, 2003
Yu Xiaodong wrote:
> Hi All, > > Is there anyone know how to generate 1/f noise for simulating the phase > noise. Someone told me though passing a white noise to a FIR the noise can > be generated. Any clue about the FIR? > > Thanks alot > > R. Y.
R.Y.: Here's some C++ code that I wrote that will create phase noise samples from a user-specified phase noise profile. The code uses the GNU Scientific Library (freely available). Good luck, OUP //-------------------------------------------------------------------------------------------------- // // phase_noise // // Generate random deviates whose spectrum matches a phase noise profile. This code uses the // GNU Scientific Library (GSL) v1.1.1. // // Revisions // --------- // 25-Jun-02 Initial version written. // //-------------------------------------------------------------------------------------------------- #include <stdio.h> #include <stdlib.h> #include <iostream.h> #include <math.h> #include <gsl/gsl_complex.h> #include <gsl/gsl_complex_math.h> #include <gsl/gsl_errno.h> #include <gsl/gsl_fft_complex.h> #include <gsl/gsl_fft_halfcomplex.h> #include <gsl/gsl_fft_real.h> #include <gsl/gsl_randist.h> #include <gsl/gsl_rng.h> #include <gsl/gsl_spline.h> #include <gsl/gsl_vector.h> #include "phase_noise.h" //-------------------------------------------------------------------------------------------------- // // main // //-------------------------------------------------------------------------------------------------- int main (int argc, char *argv[]) { int i, numSamples; double fs; double xi, yi; // number of samples numSamples = atoi(argv[1]); // sample frequency in Hz fs = atof(argv[2]); InitPhaseProfile(); double *phi = new double [numSamples]; GenPhaseNoiseDeviates(phi, numSamples, fs); for (i = 0; i < numSamples; i++) { fprintf(stdout,"%d %19.16e\n", i, phi[i]); } } //-------------------------------------------------------------------------------------------------- // // GenPhaseNoiseDeviates // // Inputs // ------ // numSamples number of samples to generate // fs sample frequency (a.k.a. PRF) // // Input/Output // ------------ // phiRandom array to hold random deviates // // Revisions // --------- // 25-Jun-02 Initial version written. // //-------------------------------------------------------------------------------------------------- int GenPhaseNoiseDeviates(double phiRandom[], int numSamples, double fs) { int i; extern int numPointsProfile; //------------------------------- // Generate white Gaussian noise //------------------------------- gsl_rng_env_setup(); const gsl_rng_type *T = gsl_rng_default; gsl_rng *r = gsl_rng_alloc(T); double *wn = new double [numSamples]; for (i = 0; i < numSamples; i++) { wn[i] = gsl_ran_gaussian(r, 1.0); // zero mean, unity sigma //cout << wn[i] << "\n"; } // Store the white noise samples in a GSL "packed" array. A "packed" array holds complex data // in a double arrray. The order is real, imag, real, imag, and so on. double *packedWn = new double [2*numSamples]; for (i = 0; i < numSamples; i++) { REAL_PACKED(packedWn,i) = wn[i]; IMAG_PACKED(packedWn,i) = 0.0; } //------------------------------------------------------ // forward Fourier transform of the white noise samples //------------------------------------------------------ gsl_fft_complex_workspace *workspace = gsl_fft_complex_workspace_alloc(numSamples); gsl_fft_complex_wavetable *wavetable = gsl_fft_complex_wavetable_alloc(numSamples); // we'll use this for the inverse too gsl_fft_complex_forward(packedWn, 1, numSamples, wavetable, workspace); //-------------------------------------------- // Construct the aliased phase noise response //-------------------------------------------- int nFold = int( fInputPhaseProfile[numPointsProfile-1] / fs ) + 1; if (nFold > nFoldMax) nFold = nFoldMax; int nHalf = numSamples/2; double *hMag = new double [nHalf]; double *f = new double [nHalf]; double *mSSB = new double [nHalf]; double fMin = 1.0; double fMax = fs / 2.0; double fStep = (fMax - fMin)/(nHalf-1); int k; double summation; for (i = 0; i < nHalf; i++) { summation = 0.0; f[i] = fMin + i*fStep; for (k = -nFold; k <= nFold; k++) { summation = summation + GetPhaseNoiseValue(f[i] + k*fs); } hMag[i] = summation; mSSB[i] = GetPhaseNoiseValue(f[i]); } // for (i = 0; i < nHalf; i++) // { // fprintf(stdout,"%f %19.16e %19.16e\n", f[i], mSSB[i], hMag[i]); // } // Construct a double-sided phase noise profile. This has even symmetry. Note that the // GSL stores the positive frequencies first, then the negative frequencies in reverse // order. We'll construct our DSB profile the same way. double *mDSB = new double [numSamples]; for (i = 0; i < nHalf; i++) { mDSB[i] = hMag[i]; mDSB[i+nHalf] = hMag[nHalf - 1 - i]; } double *packedDSB = new double [2*numSamples]; for (i = 0; i < numSamples; i++) { REAL_PACKED(packedDSB,i) = mDSB[i]; IMAG_PACKED(packedDSB,i) = 0.0; //cout << mDSB[i] << "\n"; } //---------------------------- // Convolve the two sequences //---------------------------- double *packedY = new double [2*numSamples]; gsl_complex h, x, z; // double hx, hy, wx, wy; for (i = 0; i < numSamples; i++) { // wx = REAL_PACKED(packedWn,i); // wy = IMAG_PACKED(packedWn,i); // hx = REAL_PACKED(packedDSB,i); // hy = IMAG_PACKED(packedDSB,i); // GSL_SET_COMPLEX(&x, wx, wy); // GSL_SET_COMPLEX(&h, hx, hy); GSL_SET_COMPLEX(&x, REAL_PACKED(packedWn,i), IMAG_PACKED(packedWn,i)); GSL_SET_COMPLEX(&h, REAL_PACKED(packedDSB,i), IMAG_PACKED(packedDSB,i)); z = gsl_complex_mul(h,x); REAL_PACKED(packedY,i) = GSL_REAL(z); IMAG_PACKED(packedY,i) = GSL_IMAG(z); // packedY[i] = packedDSB[i] * packedWn[i]; // this only works because imaginary part is zero! } //--------------------------- // Inverse Fourier transform //--------------------------- gsl_fft_complex_inverse(packedY, 1, numSamples, wavetable, workspace); for (i = 0; i < numSamples; i++) { phiRandom[i] = REAL_PACKED(packedY,i); } // free some stuff gsl_fft_complex_workspace_free(workspace); gsl_fft_complex_wavetable_free(wavetable); gsl_spline_free (spline); gsl_interp_accel_free(acc); return 0; } //-------------------------------------------------------------------------------------------------- // // InitPhaseProfile // // Initialize stuff for the phase profile interpolation. // // Revisions // --------- // 25-Jun-02 Initial version written. // //-------------------------------------------------------------------------------------------------- int InitPhaseProfile() { int i; extern int numPointsProfile; numPointsProfile = sizeof(fInputPhaseProfile)/sizeof(double); double *fLog = new double [numPointsProfile]; extern double fInputPhaseProfile[], mInputPhaseProfile[]; extern gsl_interp_accel *acc; extern gsl_spline *spline; for (i = 0; i < numPointsProfile; i++) { fLog[i] = log10(fInputPhaseProfile[i]); } // printf ("#m=0,S=2\n"); // for (i = 0; i < numPointsProfile; i++) // { // printf ("%g %g\n", fInputPhaseProfile[i], mInputPhaseProfile[i]); // } acc = gsl_interp_accel_alloc (); spline = gsl_spline_alloc (gsl_interp_linear, numPointsProfile); gsl_spline_init (spline, fLog, mInputPhaseProfile, numPointsProfile); return 0; } //-------------------------------------------------------------------------------------------------- // // GetPhaseNoiseValue // // Given the desired frequency, this function uses linear interpolation in log-space to // calculate the phase noise power. // // Input // ----- // f frequency (Hz) // // Output // ------ // sf phase noise power in absolute units // // Revisions // --------- // 25-Jun-02 Initial version written. // //-------------------------------------------------------------------------------------------------- double GetPhaseNoiseValue(double f) { double sf; const double noiseFloor = -150.0; extern int numPointsProfile; extern double fInputPhaseProfile[]; extern gsl_interp_accel *acc; extern gsl_spline *spline; f = abs(f); if (f > fInputPhaseProfile[numPointsProfile-1]) { sf = noiseFloor; // dBc/Hz } else { // interpolate to get phase noise power at desired frequency sf = gsl_spline_eval (spline, log10(f), acc); } sf = pow(10.0, 0.1*sf); return(sf); }
>Yu Xiaodong wrote: >> Hi All, >> >> Is there anyone know how to generate 1/f noise for simulating the
phase
can
>> be generated. Any clue about the FIR? >> >> Thanks alot >> >> R. Y. > >R.Y.: > >Here's some C++ code that I wrote that will create phase noise samples >from a user-specified phase noise profile. The code uses the GNU >Scientific Library (freely available). > >Good luck, >OUP > >//-------------------------------------------------------------------------------------------------- >// >// phase_noise >// >// Generate random deviates whose spectrum matches a phase noise >profile. This code uses the >// GNU Scientific Library (GSL) v1.1.1. >// >// Revisions >// --------- >// 25-Jun-02 Initial version written. >// >//-------------------------------------------------------------------------------------------------- > >#include <stdio.h> >#include <stdlib.h> >#include <iostream.h> >#include <math.h> > >#include <gsl/gsl_complex.h> >#include <gsl/gsl_complex_math.h> >#include <gsl/gsl_errno.h> >#include <gsl/gsl_fft_complex.h> >#include <gsl/gsl_fft_halfcomplex.h> >#include <gsl/gsl_fft_real.h> >#include <gsl/gsl_randist.h> >#include <gsl/gsl_rng.h> >#include <gsl/gsl_spline.h> >#include <gsl/gsl_vector.h> > >#include "phase_noise.h" > >//-------------------------------------------------------------------------------------------------- >// >// main >// >//-------------------------------------------------------------------------------------------------- > >int main (int argc, char *argv[]) >{ > int i, numSamples; > double fs; > double xi, yi; > > // number of samples > numSamples = atoi(argv[1]); > > // sample frequency in Hz > fs = atof(argv[2]); > > InitPhaseProfile(); > > double *phi = new double [numSamples]; > > GenPhaseNoiseDeviates(phi, numSamples, fs); > > for (i = 0; i < numSamples; i++) > { > fprintf(stdout,"%d %19.16e\n", i, phi[i]); > } > >} > >//-------------------------------------------------------------------------------------------------- >// >// GenPhaseNoiseDeviates >// >// Inputs >// ------ >// numSamples number of samples to generate >// fs sample frequency (a.k.a. PRF) >// >// Input/Output >// ------------ >// phiRandom array to hold random deviates >// >// Revisions >// --------- >// 25-Jun-02 Initial version written. >// >//-------------------------------------------------------------------------------------------------- >int GenPhaseNoiseDeviates(double phiRandom[], int numSamples, double fs) >{ > int i; > > extern int numPointsProfile; > > //------------------------------- > // Generate white Gaussian noise > //------------------------------- > > gsl_rng_env_setup(); > > const gsl_rng_type *T = gsl_rng_default; > gsl_rng *r = gsl_rng_alloc(T); > > double *wn = new double [numSamples]; > > for (i = 0; i < numSamples; i++) > { > wn[i] = gsl_ran_gaussian(r, 1.0); // zero mean, unity sigma > //cout << wn[i] << "\n"; > } > > // Store the white noise samples in a GSL "packed" array. A "packed" >array holds complex data > // in a double arrray. The order is real, imag, real, imag, and so
on.
> > double *packedWn = new double [2*numSamples]; > > for (i = 0; i < numSamples; i++) > { > REAL_PACKED(packedWn,i) = wn[i]; > IMAG_PACKED(packedWn,i) = 0.0; > } > > //------------------------------------------------------ > // forward Fourier transform of the white noise samples > //------------------------------------------------------ > > gsl_fft_complex_workspace *workspace = >gsl_fft_complex_workspace_alloc(numSamples); > gsl_fft_complex_wavetable *wavetable = >gsl_fft_complex_wavetable_alloc(numSamples); // we'll use this for the >inverse too > > gsl_fft_complex_forward(packedWn, 1, numSamples, wavetable,
workspace);
> > //-------------------------------------------- > // Construct the aliased phase noise response > //-------------------------------------------- > > int nFold = int( fInputPhaseProfile[numPointsProfile-1] / fs ) + 1; > > if (nFold > nFoldMax) nFold = nFoldMax; > > int nHalf = numSamples/2; > > double *hMag = new double [nHalf]; > double *f = new double [nHalf]; > double *mSSB = new double [nHalf]; > > double fMin = 1.0; > double fMax = fs / 2.0; > double fStep = (fMax - fMin)/(nHalf-1); > > int k; > double summation; > > for (i = 0; i < nHalf; i++) > { > summation = 0.0; > f[i] = fMin + i*fStep; > for (k = -nFold; k <= nFold; k++) > { > summation = summation + GetPhaseNoiseValue(f[i] + k*fs); > } > hMag[i] = summation; > mSSB[i] = GetPhaseNoiseValue(f[i]); > } > >// for (i = 0; i < nHalf; i++) >// { >// fprintf(stdout,"%f %19.16e %19.16e\n", f[i], mSSB[i], hMag[i]); >// } > > // Construct a double-sided phase noise profile. This has even >symmetry. Note that the > // GSL stores the positive frequencies first, then the negative >frequencies in reverse > // order. We'll construct our DSB profile the same way. > > double *mDSB = new double [numSamples]; > > for (i = 0; i < nHalf; i++) > { > mDSB[i] = hMag[i]; > mDSB[i+nHalf] = hMag[nHalf - 1 - i]; > } > > double *packedDSB = new double [2*numSamples]; > > for (i = 0; i < numSamples; i++) > { > REAL_PACKED(packedDSB,i) = mDSB[i]; > IMAG_PACKED(packedDSB,i) = 0.0; > //cout << mDSB[i] << "\n"; > } > > //---------------------------- > // Convolve the two sequences > //---------------------------- > > double *packedY = new double [2*numSamples]; > > gsl_complex h, x, z; >// double hx, hy, wx, wy; > > for (i = 0; i < numSamples; i++) > { >// wx = REAL_PACKED(packedWn,i); >// wy = IMAG_PACKED(packedWn,i); > >// hx = REAL_PACKED(packedDSB,i); >// hy = IMAG_PACKED(packedDSB,i); > >// GSL_SET_COMPLEX(&x, wx, wy); >// GSL_SET_COMPLEX(&h, hx, hy); > > GSL_SET_COMPLEX(&x, REAL_PACKED(packedWn,i),
> GSL_SET_COMPLEX(&h, REAL_PACKED(packedDSB,i), >IMAG_PACKED(packedDSB,i)); > > z = gsl_complex_mul(h,x); > > REAL_PACKED(packedY,i) = GSL_REAL(z); > IMAG_PACKED(packedY,i) = GSL_IMAG(z); > >// packedY[i] = packedDSB[i] * packedWn[i]; // this only works >because imaginary part is zero! > } > > //--------------------------- > // Inverse Fourier transform > //--------------------------- > > gsl_fft_complex_inverse(packedY, 1, numSamples, wavetable,
workspace);
> > for (i = 0; i < numSamples; i++) > { > phiRandom[i] = REAL_PACKED(packedY,i); > } > > // free some stuff > > gsl_fft_complex_workspace_free(workspace); > gsl_fft_complex_wavetable_free(wavetable); > > gsl_spline_free (spline); > gsl_interp_accel_free(acc); > > return 0; >} > >//-------------------------------------------------------------------------------------------------- >// >// InitPhaseProfile >// >// Initialize stuff for the phase profile interpolation. >// >// Revisions >// --------- >// 25-Jun-02 Initial version written. >// >//-------------------------------------------------------------------------------------------------- >int InitPhaseProfile() >{ > int i; > extern int numPointsProfile; > > numPointsProfile = sizeof(fInputPhaseProfile)/sizeof(double); > > double *fLog = new double [numPointsProfile]; > > extern double fInputPhaseProfile[], mInputPhaseProfile[]; > extern gsl_interp_accel *acc; > extern gsl_spline *spline; > > for (i = 0; i < numPointsProfile; i++) > { > fLog[i] = log10(fInputPhaseProfile[i]); > } > > // printf ("#m=0,S=2\n"); > // for (i = 0; i < numPointsProfile; i++) > // { > // printf ("%g %g\n", fInputPhaseProfile[i],
> // } > > acc = gsl_interp_accel_alloc (); > spline = gsl_spline_alloc (gsl_interp_linear, numPointsProfile); > > gsl_spline_init (spline, fLog, mInputPhaseProfile, numPointsProfile); > > return 0; >} > >//-------------------------------------------------------------------------------------------------- >// >// GetPhaseNoiseValue >// >// Given the desired frequency, this function uses linear interpolation
>in log-space to >// calculate the phase noise power. >// >// Input >// ----- >// f frequency (Hz) >// >// Output >// ------ >// sf phase noise power in absolute units >// >// Revisions >// --------- >// 25-Jun-02 Initial version written. >// >//-------------------------------------------------------------------------------------------------- >double GetPhaseNoiseValue(double f) >{ > double sf; > const double noiseFloor = -150.0; > > extern int numPointsProfile; > extern double fInputPhaseProfile[]; > extern gsl_interp_accel *acc; > extern gsl_spline *spline; > > f = abs(f); > > if (f > fInputPhaseProfile[numPointsProfile-1]) > { > sf = noiseFloor; // dBc/Hz > } > else > { > // interpolate to get phase noise power at desired frequency > sf = gsl_spline_eval (spline, log10(f), acc); > } > > sf = pow(10.0, 0.1*sf); > > return(sf); >} > > >
Hi,
You can read this article for generate 1/f noise
http://www.istia.univ-angers.fr/~chapeau/papers/jautotel.pdf (in french)
http://www.istia.univ-angers.fr/~chapeau/papers/psiplrc2.pdf (in english)
ok
phase
can
on.
workspace);
workspace);
Flat white noise fed into a flat FM modulator will produce 1/F^2
shaped phase noise.
Most phase noise is usually 1/F^2.
1/F noise (flicker noise)  in transistors etc usually creates phase
noise that is 1/F^3 very close to the carrier.
Why do you want to create 1/F shaped phase noise?
Mark
