I have a query on zero-padded FFT's.For calculating FFT of a signal with sampling rate 256 HZ what is the maximum zero padding that can be done?And what does zeropadding actually do to the signal. I have observed frequency shift with zero padding.why so?
Zero padded FFT
Started by ●July 4, 2003
Reply by ●July 4, 20032003-07-04
Zero padding actually more or less interpolates the frequency domain points you would have without zero padding. Frequency shifts are impossible in this respect. I don't really know what you mean by 'maximum zero padding'... Ciao, Dominiek ssahuiit@rediffmail.com wrote in message news:<2ce2ab3c.0307040100.4b2dddc2@posting.google.com>...> I have a query on zero-padded FFT's.For calculating FFT of a signal > with sampling rate 256 HZ what is the maximum zero padding that can > be done?And what does zeropadding actually do to the signal. I have > observed frequency shift with zero padding.why so?
ssahuiit@rediffmail.com wrote in message news:<2ce2ab3c.0307040100.4b2dddc2@posting.google.com>...> I have a query on zero-padded FFT's.For calculating FFT of a signal > with sampling rate 256 HZ what is the maximum zero padding that can > be done?Zero padding appends artificial data points of value 0 to the finite data series. The amount of artificial data points that can be appended would probably be limited by system memory.> And what does zeropadding actually do to the signal.It interpolates the spectrum.> I have > observed frequency shift with zero padding.why so?The values of the DFT coefficient are constrained on the spectrum lines that also are found in the DFT of the non-zero padded sequence. However, the gradient is not, so one might see situations where the interpolated spectrum has a positive gradient dX/df on one "true" line and a negative gradient on the nex, which means there would be a maximum in between. It's can be regarded as an artifact of the interpolation. Rune
