6711 DSK linker cmd file
Started by Dave F June 27, 2003
Hey guys,
Is there any way to tell the code composer studio to make
a chunk in off-chip ram CE0, and just put 2 arrays in it?
I dont want to put all my data variables in it, since it
is slower than IRAM and this is a real-time DSP app.
Thanks
Dave
"Dave F" <no@spam.com> wrote in message
news:LN%Ka.518$5q6.160634@ursa-nb00s0.nbnet.nb.ca...
> Hey guys, > > Is there any way to tell the code composer studio to make > a chunk in off-chip ram CE0, and just put 2 arrays in it? > I dont want to put all my data variables in it, since it > is slower than IRAM and this is a real-time DSP app. > > Thanks > Dave
This is relatively easy to do. 1) Use the #pragmas to place specified variables into certain sections. 2) Add a section to your .cmd to put the section into the desired memory block. /* Put this at the top of your C code. Make sure you don't include an extern to this variable above the #pragma statement. (Sometimes happens if you include a header file.) */ #pragma DATA_SECTION(sine_table, "tables") COMPLEX sine_table[N]; // Stores cosine and sine values for lookup. /* Linker.cmd. */ SECTIONS { coeff_sect > SARAM_A samples >SARAM tables > SARAM_B }
On Sun, 29 Jun 2003 23:30:05 -0500, "Jerry J. Trantow"
<jtrantow@ieee.org> wrote:
>/* > Put this at the top of your C code. > Make sure you don't include an extern to this variable above the #pragma >statement. (Sometimes happens if you include a header file.) >*/ >#pragma DATA_SECTION(sine_table, "tables") >COMPLEX sine_table[N]; // Stores cosine and sine values for lookup.
Note that pragma DATA_SECTION has a slightly different syntax if you're using C++! In C++ the pragma is not qualified with an object name, and is applicable to only the object immediately following the pragma. So, for the above, you would just have: #pragma DATA_SECTION("tables") COMPLEX sine_table[N]; // Stores cosine and sine values for lookup. Best Regards John McCabe To reply by email replace 'nospam' with 'assen'
