snsundar@olemiss.edu (sundar) writes:> yes even i do , thank you so much.Sure thing, sundar.> Randy, i have one more question, after i do a > hilbert(y) > ang=angle(y); > plot(ang(:,1)) > > this plot that iam getting has a pattern for a signal and is not > random for noise. Can you tell me why, am i not getting a random phase > angle distribution for that one sec data for noise. I read some of the > old posts and think that i might have something to do with my > filtering, and since my filtering widht is very narrow, all my points > are sort of correlated and hence lose their random behavior and show a > pattern.I think I agree with the "old posters." Here's one way to look at it: The output power-spectral density Sy(w) of a signal x passed throw a filter H(w) is Sy(w) = Sx(w) * |H(w)|^2, where Sx(w) denotes the input signal's PSD. Also, the Wiener-Khinchine theorem states that the power spectrum of a signal Sy(w) is the Fourier transform of its autocorrelation function Ry(k), or said from the other direction, the autocorrelation Ry(k) of a signal is the *inverse* Fourier transform of its PSD, Ry(k) = T_s/(2*pi) \int_{\pi/T_s}^{+\pi/T_s} Sy(w) e^{+j*w*k*T_s) dw. So if you have an H(w) that is very narrow, the resulting Sy(w) is also very narrow, and the resulting inverse FT will be "wide," i.e., non-zero at a lot of points, indicating there is a lot of correlation in the signal. A much easier way to look at it is just as you've begun: a narrow filter produces a sine way.> i tried > angun=unwrap(ang); % unwrap my phase > phi=angun(:,1)-2*pi*freq*(0:1/fs:1)'; % remove my carrier freq > plot(phi) > phi1=atan2(sin(phi1),cos(phi1)); % convert from -pi to pi > plot(phi1) > > This again leads me nowhere.Yeah, I don't doubt it.> Using the hilbert transform how can i differentiate between signal and > noise.I don't know. Who said it could be used that way?> thanks so much once again...u could mail me and post the reply since > that way it wud be faster for us to communicate. > > Thanks so much > > Regards > > Sundar snsundar@olemiss.eduMy Dad's family is from Taylorsville, MS - a small berg between Laurel and Jackson. Several of my uncles and cousins have attended Ole Miss. I'm jealous! Presuming you're Indian, which part are you from? I'm going to Bangalore the end of the month to visit my fiancee. -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
filtering in freq domain
Started by ●November 7, 2004
Reply by ●November 9, 20042004-11-09
Reply by ●November 10, 20042004-11-10
Rune Allnor wrote:> Randy Yates <yates@ieee.org> wrote in message news:<actt9icg.fsf@ieee.org>......>>Note that frequency-domain filtering is only useful for FIR filters, i.e., >>filters in which the a vector above is 1. Butterworth filters are not >>FIR filters, so you won't be able to use frequency-domain filtering on them. > > > Yes you are. With the filter coefficients grouped as a and b above, > the frequency domain IIR filter is implemented as > > X=fft(x,N); % DFT of input signal > A=fft(a,N); > B=fft(b,N); > Y= X.*B./A; > y= real(ifft(y)); > > where the FFT length N is large enough to contain both the input signal > and startup and end transients. The only difficult part here is to > find a suitable N. Which can be hard enough, though. > > RuneRune, This is really just an approximation of an IIR filter by taking the first (most significant) portion of its impulse response and truncating it, thus making it a finite impulse response. With a stable IIR filter, this approximation can be made close enough for any practical purposes. I'd say Rune and Randy are both right, depending on the viewpoint. In the strict sense, it is imposible to implement an infinite impulse response with circular convolution. In practice, you can get as close as you want (excepting instability/marginal stability). -- Mark
Reply by ●November 11, 20042004-11-11
Mark Borgerding <mark@borgerding.net> wrote in message news:<9gqkd.1761$DI5.1733@fe1.columbus.rr.com>...> Rune Allnor wrote: > > Randy Yates <yates@ieee.org> wrote in message news:<actt9icg.fsf@ieee.org>... > ... > >>Note that frequency-domain filtering is only useful for FIR filters, i.e., > >>filters in which the a vector above is 1. Butterworth filters are not > >>FIR filters, so you won't be able to use frequency-domain filtering on them. > > > > > > Yes you are. With the filter coefficients grouped as a and b above, > > the frequency domain IIR filter is implemented as > > > > X=fft(x,N); % DFT of input signal > > A=fft(a,N); > > B=fft(b,N); > > Y= X.*B./A; > > y= real(ifft(y)); > > > > where the FFT length N is large enough to contain both the input signal > > and startup and end transients. The only difficult part here is to > > find a suitable N. Which can be hard enough, though. > > > > Rune > > Rune, > This is really just an approximation of an IIR filter by taking the > first (most significant) portion of its impulse response and truncating > it, thus making it a finite impulse response.Uh, yes? Of course, any implementation that works on a finite number of samples can only be an approximation of a true IIR. I don't know of many practical implementations that are truly infinite.> With a stable IIR filter, this approximation can be made close enough > for any practical purposes.Which, of course, is the interesting bit.> I'd say Rune and Randy are both right, depending on the viewpoint.If you read the exchange of opinion between Randy and me, you will find that one opinion goes as "Non-FIR filters filters can not be implemented in frequency domain" while the other goes as "yes they can, and here's how it can be done". Regardless of practical issues, I think the two points of views are mutually exclusive, and I find it hard to see that both can be right.> In the strict sense, it is imposible to implement an infinite impulse > response with circular convolution.I'd go a bit further and say "it is imposible to implement an infinite impulse response" regardless of whether one uses circular convolution or not. Of course, in the case of the FIR one has a finite end transient, so the practical aspects of determining the N above become easier (N = length(x) + 2*length(b)-2;). In the IIR case, one needs to find a "effective length" of the impulse response, and decide at what time the impulse response no longer makes significant contributions to the start/end transient. This needs not be an easy task, but it is possible to do within the constraints of practical limitations to IIR systems. Now, the question was whether it is _possible_ to implement a Butterworth filter (I'll take the liberty to generalize this to a 'recursive filter') in frequency domain. If you want to go hypothetical and discuss the infinite time case, use the 'proper' DFT (with infinite summation ranges) instead of the FFT to compute the spectra A and B above. The theory works perfectly well in frequency domain. You only need the filter coefficients, no time-domain data at all.> In practice, you can get as close > as you want (excepting instability/marginal stability).Agreed. Rune
Rune Allnor wrote:> Mark Borgerding <mark@borgerding.net> wrote in message news:<9gqkd.1761$DI5.1733@fe1.columbus.rr.com>... > > If you read the exchange of opinion between Randy and me, you will find > that one opinion goes as "Non-FIR filters filters can not be implemented > in frequency domain" while the other goes as "yes they can, and here's > how it can be done". Regardless of practical issues, I think the two > points of views are mutually exclusive, and I find it hard to see that > both can be right.Randy says one can only use fast convolution for FIR filters. You show how you can implement IIR filtering with fast convolution ... by turning that IIR filter into an FIR filter. So who's right? Both of you. Although Rune gets bonus points for creative solutions. Myself, I prefer to do the IIR to FIR conversion explicitly in the time domain, rather than guessing at transient lengths The question we should be asking is, "why use IIR filters if you can use fast convolution?" The OP may have a legitimate reason, but it is good to keep sight of FIR design methods in the process. A (The?) reason for using IIR filters is to get better filter shape than a direct-implemented FIR of equal cost could provide. Example: Butterworth(5) vs. Remez(32) A 5th order butterworth (IIR) filter can be expressed (with error < -90dB) by an impulse response of length 34. A Remez filter order 32 (33 coeffs), has a shorter impulse response, a better frequency response, and linear phase. But don't take *my* word for it ... % Here's a little Octave/Matlab code to demonstrate IIR to FIR % truncation and compare it to similar length Remez filter % Copyright Mark Borgerding, 2004 % Licensed under a BSD License % see http://www.fsf.org/licenses/info/BSD_3Clause.html [bbi,abi]=butter(5,.5); bbf = filter(bbi,abi,[1 zeros(1,100)]); bbfpow = sum(bbf.^2); trunc_pow_loss = 10*log10( 1 - cumsum(bbf.^2)/bbfpow); coefs_needed = min( find( trunc_pow_loss < -90) ) % coefs_needed is 34 bremez = remez(32,[0 .3 .8 1],[1 1 0 0]); figure(1); title('original IIR Butterworth'); freqz(bbi,abi); figure(2); title('FIR approx of Butterworth'); freqz(bbf(1:coefs_needed) ); figure(3); title('Remez filter of similar cost to FIR approx'); freqz(bremez); Cheers, Mark <SHAMELESS_PLUG> If you like what you see above, and would like to inquire how I could help your project, contact markb@3dB-Labs.com for more info. If you don't like what you see above, and think I can't even spell DSP, then I claim this post was written a roaming gang of rabid monkeys. Dang monkeys. </SHAMELESS_PLUG>
Mark Borgerding <mark@borgerding.net> writes:> [...] > Randy says one can only use fast convolution for FIR filters. > > You show how you can implement IIR filtering with fast convolution > ... by turning that IIR filter into an FIR filter.You're attempting to show some grace, Mark - a personal quality of the highest order. The hard fact is, "finite != infinite," just as much as "is != (is not)." Thus the finite DFT (as defined by Oppenheim et al. in "Signals and Systems," and which is by definition the tool used in frequency-domain filtering as defined in P&M) can NEVER be used to implement an infinite impulse response. And to put a stop to the "practical implementation" argument, I was speaking analytically, not practically. (Please side-step the emotional power in this message, Mark et al., and allow it to reach its intended target.) -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
Reply by ●November 12, 20042004-11-12
Mark Borgerding <mark@borgerding.net> wrote in message news:<fCLkd.143680$5v2.39391@fe2.columbus.rr.com>...> Rune Allnor wrote: > > Mark Borgerding <mark@borgerding.net> wrote in message news:<9gqkd.1761$DI5.1733@fe1.columbus.rr.com>... > > > > If you read the exchange of opinion between Randy and me, you will find > > that one opinion goes as "Non-FIR filters filters can not be implemented > > in frequency domain" while the other goes as "yes they can, and here's > > how it can be done". Regardless of practical issues, I think the two > > points of views are mutually exclusive, and I find it hard to see that > > both can be right. > > Randy says one can only use fast convolution for FIR filters.Well... it's a matter of interpreting the original question. I agree if you say "one can only use fast convolution for finite amounts of data". In that sense, any practical data set is finite, and an IIR filter does not really yield an infinite impulse response and can be said to be FIR. My interpretation of the question is whether recursive filters (I'm rephrasing here, to avoid splitting hairs over the word "infinite") can be implemented in frequency domain. True, the price paid for using the frequency domain method for IIRs is the risk of wrap-around effects, but with care you can implement the IIR as a frequency domain solution. Whether that's an easy or smart thing to do, is a completely different matter.> You show how you can implement IIR filtering with fast convolution ... > by turning that IIR filter into an FIR filter.Yep. That's a common way of doing things. The main benefit when compared to the "IIR way" is that you have complete control of end transients. You do need to compute the impulse response, though, from the IIR filter coefficients. How would you du that? Some use the unit impulse sequence and implement the difference equation. That way one can decide the "effective N" on the fly, by monitoring the magnitude of the response samples. It would require a "sufficiently large" data buffer being available in the first place, to store the coefficients. If that's not available, you would have to estimate the impulse response twice: The first time to estimate the number of "effective" coefficients in the impulse response; the second time to compute the coefficients before storing them after having allocated the memory space. An alternative would be to try h=real(ifft(fft(b,N)./fft(a,N))); where a and b are the filter coefficient vectors and N is "sufficiently large" to contain the significant parts of the impulse response. Again, the problem is that N must be specified in advance. I don't say that this is a particularly smart way of doing things, but it's _possible_ to do it like this.> So who's right? Both of you. > Although Rune gets bonus points for creative solutions.Thanks for the credit, but I picked it up somewhere on comp.dsp. I can't remember who posted the trick, though.> Myself, I prefer to do the IIR to FIR conversion explicitly in the time > domain, rather than guessing at transient lengthsAgreed. That's the way one would do it in practice. Again, my interpretation of the question was whether pure frequency domain operations are _possible_.> The question we should be asking is, "why use IIR filters if you can use > fast convolution?"There was a thread here, some time ago, where the poster tried to do some processing in frequency domain and convert back to time domain and play the result on the speaker. The resulting sound wasn't very good, and I think glitches at the joints between blocks was at least part of the problem. Frequency domain solutions might work in off-line applications. In on-line applications you might get into other kinds of trouble that time-domain implementations avoid.> The OP may have a legitimate reason, but it is good to keep sight of FIR > design methods in the process. A (The?) reason for using IIR filters is > to get better filter shape than a direct-implemented FIR of equal cost > could provide.There are other reasons. A student of mine did some data processing where it turned out that control of passband ripple was essential for getting good results. The trick only worked when he used Butterworth or Cheb 2 filters. As far as I know, he used the IIR implementation. I don't know if things would have been messed up if he had used a FIR approximation (actually, I doubt that a FIR approximation would have made much of a difference). Rune
