Gordon Sande <g.sande@worldnet.att.net> wrote> Position invariance would mean that a seascape would have the same > properties as an urban image. If you think not then you have given > up the Fourier assumptions. The things folks will agree on tend to > suggest Haar analysis or perhaps wavelets.I actually think it's a little different from the way you say it. I don't think it's that the stationarity problem occurs between different images, it's that the statistics of an image change _within_ a given image. For example, the pixel values of the sea in a seascape would have different mean and standard deviation from the pixel values of the beach in the same seascape. That's why images can be thought of as non-stationary. For what it's worth, I really don't think that stationarity says anything about whether the Fourier transform can or can't be used. Of course it can be used; how you interpret it might be a problem, but many non-stationary problems (e.g. speech, sonar) have used the Fourier transform to good effect. Ciao, Peter K.
why is an image non-stationary?
Started by ●November 24, 2004
Reply by ●November 24, 20042004-11-24
