Hi, I'm using the C6416 DSK with the DSignT DSK-91C111 Ethernet daughter card. In fact this card just connects an SMSC 91C111 MAC+PHY to the DSP's EMIFA and an interrupt line to one of the DSP's external interrupt pins. What I want to do is to receive audio data via ethernet and send it to the board's audio output. So at the moment, whenever I get an HWI from the MAC I start a service routine that tries to receive the packet and if succesful sends it to the codec's buffer. That works, but in fact the quality of the audio output is quite bad. I guess, since the ISR runs every time completely when an HWI arrives, not knowing what kind of interrupt this could be, I get problems in keeping my real time requirements (since I'm waiting for packets that won't arrive). I think the solution is to check the MAC's interrupt register in order to know the reason of the HWI and then only if a new packet has arrived I should try to receive this one. I konw the base address and the offset of the interrupt register but since I don't have to much experience with DSPs, CCS or assembler I don't know how to access it. Would be nice, if somebody could help me. By the way, I'm using CCS and DSP/BIOS
Interrupt Register access via EMIF
Started by ●December 1, 2004
Reply by ●December 2, 20042004-12-02
scottie7980@yahoo.de (scottie) wrote in message news:<ce76b8ba.0412010137.5e7ce8d@posting.google.com>...> Hi, > I'm using the C6416 DSK with the DSignT DSK-91C111 Ethernet daughter > card. In fact this card just connects an SMSC 91C111 MAC+PHY to the > DSP's EMIFA and an interrupt line to one of the DSP's external > interrupt pins. > What I want to do is to receive audio data via ethernet and send it to > the board's audio output. So at the moment, whenever I get an HWI from > the MAC I start a service routine that tries to receive the packet and > if succesful sends it to the codec's buffer. That works, but in fact > the quality of the audio output is quite bad. I guess, since the ISR > runs every time completely when an HWI arrives, not knowing what kind > of interrupt this could be, I get problems in keeping my real time > requirements (since I'm waiting for packets that won't arrive). I > think the solution is to check the MAC's interrupt register in order > to know the reason of the HWI and then only if a new packet has > arrived I should try to receive this one. I konw the base address and > the offset of the interrupt register but since I don't have to much > experience with DSPs, CCS or assembler I don't know how to access it. > Would be nice, if somebody could help me. > By the way, I'm using CCS and DSP/BIOSHi Since the interrupt register is a memory mapped one you may use the any of the macros given in the peripheral support library which should be part of the software package along with the DSK. The macro would be something like GET_REG... probably somebody else in the group might be able to give you the exact info about that as i have not used this DSK.. Hope it helps -Nithin
scottie7980@yahoo.de (scottie) wrote in message news:<ce76b8ba.0412010137.5e7ce8d@posting.google.com>...> Hi, > I'm using the C6416 DSK with the DSignT DSK-91C111 Ethernet daughter > card. In fact this card just connects an SMSC 91C111 MAC+PHY to the > DSP's EMIFA and an interrupt line to one of the DSP's external > interrupt pins. > What I want to do is to receive audio data via ethernet and send it to > the board's audio output. So at the moment, whenever I get an HWI from > the MAC I start a service routine that tries to receive the packet and > if succesful sends it to the codec's buffer. That works, but in fact > the quality of the audio output is quite bad. I guess, since the ISR > runs every time completely when an HWI arrives, not knowing what kind > of interrupt this could be, I get problems in keeping my real time > requirements (since I'm waiting for packets that won't arrive). I > think the solution is to check the MAC's interrupt register in order > to know the reason of the HWI and then only if a new packet has > arrived I should try to receive this one. I konw the base address and > the offset of the interrupt register but since I don't have to much > experience with DSPs, CCS or assembler I don't know how to access it. > Would be nice, if somebody could help me. > By the way, I'm using CCS and DSP/BIOSU may want look it up in the manual at http://focus.ti.com/lit/ug/spru273b/spru273b.pdf -Nithin
