Hello all, I am implementing Speech to Text Conversion task using MATLAB. I implemented with LPC and Kohonnen's neural network to do Speaker Identification task . Now i am able to idenify the speaker. With the same method i am able to identify the Vowel sounds also. Further i am not able to proceed to implement Consonent Conversion. I do not know about Phoneme also. Can any body suggest me some useful tip for this, Thanks in advance, Athreya Sathish
I need Some help regarding speech to Text Conversion task
Started by ●December 6, 2004
Reply by ●December 6, 20042004-12-06
On Mon, 6 Dec 2004 11:23:21 +0100, "Athreya Sathish" <saikumar.mangapuram@de.bosch.com> wrote:>I am implementing Speech to Text Conversion task using MATLAB. > >Athreya SathishI have known that such work is not a simple stuff but you did, so I'm much envy you(^^). To my knowledge, the algorithm you are doing will takes long time because of its complexity. Am I right? If so, have you ever get any speed problem for running your program with MATLAB, which is not a machine code specific compiling language. Because I also have to do the similar task and wish to make my program as a m-file as possible for its simplicity, I'd like to know your opinion about the speed of m-files. -- Best regards, James K. (txdiversity@hotmail.com) [HOME] http://home.naver.com/txdiversity
Reply by ●December 18, 20042004-12-18
