Hi, In a typical application of OFDM receiver an 8 bit -ADC is sampled at 6.4 Msamples/s. I have to take ADC output through a serial port. After transfering to memory I need to perform 1024-point FFT on real time basis. What should be my optimum buffer size. Do we need to know FFT processing delay, Clock speed of the processor etc. in advance? I thought it should be 2*1024 - Is that correct? (consider :: One memory unit holds a complex sample) Santosh
1024-point FFT buffer size of OFDM receiver
Started by ●December 9, 2004
Reply by ●December 9, 20042004-12-09
Typically, you'd be getting the samples and performing the FFT in a pipelined fashion. So you'd need two 1024 sample buffers - one to hold your input and the other on which you'd be performing your FFT. Of course, this assumes that the processor is fast enough to complete the FFT and all other processing BEFORE the next block of data is ready. If your sampling clock is 6.4MHz, then you have a 1024-point blockset available in 160us. So you need to make sure that your DSP can finish other processing and free up the buffer before then. As an example, the c64x requires about 6000 cycles to do a 1024 point complex fft (see http://dspvillage.ti.com/docs/catalog/generation/details.jhtml?templateId=5154&path=templatedata/cm/dspdetail/data/c64_benchmarks). If you have a c64x running at 500MHz, then it would need 12us to complete the FFT giving it (160-12)us for other processing. If all your other processing with the data can be completed in that time, then you're ok. Of course, you need to be careful of benchmark numbers you accept and estimate all the other tasks your dsp is loaded with. - Ravi
Reply by ●December 10, 20042004-12-10
Ravi Srikantiah wrote:> Typically, you'd be getting the samples and performing the FFT in a > pipelined fashion. So you'd need two 1024 sample buffers - one to hold > your input and the other on which you'd be performing your FFT. Of > course, this assumes that the processor is fast enough to complete the > FFT and all other processing BEFORE the next block of data is ready. > > If your sampling clock is 6.4MHz, then you have a 1024-point blockset > available in 160us. So you need to make sure that your DSP can finish > other processing and free up the buffer before then. > > As an example, the c64x requires about 6000 cycles to do a 1024 point > complex fft (see > http://dspvillage.ti.com/docs/catalog/generation/details.jhtml?templateId=5154&path=templatedata/cm/dspdetail/data/c64_benchmarks). > If you have a c64x running at 500MHz, then it would need 12us to > complete the FFT giving it (160-12)us for other processing. If all your > other processing with the data can be completed in that time, then > you're ok. > > Of course, you need to be careful of benchmark numbers you accept and > estimate all the other tasks your dsp is loaded with. > > - RaviActually, you really don't need two complete buffers. You only need 1.x buffers depending on the speed of your DSP. Continuing with the above example, if say, all processing by the dsp only took 60us, then the dsp could free up the buffer after that time, you'd only need a buffer to store incoming samples for the 60us that the dsp is using the 1024-point buffer. 60us time translates to 384 samples at 6.4MHz, so you'd need a (1024+384) sample buffer. - Ravi
