Uli wrote:> Hi all, > > thanks first for all your comments. > As I honestly have said I'm a newbie to DSP. The book of > www.dspguide.com is now what I understood so far. And I have directly > used the code samples there. They are given in BASIC and I have > transferred them to DELPHI, my favourite programming language. > So I have declared arrays of the described sizes with doubleprecision. I haven't seen the code snippets you refer to. Usually, such snippets are shaved to the bone what memory management, optimizations and numerical consistecy is concerned. If you have used a textbook code example to handle bulky problems like what you indicate here, I am not at all suprised you end up with problems. Having said that, this is a very useful experience. I whish more people met practical problems like these when they programmed. These are the kind of real-world problems that make or brake a project. Anticipating them early is a huge advantage in practical project work. I think DELPHI is a descendant of what used to be Borland Turbo Pascal? If so, there is no obvious reason why you would want to change to C/C++ or FORTRAN. The old pascal compiler (TP 6.0, 1990 vintage) was comparable with the C compiler of the time. I didn't swap from pascal to C until I attempted to implement production code. I haven't studied your code, I'm pretty sure most of the problem has to do with memory management. I suggest you try to handle this with some decent data I/O buffers. It ought to be possible to achieve a run-time less than one hour, given the computer, compiler and your experience. Rune
FFT convolution with overlap add
Started by ●December 13, 2004
Reply by ●December 19, 20042004-12-19
