What purpose is for a sliding FFT on windowing data?
Started by fl April 12, 2015
Hi,
I read some codes from some formal demonstration sample project. It is found
 that there are 4 data blocks (one is the present data block). After the 4
 block data windowing, it is sent to an FFT function. The interesting thing
 is that the FFT function is not the same with the windowing block. In fact,
 the FFT is cycled with a fixed data block position (as one data block is
 getting old in the 4 data blocks). That is, the FFT block begins at 0, 1, 2,
 3 if block 0 is always the latest data block position. I don't know the
 reason for this arrangement. Can you tell me something about it?
 Thanks,
On Sun, 12 Apr 2015 16:00:25 -0700 (PDT), fl <rxjwg98@gmail.com>
wrote:
>Hi, > >I read some codes from some formal demonstration sample project. It is found > that there are 4 data blocks (one is the present data block). After the 4 > block data windowing, it is sent to an FFT function. The interesting thing > is that the FFT function is not the same with the windowing block. In fact, > the FFT is cycled with a fixed data block position (as one data block is > getting old in the 4 data blocks). That is, the FFT block begins at 0, 1, 2, > 3 if block 0 is always the latest data block position. I don't know the > reason for this arrangement. Can you tell me something about it? > > Thanks,
Hello fl, It looks like you've received no replies to your post. There are guys here who know something about Sliding FFTs. But I don't think they understand the words and phrases you used in your question. For example, what does "4 block data windowing" and "FFT function is not the same with the windowing block" mean? If you can tell us EXACTLY, specifically, what you are doing I imagine someone here can provide you with a little help. By the way, the word "window" means different things to different people, so when you use the word "window" you should carefully describe what that word means to you. [-Rick-]
