Hi, I am learning about spectral analysis, now I want to solve a periodogram problem in Matlab but I'm getting wrong results, don't know why. I'm working with an AR random process: x(n)=e(n)+(summation from k=1 to N of) (α_k* x(n−k)) e(n) is a white noise signal and α_k are five given coefficients I plotted the power spectrum in Matlab for ω from 0 to π. Then I generated the realizations of x(n) with 10000 samples Now I'm trying to get the estimate of the spectrum from the generated data using the periodogram formula Sxx=(1/K)*∣(summation from k=0 to K-1 of) (x[k]*e^(−jωk))∣^2 with K=256 the number of first values of x(n). When I run my code what I get is a vector whose element are all the same constant value, so I'm getting a straight line in my plots. Not sure what is going wrong. I would appreciate if you can give a look to my code and advise on what I am doing wrong. This is the section of the code I'm using to find the estimates [CODE] var_e=0.01; % noise variance b_1=1.4261; % coefficients b_2=-.7634; b_3=-.9002; b_4=1.2548; b_5=-.5707; K=256; wn=rand(1,10000)-0.5; % white noise samp=1:1:1e4; T=10000; x=zeros(1,length(samp)); % here I generate the expectations for n=6:T+5 x(n)=b_1*x(n-1)+b_2*x(n-2)+b_3*x(n-3)+b_4*x(n-4)+b_5*x(n-5)+wn(n-5); end x=x(6:end); figure plot(samp,x) % here I'm looking for the periodogram. It's the section giving wrong results for i=1:length(w) % w is the frequency, has 1000 for k=1:K per2(i)=sum(x(k)*exp(-j*k*i)); % sum of exponentials pe2(i)=per2(i)*conj(per2(i)); % squared end end [CODE] Thanks in advance for your help, Alif Hamnan --------------------------------------- Posted through http://www.DSPRelated.com
Wrong results in periodogram code in Matlab
Started by ●May 10, 2015
Reply by ●May 11, 20152015-05-11
The following line has at least 2 defects per2(i)=sum(x(k)*exp(-j*k*i)); Hints Is i the same as w? How many items are being summed inside your sum statement ? Bob
>The following line has at least 2 defects > > per2(i)=sum(x(k)*exp(-j*k*i)); > >Hints > >Is i the same as w? >How many items are being summed inside your sum statement ? > > >BobHi, thanks for your answer. I get the first hint, should use w(i) instead of i. I changed to per2(i)=sum(x(k)*exp(-j*k*w(i))); But continue getting the same error: all the results are equal. I don't really get the second hint, I feel like just rewriting the summation formula. As I understand it, if I have my frequency w as a vector from zero to pi with 1024 elements and want to estimate the original power spectrum taking K=256 samples from the vector x (which has 10000 elements), aftr applying the periodogram formula I should get a vector with 1024 elements, so I can compare between the original and the estimated spectra.Am I ok? or I should get a vector with K-1 elements instead? How can I then make a comparison between the calculated an the estimated? Regards, Alif --------------------------------------- Posted through http://www.DSPRelated.com
I got it! Thanks very much for your help Bob, the loop: for k=0:K-1 per1=x(k+1)*exp(-1j*k.*w)+per1; end pdg1=((abs(per1)).^2)./K; plot(w,pdg1) Best Regards, Alif --------------------------------------- Posted through http://www.DSPRelated.com
