>>On Tue, 16 Jun 2015 11:48:24 -0400, robert bristow-johnson >><rbj@audioimagination.com> wrote: >> >>>dunno fer sure who "Robert" is. i don't remember any solution i have >>>ever done for a 15/50 microsecond deemphasis filter. >> >>He's referring to Robert Orban. >> >>https://groups.google.com/d/msg/comp.dsp/9kuirTaABzg/CSg4hgh0saoJ > >yeah, Robert Orban.... I think Robert Orban's and Greg Berchin methods >would realise an analog transfer function in digital domain with minimum >error.... I am going through these methods.... > >@ Greg I have mailed u...My name is sharvin >--------------------------------------- >Posted through http://www.DSPRelated.comHi greg, in http://www.dsprelated.com/showthread/comp.dsp/76256-1.php you have designed an eighth order filter. What could be the error for the first order filter according to your FDLS method Thanks --------------------------------------- Posted through http://www.DSPRelated.com
how to adjust poles and zeros for reducing error
Started by ●May 14, 2015
Reply by ●June 17, 20152015-06-17
On Wed, 17 Jun 2015 02:28:53 -0500, "alpha1" <103600@DSPRelated> wrote:>in >http://www.dsprelated.com/showthread/comp.dsp/76256-1.php >you have designed an eighth order filter. What could be the error for the >first order filter according to your FDLS methodOff hand, I don't know, but it will be very large. If I used 8th-order in that previous case, it's probably because 8th-order was needed to satisfy some goodness-of-fit criterion. I haven't received your direct email message, but once I do, I will send you the FDLS Matlab code. Then you can try it for yourself.
>On Wed, 17 Jun 2015 02:28:53 -0500, "alpha1" <103600@DSPRelated> wrote: > >>in >>http://www.dsprelated.com/showthread/comp.dsp/76256-1.php >>you have designed an eighth order filter. What could be the error forthe>>first order filter according to your FDLS method > >Off hand, I don't know, but it will be very large. If I used 8th-order >in that previous case, it's probably because 8th-order was needed to >satisfy some goodness-of-fit criterion. > >I haven't received your direct email message, but once I do, I will send >you the FDLS Matlab code. Then you can try it for yourself.Thank you Greg, Can u help me with the Robert orban's method???? I am finding it difficult to understand. --------------------------------------- Posted through http://www.DSPRelated.com
