malloc
Started by Simone Winkler January 2, 2005
Stephen Maudsley wrote:
> I was thinking about systems with several sources of differeent sized > tasks with different priorities, say a conferencing controller with > different protocols on incoming calls. Mallocing dynamic buffers by the > call handler might be the easiest way to contain all of the call > variable stuff in one module.
Malloc isn't guaranteed to return a valid pointer; it can fail. To my simple mind, if there's enough memory so that malloc is sure to succeed, you don't need it. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Thu, 06 Jan 2005 09:11:22 -0500, Jerry Avins <jya@ieee.org> wrote:
>It was you, wasn't it, who brought up the case of insufficient memory >for two different codecs that a base station had to deal with?
yes... that's right - it was me... but what I mean was insufficient memory for "data" - meaning - applications use memory for storing data and all that - for example - image processing algorithms (I know I'm drifting away from cell-phone-world) - use big buffers for manipulating images applying filters and all that... so - that's what I meant by insufficient "resources"...
>That depends. I've written programs that PUSHed a whole bunch of >constants, then executed the stack. Some people have trouble believing >it, but as far as memory is concerned, there's no difference in >structure between code and text.
;-) well - I do believe you - it is possible to push data to stack and execute it ;-) wait - isn't it called "dynamic programming"? where code is changed dynamically? the code being executed is changing itself dynamically... but I get the impression that we drifted far too far from the original subject ;-) sadly nobody answered my doubts about how the cell-phone system works with all the codecs ;-) did you move forward about mallocs Jerry? ;-)
Shawn Steenhagen wrote:
> Jerry et al. > > In our typical DSP systems, we use what I call "psuedo dynamic" or > "start-up" dynamic memory allocation in which the memory needed for various > "objects" (LMS filters, IIR & FIR filters, etc) are allocated off a static > heap at start up. Configuration information read from Flash can thereby be > used to change the characteristics of the system without a re-compile (i.e. > the same compile-time build of software can support different system > attributes such as filter length, IIR filter order etc). > > For what its worth, we stay away from malloc( ) and use our own memory > allocation functions that can allocate memory from a number of different > static heaps as well as enforce address alignment for use with circular > buffers. The start address and size of the heaps are automatically > determined at the link process so that all possible memory within a device > is available for use.
Thanks for that broader view. I always like expanding my horizons. Jerry -- Engineering is the art of making what you want from things you can get. &#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;
On Thu, 06 Jan 2005 09:19:23 -0500, Jerry Avins <jya@ieee.org> wrote:
>> I was thinking about systems with several sources of differeent sized >> tasks with different priorities, say a conferencing controller with >> different protocols on incoming calls. Mallocing dynamic buffers by the >> call handler might be the easiest way to contain all of the call >> variable stuff in one module. > >Malloc isn't guaranteed to return a valid pointer; it can fail. To my >simple mind, if there's enough memory so that malloc is sure to succeed, >you don't need it.
;-) I can understand your way of thinking Jerry... at some point I've seen some documents from TI about configuring DSP/BIOS for "static systems" - there was also somethign about "dynamic systems" - I never investigated the latter - however I do believe there are applications that require use of malloc/free (sorry - for my mistakes before when I wrote malloc/delete ;-))
Jerry Avins <jya@ieee.org> writes:
> [...] > I've written programs that PUSHed a whole bunch of constants, then > executed the stack. Some people have trouble believing it, but as > far as memory is concerned, there's no difference in structure > between code and text.
(Did you mean "code and data"?) There is in some processors, Jerry - especially DSPs. Code space and data space are separate address spaces, in general. At least on the TI TMS32054x they are. (There are some exceptions, but let's not get hung up in the details.) -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
Randy Yates wrote:
> Jerry Avins <jya@ieee.org> writes: > >>[...] >>I've written programs that PUSHed a whole bunch of constants, then >>executed the stack. Some people have trouble believing it, but as >>far as memory is concerned, there's no difference in structure >>between code and text. > > > (Did you mean "code and data"?)
I was trying for high contrast. I had in mind the guy with the new CS Masters who asked me how hardware distinguishes between numbers and ASCII and dismissed me as woefully ignorant when I told him that it doesn't.
> There is in some processors, Jerry - especially DSPs. Code space > and data space are separate address spaces, in general. At least > on the TI TMS32054x they are. (There are some exceptions, but > let's not get hung up in the details.)
There are some processors that are strictly Harvard, some with flat memory, and some with multiple banks each with its own bus where the banks are general purpose. The 6502 has a pin that asserts "instruction fetch" that can be used as a 17th address bit to overlay ROM and RAM. You use the processor you have, and in most cases, code for that one alone. Jerry -- Engineering is the art of making what you want from things you can get. &#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;
>>>>> "Jerry" == Jerry Avins <jya@ieee.org> writes:
Jerry> Stephen Maudsley wrote: Jerry> ... >> I was thinking about systems with several sources of differeent sized >> tasks with different priorities, say a conferencing controller with >> different protocols on incoming calls. Mallocing dynamic buffers by the >> call handler might be the easiest way to contain all of the call >> variable stuff in one module. Jerry> Malloc isn't guaranteed to return a valid pointer; it can fail. To my Jerry> simple mind, if there's enough memory so that malloc is sure to succeed, Jerry> you don't need it. To complicate things even further, even if there is enough memory available, malloc can still fail because the malloc heap has become fragmented and can't satisfy the request, because there's not block large enough. I bet the use of malloc in embedded systems is mostly a convenience. Sometimes necessary, of course, when your embedded system is very complex, like a cell phone with all kinds of apps. It would be hard to allocate all the memory upfront and recycle manually. Ray
Jerry Avins wrote:
(snip)
> There are some processors that are strictly Harvard, some with flat > memory, and some with multiple banks each with its own bus where the > banks are general purpose. The 6502 has a pin that asserts "instruction > fetch" that can be used as a 17th address bit to overlay ROM and RAM. > You use the processor you have, and in most cases, code for that one alone.
The 8086 had pins to decode the segment externally, you you could have two extra address bits. Code segment, stack segment, data segment, and extra segment could each have its own address space. Though code in ROM everything else in RAM probably makes more sense. I don't know if this is still there on later processors. -- glen
Jerry Avins wrote:
> glen herrmannsfeldt wrote:
-- snip --
>>Consider a laser printer, a nice dedicated system that does the same >>thing all day long. Many printers allow one to add additional RAM. >>At power up it determines the available RAM and allocates it >>accordingly. Once allocated it might never be free()d. The code >>will be more readable calling a routine called malloc() (or any other >>name one would like). It could be done other ways, but the code >>would be much less readable. >> >>Postscript does do dynamic allocation. A routine called malloc() may >>or may not be a good way to do it in a Postscript (or compatible) >>printer. >> >>For the most part, I agree with you, but I think there are some exceptions. > > > Thanks; that makes good sense. Notice, though, that with the possibility > of expansion memory, the resources are not known at coding time. > > Jerry
This also applies to the situation where I feel comfortable for using malloc(): in library code where free() will never be called. I've even implemented assign-only heaps to support this. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
