Hi, I tried to record an audio signal by speaking into a microphone using the audiorecorder object in Matlab 6.5. But the output was absolutely illegible,and was noisy. I tried the same thing with Microsoft Sound recorder and the signal was clear. Do I need to do some conditioning before using the audiorecorder object's output????
Audiorecorder in Matlab.....
Started by ●January 16, 2005
Reply by ●January 16, 20052005-01-16
in article 1105882512.577622.179600@c13g2000cwb.googlegroups.com, P L U M ! at karthik.ravikanti@gmail.com wrote on 01/16/2005 08:35:> I tried to record an audio signal by speaking into a microphone using > the audiorecorder object in Matlab 6.5. > But the output was absolutely illegible,and was noisy. > I tried the same thing with Microsoft Sound recorder and the signal was > clear. > Do I need to do some conditioning before using the audiorecorder > object's output????dunno MATLAB v 6.5, but you should be able to open your recorded .wav files with MATLAB, but that might be an additional inconvenient step. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●January 17, 20052005-01-17
yeah, i could open the recorded wav file using wavread().....but cant I record a clear audio signal directly into Matlab?
P L U M ! wrote:> Hi, > I tried to record an audio signal by speaking into a microphone using > the audiorecorder object in Matlab 6.5. > But the output was absolutely illegible,and was noisy. > I tried the same thing with Microsoft Sound recorder and the signal was > clear. > Do I need to do some conditioning before using the audiorecorder > object's output???? >Presuming you used same parameters (Fs, NBITS, NCHANS), I guess it may be caused by the recording volume. -- Song /* E-mail.c */ #define User "Yu.Song" #define At '@' #define Warwick "warwick.ac.uk" int main() { printf("Yu Song's E-mail: %s%c%s", User, At, Warwick); return 0;} Further Info. : http://www.dcs.warwick.ac.uk/~esubbn/ _______________________________________________________
