Tony wrote: ...> So Octave is more compatible with Matlab scripts than SciLab? What > about other compatibilities? Ease of use? Results? Speed? > > I too need to get up to speed with a free or low cost option > (Matlab is out of the question), so I'd really like to know the > limitations of SciLab, Octave and any other alternatives out > there. > > Tony (remove the "_" to reply by email)I didn' try Octave. I like Matlab, because it provides a lot of toolboxes and blocksets, which helps when first approaching new stuff. Simulink provides even automatic generation of VHDL code, and it really works! When it comes to precision of calculation, I found SciLab to be superior. Scripts are very similar - I indeed created scripts which run in both worlds (with some if matlab then ... else ... constructs). If your budget is low, use Scilab instead of Matlab. If you need special features, buy Matlab/Simulink, but benefit of your Scilab in parallel! Bernhard
IIR filter frequency response
Started by ●September 9, 2004
Reply by ●September 13, 20042004-09-13
