Rune Allnor wrote:> Ouch! That leaves me out. I know I've seen my father's slide rule > in a box where he keeps his old stuff, but I never saw it used. > > Rune >Time spent playing with a slide rule is time well spent. This page has some PDF's of paper slide rules. http://chris.gillings.com/collect/slide/index.html You can download them, print them, cut them out, assemble them, and then use them. There are hundreds of websites with slide rule tutorials. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Quidquid latine dictum sit, altum sonatur. Whatever is said in Latin sounds profound.
Understanding inverse FFT results
Started by ●February 7, 2005
Reply by ●February 9, 20052005-02-09
Rune Allnor wrote: ...> Ouch! That leaves me out. I know I've seen my father's slide rule > in a box where he keeps his old stuff, but I never saw it used.It is simple and elegant. What's more, there are some startlingly elegant procedures you can learn that will make you feel smug. For example, calculating sqrt(a^2 + b^2) and phase angle with one push of the stick and one alignment of the cursor. I can teach you how to use one and to do that trick even by email if you like. (You need trig scaled to do trig. Duh!) My large Dietzgen rule is a "Maniphase Multiplex (Log Log Vector)". The Keuffel and Esser equivalent is a "Log Log Duplex Vector", the archtypical engineering rule in my time. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> Rune Allnor wrote: > > ... > > >>Ouch! That leaves me out. I know I've seen my father's slide rule >>in a box where he keeps his old stuff, but I never saw it used. > > > It is simple and elegant. What's more, there are some startlingly > elegant procedures you can learn that will make you feel smug. For > example, calculating sqrt(a^2 + b^2) and phase angle with one push of > the stick and one alignment of the cursor.One push after an initial set-up. I could argue that that's two pushes. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Jim Thomas" <jthomas@bittware.com> wrote in message news:110k88lpnotvr1b@corp.supernews.com...> Rune Allnor wrote: > > Ouch! That leaves me out. I know I've seen my father's slide rule > > in a box where he keeps his old stuff, but I never saw it used. > > > > Rune > > > > Time spent playing with a slide rule is time well spent. This page has > some PDF's of paper slide rules. > > http://chris.gillings.com/collect/slide/index.htmlFYI, fred harris is a collector of old slide rules. So if you have a rare piece he might be interested in chatting with you. Cheers Bhaskar
