we are simply trying to modify nlms algorithm to cancel nonlinear echo on top of linear echo. What we don't understand is how to create a sound file with nonlinear properties. I don't know if it makes a lot of sense.. but we can't really design the filter unless we know how a nonlinear echo in equation form looks like or how to produce such a thing in matlab. Will simply delaying the original signal and adding it to the new signal qualify as a nonlinear echo? This message was sent using the Comp.DSP web interface on www.DSPRelated.com
how to simulate NONLINEAR echo in matlab
Started by ●February 22, 2005
Reply by ●February 24, 20052005-02-24
"RUMMY" <rpj616@yahoo.com> wrote in message news:TKOdneZu1YBnj4PfRVn-tA@giganews.com...> we are simply trying to modify nlms algorithm to cancel nonlinear echo on > top of linear echo. What we don't understand is how to create a sound file > with nonlinear properties. I don't know if it makes a lot of sense.. but we > can't really design the filter unless we know how a nonlinear echo in > equation form looks like or how to produce such a thing in matlab. Will > simply delaying the original signal and adding it to the new signal > qualify as a nonlinear echo?No, that is a linear echo. What TYPE of non-linearity do you want to simulate/cancel? As I mentioned in a previous post, saying it is non-linear is not specific enough. You are only saying what the signal is NOT, rather than what it IS. Steve mentioned low-level distortion due companding as a non-linear process. Others would be clipping/overload, frequency shift, full-wave rectification, etc..
>"RUMMY" <rpj616@yahoo.com> wrote in message >news:TKOdneZu1YBnj4PfRVn-tA@giganews.com... >> we are simply trying to modify nlms algorithm to cancel nonlinear echoon>> top of linear echo. What we don't understand is how to create a soundfile>> with nonlinear properties. I don't know if it makes a lot of sense..but we>> can't really design the filter unless we know how a nonlinear echo in >> equation form looks like or how to produce such a thing in matlab.Will>> simply delaying the original signal and adding it to the new signal >> qualify as a nonlinear echo? > >No, that is a linear echo. What TYPE of non-linearity do you want to >simulate/cancel? As I mentioned in a previous post, saying it isnon-linear is>not specific enough. You are only saying what the signal is NOT, ratherthan>what it IS. Steve mentioned low-level distortion due companding as anon-linear>process. Others would be clipping/overload, frequency shift, full-wave >rectification, etc.. > > >We are trying to simulate it for handsfree telephone systems. What types of nonlinearities can you encounter in this situation and how to do you model them in matlab? Please help. Thanks. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
"RUMMY" <rpj616@yahoo.com> wrote in message news:Oo6dnSGc15V7vYPfRVn-vg@giganews.com...> >"RUMMY" <rpj616@yahoo.com> wrote in message > >news:TKOdneZu1YBnj4PfRVn-tA@giganews.com... > >> we are simply trying to modify nlms algorithm to cancel nonlinear echo > on > >> top of linear echo. What we don't understand is how to create a sound > file > >> with nonlinear properties. I don't know if it makes a lot of sense.. > but we > >> can't really design the filter unless we know how a nonlinear echo in > >> equation form looks like or how to produce such a thing in matlab. > Will > >> simply delaying the original signal and adding it to the new signal > >> qualify as a nonlinear echo? > > > >No, that is a linear echo. What TYPE of non-linearity do you want to > >simulate/cancel? As I mentioned in a previous post, saying it is > non-linear is > >not specific enough. You are only saying what the signal is NOT, rather > than > >what it IS. Steve mentioned low-level distortion due companding as a > non-linear > >process. Others would be clipping/overload, frequency shift, full-wave > >rectification, etc.. > > > We are trying to simulate it for handsfree telephone systems. What types > of nonlinearities can you encounter in this situation and how to do you > model them in matlab? Please help. Thanks.Great, that is very useful additional information. Steve Underwood's earlier post had some info on this (low-level distortion from a-law and u-law compression). An easy way to simulate that would be actually implement the compression/expansion. Maybe there is an easy way to do that in Matlab? More generally, you could apply an arbitrary transfer function to the audio. Start with a perfect linear transfer function, then modify as you see fit. A common distortion would be that the gain tends to be reduced at high levels (overload distortion) and the output is limited to a maximum fixed value.
Reply by ●March 2, 20052005-03-02
>"RUMMY" <rpj616@yahoo.com> wrote in message >news:Oo6dnSGc15V7vYPfRVn-vg@giganews.com... >> >"RUMMY" <rpj616@yahoo.com> wrote in message >> >news:TKOdneZu1YBnj4PfRVn-tA@giganews.com... >> >> we are simply trying to modify nlms algorithm to cancel nonlinearecho>> on >> >> top of linear echo. What we don't understand is how to create asound>> file >> >> with nonlinear properties. I don't know if it makes a lot ofsense..>> but we >> >> can't really design the filter unless we know how a nonlinear echoin>> >> equation form looks like or how to produce such a thing in matlab. >> Will >> >> simply delaying the original signal and adding it to the new signal >> >> qualify as a nonlinear echo? >> > >> >No, that is a linear echo. What TYPE of non-linearity do you want to >> >simulate/cancel? As I mentioned in a previous post, saying it is >> non-linear is >> >not specific enough. You are only saying what the signal is NOT,rather>> than >> >what it IS. Steve mentioned low-level distortion due companding as a >> non-linear >> >process. Others would be clipping/overload, frequency shift,full-wave>> >rectification, etc.. >> > >> We are trying to simulate it for handsfree telephone systems. Whattypes>> of nonlinearities can you encounter in this situation and how to doyou>> model them in matlab? Please help. Thanks. > >Great, that is very useful additional information. Steve Underwood'searlier>post had some info on this (low-level distortion from a-law and u-law >compression). An easy way to simulate that would be actually implementthe>compression/expansion. Maybe there is an easy way to do that in Matlab?More>generally, you could apply an arbitrary transfer function to the audio.Start>with a perfect linear transfer function, then modify as you see fit. Acommon>distortion would be that the gain tends to be reduced at high levels(overload>distortion) and the output is limited to a maximum fixed value. > > >how do i go about simulating that in matlab? i tried recording my voice. Then what? how do i add a nonlinear component to it so i can design my nlms to cancel the nonlinear portion of the input signal This message was sent using the Comp.DSP web interface on www.DSPRelated.com
