Hi all, I have what should be a simple request that I can't seem to find the answer to. In TI 54x assembler, is there an instruction to copy a value directly from either the T or ASM registers to the A/B accumulator registers? My motivation is that fixed point math frequently requires a shift value to be calculated in the A or B accumulators (I dont believe T or ASM can do arithmetic). Once the shift value is calculated in A or B, I believe it needs to be copied to the T or ASM registers in order for the shift to be applied, for example using 'NORM A' or 'LD A, ASM, A' respectively. However I can not find a single instruction method of moving the shift value from A or B to T or ASM in 54x assembly. My current solution is to use the stack as an intermediate storage location, for example: (shift value has been calculated in B) STL B, *sp(temp) LD *sp(temp), ASM but this feels inefficient and dirty. Help clean my code up! Regards, Nick
TI 54x Assembler - Is it possible to move between T/ASM and A/B registers
Started by ●February 22, 2005
Reply by ●February 22, 20052005-02-22
I have just found a solution, although I still think its a bit of a hack. Absolute addressing can be used to address a memory mapped register, therefore allowing a register such as T or ASM to be used as a Smem parameter. For example LD T, B does not work because T is not a Smem address But LD *(0Eh), B does work because *(0Eh) is a Smem address that points to the memory mapped location of the T register (see SPRU131G pg 3-27). This still feels a bit dirty to me, but at least it is just one instruction. Is there a better method? Regards, Nick
Reply by ●February 24, 20052005-02-24
Look at the MVMM instruction (Move Memory Mapped Register) (or similarly the MVDK, MVDM ) I think one of these will do what you need. Just be careful of pipeline latencies. Going from A or B into T is straight forward: STLM A,T ; T=x MPY y,A ; A=x*y Hope this helps -Shawn <npelly@gmail.com> wrote in message news:1109121040.475930.89540@f14g2000cwb.googlegroups.com...> Hi all, > > I have what should be a simple request that I can't seem to find the > answer to. > > In TI 54x assembler, is there an instruction to copy a value directly > from either the T or ASM registers to the A/B accumulator registers? > > My motivation is that fixed point math frequently requires a shift > value to be calculated in the A or B accumulators (I dont believe T or > ASM can do arithmetic). Once the shift value is calculated in A or B, I > believe it needs to be copied to the T or ASM registers in order for > the shift to be applied, for example using 'NORM A' or 'LD A, ASM, A' > respectively. > > However I can not find a single instruction method of moving the shift > value from A or B to T or ASM in 54x assembly. > > My current solution is to use the stack as an intermediate storage > location, for example: > (shift value has been calculated in B) > STL B, *sp(temp) > LD *sp(temp), ASM > > but this feels inefficient and dirty. > > Help clean my code up! > > Regards, > > Nick >
