Hi, I'm trying to write my first signal detection algorithm in Matlab... but it's been several years since I've done any DSP... so it's slow going. if anyone has a little free-time, can you look at this and see if you can spot what I'm doing wrong? the data files can be acquired here: http://www.podoboq.com/podoboq/basic_detect.zip the two examples are simple (Class 1 - everything known a priori) versions of what I am trying to do. Unfortunately, I only have 299 data points to work with, and a sampling rate of 1Hz (Nyquist == 0.5Hz). I am using a Wiener estimation filter for pre-processing, and for the detection I am using an uncorrelated Wiener-style high-resolution detection filter. "run_me1.m" uses a single sine pulse centered at 100 seconds for the signal I'm trying to detect, and "run_me2.m" has two sine pulses, one centered at 100 seconds and the other centered at 250 seconds. I'm not sure if I'm making a DSP-related error or just an error in the way I'm manipulating the data in Matlab, but it doesn't seem to work. after the estimation phase, you can see the pulse coming out at 100 seconds, but then the final output seems like garbage. Aren't you supposed to get a narrow impulse at each place where a detection occurs??? What about SNR? In this case the ratio is 1:1. Do I need to RMS-normalize something before filtering? I've experimented with all sorts of things, but maybe I'm just forgetting something dumb! I'd hugely appreciate any help. thnx!!! -ColdCold
DSP: basic signal detection in Matlab (help!) :)
Started by ●March 2, 2005
Reply by ●March 3, 20052005-03-03
boo hoo... I'm sure some of you must be detection whizzes.. yes? no? radar anyone? this problem is super-basic, but I'm stuck. Can somebody just download the m-files (http://www.podoboq.com/podoboq/basic_detect.zip) and take a look at my transfer functions? If it's a DSP-related error, I would expect it to be there somewhere. Any feedback would be greatly appreciated. -ColdCold
