Hello, I am starting with a C54CST, I get the corresponding evalutation board C54CST EVM wihtout JTAG. I have some example given by SPIRIT the company which produced the algorithms included inside the DSP. I manage to use the flex examples applications using only a thread. However I can't used those with BIOS included. It starts the emulation via JTAG. When I load the program by UART, It doesn't work, althought the same code runs without DSP/BIOS tools. Is someone meet the problem and How can I resolve it while I don't have A JTAG? Thank You, Guenael. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Starting With DSP/BIOS : lost
Started by ●March 3, 2005
Reply by ●March 7, 20052005-03-07
"Gwen" <g.anne@intervox.fr> wrote in message news:<O6KdnXsJrbaTWLvfRVn-pA@giganews.com>...> Hello, > > I am starting with a C54CST, I get the corresponding evalutation board > C54CST EVM wihtout JTAG. I have some example given by SPIRIT the company > which produced the algorithms included inside the DSP. > > I manage to use the flex examples applications using only a thread. > However I can't used those with BIOS included. It starts the emulation via > JTAG. > > When I load the program by UART, It doesn't work, althought the same code > runs without DSP/BIOS tools. > > Is someone meet the problem and How can I resolve it while I don't have A > JTAG? > > Thank You, > > Guenael. > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.comHi Actually I am not work on the board which you have, I am working on TMS320C6711 DSK. I have seen that the data can be send through the printer port to communicate PC and DSP, using RTDX communication channel, (HST and RTDX ..) so data should be passed through any device and DSP with out JTAG, although JTAG can give you a very good debuging facility. bye Dibyendu Mondal
