Hello, for my project I've bought the Spectrum Digital board with the TMS320F2812 DSP. I have chosen it because it has A/D converters and PWM units on board. Yesterday I met a man from a company in Germany and he told me that the converters of the processor are very bad. He would measure the DC signal, and what he got was something that from 12-bit signal only 7 bits were stable. He said that although the signal was taken from the voltage generator and was really stable DC signal, the output from A/D converters was "changing", the 5 bits were constantly changing. He said, that he had to use external A/D converters and now he doesn't have this problem. Have you seen this before? Do you possibly know where it could come from? Or it is like this with this processor? Greetings, Pawel
eZdsp with TMS320F2812 - A/D converters
Started by ●March 5, 2005
Reply by ●March 5, 20052005-03-05
Pawel Szczupak wrote:> Hello, > for my project I've bought the Spectrum Digital board with the > TMS320F2812 DSP. I have chosen it because it has A/D converters andPWM> units on board. Yesterday I met a man from a company in Germany andhe> told me that the converters of the processor are very bad. He would > measure the DC signal, and what he got was something that from 12-bit> signal only 7 bits were stable. He said that although the signal was > taken from the voltage generator and was really stable DC signal, the> output from A/D converters was "changing", the 5 bits were constantly> changing. He said, that he had to use external A/D converters and nowhe> doesn't have this problem. > > Have you seen this before? Do you possibly know where it could come > from? Or it is like this with this processor? > > Greetings, > PawelTI states the typical effective number of bits for the 2812 A/D is 10.1 bits (S/N 62dB), thats typical, min could be much worse, its not stated in the datasheet I've read. Add to that noise of external reference (if used) plus various other external noise sources and I can see getting only 7 stable bits. The performance of the A/D's that go into DSPs depends not only on the A/D itself, but where it placed relative to the core. The same A/D used in different DSP's can have a wide range of performance. They also tend to have "sweet spots", that is clock frequency multiples of the core clock where performance is the highest, some manufacturers will state these clock frequencies in the datasheets. Also the best material to make a DSP core is not the best material to make a high performance A/D, and vice versa, so putting both on one die is a compromise. So yes an external A/D is going to have much higher performance as compared to an internal A/D for the above reasons. The TI A/D is pretty fast so you could oversample/average to increase your effective number of bits.
On Sat, 05 Mar 2005 10:48:57 +0100, Pawel Szczupak <pawl6@OHNESPAM.op.pl> wrote in comp.dsp:> Hello, > for my project I've bought the Spectrum Digital board with the > TMS320F2812 DSP. I have chosen it because it has A/D converters and PWM > units on board. Yesterday I met a man from a company in Germany and he > told me that the converters of the processor are very bad. He would > measure the DC signal, and what he got was something that from 12-bit > signal only 7 bits were stable. He said that although the signal was > taken from the voltage generator and was really stable DC signal, the > output from A/D converters was "changing", the 5 bits were constantly > changing. He said, that he had to use external A/D converters and now he > doesn't have this problem. > > Have you seen this before? Do you possibly know where it could come > from? Or it is like this with this processor? > > Greetings, > PawelWhat you have been told is pretty much true. Consult the latest errata documents for the 2812 from TI's web site. There are some possibilities to improve the operation. One involves using two channels for references, inputting 0.5 volts to one and 2.5 volts to the other, and performing a software calculation to use in adjusting or correcting the readings of the other 14 channels. We are using this one. The other is to provide your own external reference voltage to the ADC. The newest versions of the chip allow you to do so on two pins. We have not tried this one. Consult the TI errata documentation and contact TI for app notes. -- Jack Klein Home: http://JK-Technology.Com FAQs for comp.lang.c http://www.eskimo.com/~scs/C-faq/top.html comp.lang.c++ http://www.parashift.com/c++-faq-lite/ alt.comp.lang.learn.c-c++ http://www.contrib.andrew.cmu.edu/~ajo/docs/FAQ-acllc.html
Reply by ●March 6, 20052005-03-06
> One involves using two channels for references, inputting 0.5 volts to > one and 2.5 volts to the other, and performing a software calculation > to use in adjusting or correcting the readings of the other 14 > channels. We are using this one. > > The other is to provide your own external reference voltage to the > ADC. The newest versions of the chip allow you to do so on two pins. > We have not tried this one. >Hello, Thank you both for answers. I will check the methods. As you told, there is a pin for external reference voltage. I am going to try it :) Greetings, Pawel
