Hi! Have someone programier a fir filter for this ADSP-21161 EZ-Kit and for 96kHz sample rate? I am new in the DSP world. Have someone worked with the ADSP-21161 EZ-Kit? I need to program a correlation. That�s mean a matched filter, als a fir filter? I need 96kHz sample rate for the AD. That�s mean I2S mode but there is not a lot of examples for I2S mode configuration. I need Help!!! Thanks and regards, Flavia
HELP with ADSP-21161 Ez-Kit !!!
Started by ●March 8, 2005
Reply by ●March 9, 20052005-03-09
Hello, What are the problems you are experiencing? What have you done so far? -- ------------------------------ Jaime Andr�s Aranguren Cardona jaac@sanjaac.com SanJaaC Electronics Soluciones en DSP www.sanjaac.com "Flavia" <flavia_rafols@yahoo.es> escribi� en el mensaje news:d2006f11.0503080744.5c8f0036@posting.google.com...> Hi! > > Have someone programier a fir filter for this ADSP-21161 EZ-Kit and > for 96kHz sample rate? > > I am new in the DSP world. > Have someone worked with the ADSP-21161 EZ-Kit? > I need to program a correlation. That�s mean a matched filter, als a > fir filter? > I need 96kHz sample rate for the AD. That�s mean I2S mode but there is > not a lot of examples for I2S mode configuration. > > I need Help!!! > > Thanks and regards, > Flavia
Flavia wrote:> Hi! > > Have someone programier a fir filter for this ADSP-21161 EZ-Kit and > for 96kHz sample rate? > > I am new in the DSP world. > Have someone worked with the ADSP-21161 EZ-Kit? > I need to program a correlation. That�s mean a matched filter, als a > fir filter? > I need 96kHz sample rate for the AD. That�s mean I2S mode but there is > not a lot of examples for I2S mode configuration. > > I need Help!!! >Try Analog Devices online documentation : http://www.analog.com/processors/resources/beginnersGuide/index.html
Hola! Creo que mejor te hablo en espanol. Problemas? todos. De momento creo que ya he conseguido que est� todo en I2S mode para 96kHz sample rate. Configur� los registros del AD y los de los puertos 0 y 2. Aunque a�n no lo tengo muy claro. C�mo puedo estar segura de que est� muestreando a 96kHz? Y de todas formas no voy poder sacar nada porque el clock y el framsync del puerto 2 no est�n unidos a nada. Pero lo que quiero es el resultado de la correlaci�n que calcula el DSP (como una chirp signal)plotearlo con el VisualDSP, vamos que no necesito volver a pasarlo por el DA. Y los puertos 1 y 3 los uso para configurar el AD1836. Ahora estoy intentando recoger las muestras que meto por una de los conectores de entrada en un buffer para al plotear con el VisualDSP poder ver la senal. Pero de momento sin mucho �xito.He tratado de hacer �sto en la rutina de recepcion de muestras: b0 = _input_fir; l0 = @_input_fir; m0 = 1; r0 = dm(_rx0a_buf + Internal_ADC_L0); f0 = float r0 by r1; dm(_Left_Channel_In0) = r0; r2 = dm(_Left_Channel_In0); dm(i0,m0) = r2; r0 = dm(_rx0a_buf + Internal_ADC_L0); f0 = float r0 by r1; dm(_Left_Channel_In0) = r0; r2 = dm(_Left_Channel_In0); dm(i0,m0) = r2; r0 = dm(_rx0a_buf + Internal_ADC_L0); f0 = float r0 by r1; dm(_Left_Channel_In0) = r0; r2 = dm(_Left_Channel_In0); dm(i0,m0) = r2; para ver c�mo entran 3 muestras a mi buffer, pero s�lo si lo ejecuto paso a paso veo las 3 muestras diferentes, si lo dejo correr me guarda 3 muestras iguales. Y si trato de hacer un loop por ejemplo para guardar en mi buffer 200 muestras: me las guarda pero una encima de la otra, o sea que al final s�lo veo la �ltima. �sto del buffer es para luego pasar un bloque de muestras a la funcion fir en c que viene en la librer�a pero que s�lo trabaja con bloques de muestras. Alguna idea? Saludos y gracias, Flavia --------------------------------------------------------------------------- "Jaime Andr�s Aranguren Cardona" <jaac@nospam.sanjaac.com> wrote in message news:<1110349558.2eb15d1f413a4935df551aa8d7061f85@teranews>...> Hello, > > What are the problems you are experiencing? What have you done so far? > > -- > ------------------------------ > Jaime Andr�s Aranguren Cardona > jaac@sanjaac.com > SanJaaC Electronics > Soluciones en DSP > www.sanjaac.com > > > "Flavia" <flavia_rafols@yahoo.es> escribi� en el mensaje > news:d2006f11.0503080744.5c8f0036@posting.google.com... > > Hi! > > > > Have someone programier a fir filter for this ADSP-21161 EZ-Kit and > > for 96kHz sample rate? > > > > I am new in the DSP world. > > Have someone worked with the ADSP-21161 EZ-Kit? > > I need to program a correlation. That�s mean a matched filter, als a > > fir filter? > > I need 96kHz sample rate for the AD. That�s mean I2S mode but there is > > not a lot of examples for I2S mode configuration. > > > > I need Help!!! > > > > Thanks and regards, > > Flavia
