"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in news:BsmdnVyx0LZHkqbfRVn-tA@centurytel.net:> > "Tom Cantwell" <NoWay@nope.com> wrote in message<snip>>> Tom, > > That's interesting. I was in San Diego and worked with Dave > Princehouse, (who was at APL along with Sienkiewicz, Haugen et al) > in writing the paper I mention above. We implemented the first > "production" version or REVGEN in San Diego using Floating Point > Systems AP-120B(?) array processors. Ten of them as I recall. So, > I was interested in efficient computing because that was a lot of > hardware! > > One of my thoughts was to change the range-Doppler map > implementation as follows: > > As you know, the range-Doppler map was split up into cells or > elements that represented range (time) and look angle. The > contents of the R-D map had to be computed completely on the fly > due to platform dynamics (changing velocity vector direction and > beam patterns). It was a lot of computing because there needs to > be a new map computed (a 2-D matrix) for each time sample of each > of the receiver data streams. > > I have an idea that would reduce the processing load per R-D cell > per time sample. Probably by greater than a factor of 2. I never > got around to working on this idea. I wonder if it still might > make sense? I'd be interested in working on it if there's still an > application - and it sounds like there is.... > > Fred >--- Yeah, spent many hours at NOSC/NRAD/what_ever_it_is_now using the real- time "hybrid simulator" with an ADCAP torpedo panel in the loop. We shared the facility with the people working on the Mark 46/50 upgrades. Dr. Robert Goddard of APL would probably be interested in communicating with you re: increasing the speed of the SST. I'll send you his email addy when I get to work later today. Tom
Need suggestions for literature: Radar/Sonar pulse design
Started by ●March 11, 2005
Reply by ●March 30, 20052005-03-30
"Tom Cantwell" <NoWay@nope.com> wrote in message news:Xns96295C54A2341NoWaynope@129.250.170.86...> "Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in> --- > Yeah, spent many hours at NOSC/NRAD/what_ever_it_is_now using the real- > time "hybrid simulator" with an ADCAP torpedo panel in the loop. We > shared the facility with the people working on the Mark 46/50 upgrades. >Tom, I was there managing the advanced lightweight project which funded the simulator upgrade. (The advanced lightweight became the MK50). I left to go to DC in '78. Both ADCAP and MK50 continued well after that of course. Maybe we crossed paths... ? I actually started my engineering career working on the hybrid simulator when it was a UNIVAC 1108 plus a couple of the largest analog computers in existence at the time - in Pasadena, CA which was a Navy / Caltech lab. We moved / merged the lab in San Diego in '73. Fred
