If a band-limited white noise source is mixed with a non-delayed version of itself in a down-conversion process, is the noise cancelled? If the noise is mixed with a version of itself, which is time delayed by greater than a 1/BW, is the noise power out of the mixer 2x one of the noise sources? I modelled this process in matalb and dont get the expected result. Thanks. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Mixing correlated, band-limited Noise
Started by ●March 11, 2005
Reply by ●March 12, 20052005-03-12
JohnnyM wrote:> If a band-limited white noise source is mixed with a non-delayedversion of> itself in a down-conversion process, is the noise cancelled? If thenoise> is mixed with a version of itself, which is time delayed by greaterthan a> 1/BW, is the noise power out of the mixer 2x one of the noisesources? I> modelled this process in matalb and dont get the expected result. > Thanks. > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.comAre you using the term "mix" like the audio guys as in ADD or like the RF guys as in MULTIPLY? Mark
> >JohnnyM wrote: >> If a band-limited white noise source is mixed with a non-delayed >version of >> itself in a down-conversion process, is the noise cancelled? If the >noise >> is mixed with a version of itself, which is time delayed by greater >than a >> 1/BW, is the noise power out of the mixer 2x one of the noise >sources? I >> modelled this process in matalb and dont get the expected result. >> Thanks. >> >> This message was sent using the Comp.DSP web interface on >> www.DSPRelated.com > >Are you using the term "mix" like the audio guys as in ADD or like the >RF guys as in MULTIPLY? > >Mark >Multiply-like the RF guys. My signals are complex and I am modelling the mixer as the sum of the straight product and the product of the signal times its complex conjugate. John>This message was sent using the Comp.DSP web interface on www.DSPRelated.com
JohnnyM wrote:>>JohnnyM wrote: >> >>>If a band-limited white noise source is mixed with a non-delayed >>>version of itself in a down-conversion process, is the noise >>>cancelled? If the noise is mixed with a version of itself, which >>>is time delayed by greater than a 1/BW, is the noise power out of >>>the mixer 2x one of the noise sources? I >> >>>modelled this process in matalb and dont get the expected result. >>>Thanks. >>> >>>This message was sent using the Comp.DSP web interface on >>>www.DSPRelated.com >> >>Are you using the term "mix" like the audio guys as in ADD or like the >>RF guys as in MULTIPLY? >> >>Mark >> > > Multiply-like the RF guys. My signals are complex and I am modelling the > mixer as the sum of the straight product and the product of the signal > times its complex conjugate. > John >No. Study up on random processes, on what happens when you square a zero-mean random process (i.e. your noise times itself) and what happens when you multiply two zero-mean random processes (i.e. your noise times its complex conjugate). -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
>JohnnyM wrote: > >>>JohnnyM wrote: >>> >>>>If a band-limited white noise source is mixed with a non-delayed >>>>version of itself in a down-conversion process, is the noise >>>>cancelled? If the noise is mixed with a version of itself, which >>>>is time delayed by greater than a 1/BW, is the noise power out of >>>>the mixer 2x one of the noise sources? I >>> >>>>modelled this process in matalb and dont get the expected result. >>>>Thanks. >>>> >>>>This message was sent using the Comp.DSP web interface on >>>>www.DSPRelated.com >>> >>>Are you using the term "mix" like the audio guys as in ADD or like the >>>RF guys as in MULTIPLY? >>> >>>Mark >>> >> >> Multiply-like the RF guys. My signals are complex and I am modellingthe>> mixer as the sum of the straight product and the product of the signal >> times its complex conjugate. >> John >> >No. Study up on random processes, on what happens when you square a >zero-mean random process (i.e. your noise times itself) and what happens>when you multiply two zero-mean random processes (i.e. your noise times >its complex conjugate). > >-- > >Tim Wescott >Wescott Design Services >http://www.wescottdesign.com >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
>JohnnyM wrote: > >>>JohnnyM wrote: >>> >>>>If a band-limited white noise source is mixed with a non-delayed >>>>version of itself in a down-conversion process, is the noise >>>>cancelled? If the noise is mixed with a version of itself, which >>>>is time delayed by greater than a 1/BW, is the noise power out of >>>>the mixer 2x one of the noise sources? I >>> >>>>modelled this process in matalb and dont get the expected result. >>>>Thanks. >>>> >>>>This message was sent using the Comp.DSP web interface on >>>>www.DSPRelated.com >>> >>>Are you using the term "mix" like the audio guys as in ADD or like the >>>RF guys as in MULTIPLY? >>> >>>Mark >>> >> >> Multiply-like the RF guys. My signals are complex and I am modellingthe>> mixer as the sum of the straight product and the product of the signal >> times its complex conjugate. >> John >> >No. Study up on random processes, on what happens when you square a >zero-mean random process (i.e. your noise times itself) and what happens>when you multiply two zero-mean random processes (i.e. your noise times >its complex conjugate). > >-- > >Tim Wescott >Wescott Design Services >http://www.wescottdesign.comI'll have to think about it. I took the above products to get the sum and difference frequencies produced by the mixing process - this works for detrministic signals, e.g., sin cos. If I think about this stochasically, the two products certainly dont give the same thing - you get x(n)= e^j(s(n)-s(n))+e^j(s(n)+s(n)), but is it incorrect? I would guess the autocorrelations of the two terms of x(n) should be the same if this is correct. For zero lag, the first term will gives what I expect (=1 for correlated signals), but the second term doesn't, so it seems something is wrong. What I am trying to to must have been done a thousand times before. Can anyone suggest a reference or approach? Thanks, John M. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
