processor choice for mpeg
Started by Unknown March 16, 2005
I'm starting to look at a home project for creating a stand alone
webcam server. What I'd like to do is have 3-4 usb inputs for webcams,
convert the inputs into mpeg and send the data out an ethernet port. I
want to be able to support real-time (or close to it) video processing
and run a web server in the box also, as well as a few other
housekeeping functions and bells and whistles. I'm looking at several
options for the processor: the ADI Blackfin, the ADI Sharc and the Arm
processor. I'm leaning towards the Blackfin most, but I'd like to know
if it has the processing power needed (being 16 bit fixed point, rather
than the Sharc 32 bit floating point) to handle 4 camera inputs.
I've done some work with DSPs before ( Freescale 56K series) so I'm not
too worried about dealing with any of the procesors I mentioned. I just
need some idea on handling the mpeg processing from multiple cam
inputs. Any comments or suggestions would be appreciated. Thanks.
Lee
Hi,
It seems to me that that Blackfin is the processor of choice for your
application. It's processing power is really high... do you really need 32
bit precision?
Blackfin has special instruction to efficiently handle video streams, maybe
you've seen that. Power consumption is low(-er than SHARC's)..
Regards,
Jaime Andr�s Aranguren Cardona
jaac@sanjaac.com
SanJaaC Electronics
Soluciones en DSP
www.sanjaac.com
<lee_t@bigfoot.com> escribi&#2013265923; en el mensaje
news:1110989529.303764.27990@f14g2000cwb.googlegroups.com...
> I'm starting to look at a home project for creating a stand alone > webcam server. What I'd like to do is have 3-4 usb inputs for webcams, > convert the inputs into mpeg and send the data out an ethernet port. I > want to be able to support real-time (or close to it) video processing > and run a web server in the box also, as well as a few other > housekeeping functions and bells and whistles. I'm looking at several > options for the processor: the ADI Blackfin, the ADI Sharc and the Arm > processor. I'm leaning towards the Blackfin most, but I'd like to know > if it has the processing power needed (being 16 bit fixed point, rather > > than the Sharc 32 bit floating point) to handle 4 camera inputs. > > > I've done some work with DSPs before ( Freescale 56K series) so I'm not > > too worried about dealing with any of the procesors I mentioned. I just > > need some idea on handling the mpeg processing from multiple cam > inputs. Any comments or suggestions would be appreciated. Thanks. > > > Lee >
