Hi guys/gals I'm new to DSP pogramming but am familiar to the high level concepts. I know how the output of a FIR filter is computed and how to generate the coeficients and tap count. I'm using ScopeFIR and have generated a 100 tap low pass filter. I have "quantized the coefficents to 16 bits because I'm planning to use this on the DsPic 30F6014. The 16bit A2D I'll be sampling outputs and outputting 0 for -10V input and FFFF for +10V The DsPic has C librarys that call for the coefficients to be in fraction format. I assume the A2D sample also need to be in a compatable format as well. What type of Coefficent export type out of ScopeFIR do I need to get the coefficents in the appropriate form for the DsPic C functions to be happy? Do I need to do some kind of transform to the A2D samples to get them into Fraction form as well? The output will be sent to a matching 16 bit DAQ (same +/- 10V) range and would like it to track the DC input to the A2D and reject the AC noise. AA filter is in place. :) thanks
New to DSP (FIR implementation help)
Started by ●March 17, 2005
Reply by ●March 17, 20052005-03-17
Mook Johnson wrote:> Hi guys/gals > > I'm new to DSP pogramming but am familiar to the high level concepts. I > know how the output of a FIR filter is computed and how to generate the > coeficients and tap count. > > I'm using ScopeFIR and have generated a 100 tap low pass filter. I have > "quantized the coefficents to 16 bits because I'm planning to use this on > the DsPic 30F6014. The 16bit A2D I'll be sampling outputs and outputting 0 > for -10V input and FFFF for +10V > > > The DsPic has C librarys that call for the coefficients to be in fraction > format. I assume the A2D sample also need to be in a compatable format as > well. > > What type of Coefficent export type out of ScopeFIR do I need to get the > coefficents in the appropriate form for the DsPic C functions to be happy? > > Do I need to do some kind of transform to the A2D samples to get them into > Fraction form as well? > > The output will be sent to a matching 16 bit DAQ (same +/- 10V) range and > would like it to track the DC input to the A2D and reject the AC noise. AA > filter is in place. :) > > thanks > >You will have to check your documentation from Microchip, but it is most likely that the fraction format is just a 2's complement number that is interpreted as a fraction -- i.e. instead of the LSB having a bit weight of 1 and the MSB (sign bit of a 16-bit number) having a bit weight of 32768 a fractional number that ranges from -1 (0x8000) to almost +1 (0xffff) will have a LSB bit weight of 1/32768 and a MSB (sign) bit weight of 1. Assuming this is correct then your ADC will have to have it's MSB reversed so -10V results in 0x8000 and +10V (well, 9.9997V) will result in 0x7fff, with 0V (0x8000 out of the ADC) will be 0x0000. I'm familiar with neither the ScopeFIR or the DsPIC, but I suspect that you just need to export the FIR coefficients as a vector of integers that range from -32768 to 32767 and make them into a C array. You should be able to just tell the DsPIC to interpret them as fractional. Assuming that the DAC format matches the ADC then you'll have to do the same sign bit inversion on the DAC as you did on the ADC. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●August 18, 20052005-08-18
>Hi guys/gals > >I'm new to DSP pogramming but am familiar to the high level concepts. I>know how the output of a FIR filter is computed and how to generate the >coeficients and tap count. > >I'm using ScopeFIR and have generated a 100 tap low pass filter. I have>"quantized the coefficents to 16 bits because I'm planning to use this on>the DsPic 30F6014. The 16bit A2D I'll be sampling outputs and outputting0>for -10V input and FFFF for +10V > > >The DsPic has C librarys that call for the coefficients to be in fraction>format. I assume the A2D sample also need to be in a compatable formatas>well. > >What type of Coefficent export type out of ScopeFIR do I need to get the>coefficents in the appropriate form for the DsPic C functions to behappy?> >Do I need to do some kind of transform to the A2D samples to get theminto>Fraction form as well? > >The output will be sent to a matching 16 bit DAQ (same +/- 10V) range and>would like it to track the DC input to the A2D and reject the AC noise.AA>filter is in place. :) > >thanks > > >ok here is what you do: I created a FIR as example I used a tool calleddsPIC FD lite for it: create this as .s file ; .............................................................................. ; File fir.s ; .............................................................................. .equ firNumTaps, 49 ; .............................................................................. ; Allocate and initialize filter taps .section .xdata,data,xmemory // see below .align 128 //this are the taps change as required firTaps: hword 0x01F9, 0x020C, 0x021E, 0x0230, 0x0241, 0x0252, 0x0262, 0x0271, 0x0280 hword 0x028E, 0x029C, 0x02A8, 0x02B4, 0x02BF, 0x02C9, 0x02D2, 0x02DA, 0x02E2 hword 0x02E8, 0x02ED, 0x02F2, 0x02F5, 0x02F8, 0x02F9, 0x02FA, 0x02F9, 0x02F8 hword 0x02F5, 0x02F2, 0x02ED, 0x02E8, 0x02E2, 0x02DA, 0x02D2, 0x02C9, 0x02BF hword 0x02B4, 0x02A8, 0x029C, 0x028E, 0x0280, 0x0271, 0x0262, 0x0252, 0x0241 hword 0x0230, 0x021E, 0x020C, 0x01F9 ; .............................................................................. ; Allocate delay line in (uninitialized) Y data space .section .ybss,bss,ymemory // see below .align 128 firDelay: .space firNumTaps*2 ; .............................................................................. ; Allocate and intialize filter structure .section .data .global _firFilter _firFilter: hword firNumTaps hword firTaps hword firTaps+firNumTaps*2-1 hword 0xff00 hword firDelay hword firDelay+firNumTaps*2-1 hword firDelay If you use the FD lite the bit I marked see below will be wrong change it as IK have done in here you also need an .h file #ifndef FIR_H #define FIR_H extern FIRFilterStructure firFilter; #endif /* FIR_H */ /* The following C-code fragment demonstrates how to call the filter routine #include "FIR_Filter.h" #include "fir.h" // NUM_SAMPLES defines the number of samples in one block of input data. // This value should be changed as needed for the application #define NUM_SAMPLES 100 { // Declare input and output sample arrays. int inSamples[NUM_SAMPLES], outSamples[NUM_SAMPLES]; // Call the FIRFilterInit routine to zero out the delay line FIRFilterInit( &firFilter ); // Call BlockFIRFilter for each block of input samples // This routine would normally be called inside a FOR or a DO-WHILE loop // Only one instance has been shown BlockFIRFilter( &firFilter, &inSamples, &outSamples, NUM_SAMPLES ); } */ which is also created by FD lite and it actually does explain the rest you have to do --- note that I called the filter "fir" (maybe not a good choice as it confuses things) so replace that with the name of your filter. That should do the trick This message was sent using the Comp.DSP web interface on www.DSPRelated.com
