What is the difference between FFT and IFFT?
Started by Sea Squid March 22, 2005
"Clay S. Turner" <Physics@Bellsouth.net> writes:
> There is a simple linear transformation between the Hartley and > Fourier transforms, so one doesn't really have any info the other > doesn't.
Hi Clay, I don't really mean to mince words here, but couldn't you say that the time domain "doesn't really have any info" the frequency domain doesn't, and vice-versa? After all, the FT is a linear transformation of the time domain. What I'm getting at is that, even though the HT may be isomorphic to the FT, it still might be a view of the signal that is useful for certain purposes that the FT doesn't provide. I dunno - maybe it's not useful. I certainly don't know of any reason to use it, but it would be shame to overlook some usefulness we haven't thought of. -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
"Randy Yates" <randy.yates@sonyericsson.com> wrote in message
news:xxpsm2jvka9.fsf@usrts005.corpusers.net...
> "Clay S. Turner" <Physics@Bellsouth.net> writes: >> [...] > >> There is a simple linear transformation between the Hartley and >> Fourier transforms, so one doesn't really have any info the other >> doesn't. > > Hi Clay, > > I don't really mean to mince words here, but couldn't you say that the > time domain "doesn't really have any info" the frequency domain > doesn't, and vice-versa? After all, the FT is a linear transformation > of the time domain. > > What I'm getting at is that, even though the HT may be isomorphic to > the FT, it still might be a view of the signal that is useful for > certain purposes that the FT doesn't provide. > > I dunno - maybe it's not useful. I certainly don't know of any reason > to use it, but it would be shame to overlook some usefulness we haven't > thought of. > --
Hello Randy, Certainly, the FT is a linear transform, but the freq. domain representation is at least enough different than the time domain presentation to be quite useful. The Hartley transform is so similar to the Fourier transform, that its differences are simply academic. For example a single sinusoid in the time domain gets mapped to a mix of plus and minus "frequencies". Actually the Hartley really only looks at positive frequencies and the phase info is distributed between the plus and minus frequency values. I.e., the plus frequency is the component of the signal along a +45 degree phase shifted sinusoid. and the minus frequency finds the orthogonal component along a -45 degree phase shifted sinusoid. For each frequency, both transforms perform projections onto a pair of orthogonal sinusoids. Clay
"bhooshaniyer" <bhooshaniyer@gmail.com> wrote in message
news:wsmdnQOZJbwmh93fRVn-qw@giganews.com...
> >I used to think the operations are the same? > > > >Thank you. > > > > Here is the equation for both forward and inverse transform: > (Iam not used to typing math equations in text files, but never the > less:) > > ---------------------------------------------- > FFT: > x(F)= summation( x(n)* exp[(-j*2*pi/N)kn] > --------- > 0->N-1 > > IFFT: > x(n)= 1/N * summation( x(n)* exp[(j*2*pi/N)kn] > --------- > 0->n-1 > ------------------------------------------------- >
Strictly speaking the direct FFT whould have the 1/N.Why? Well consider a pure dc signal, its FFT will be the average. Dr Tam
in article T1q1e.13096$1S4.1363995@news.xtra.co.nz, Dr Tam at
ProfTam@yahoo.co.nz wrote on 03/26/2005 22:48:
> > "bhooshaniyer" <bhooshaniyer@gmail.com> wrote in message > news:wsmdnQOZJbwmh93fRVn-qw@giganews.com... >>> I used to think the operations are the same? >>> >>> Thank you. >>> >> >> Here is the equation for both forward and inverse transform: >> (Iam not used to typing math equations in text files, but never the >> less:)
i fixed it a little.
>> >> FFT: >> X[k] = summation( x[n] * exp(-j*2*pi*k*n/N) >> --------- >> 0->N-1 >> >> IFFT: >> x[n] = 1/N * summation( X[k]* exp(+j*2*pi*k*n/N) >> --------- >> 0->N-1
> Strictly speaking the direct FFT whould have the 1/N. Why? Well consider a > pure dc signal, its FFT will be the average.
it's a matter of convention and, while i agree with your preference - i have the same, it's not the common convention in the literature and i finally got tired of having it corrected in anything i wrote. it would be nice if all the textbooks could be rewritten. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
bhooshaniyer wrote:
> >I used to think the operations are the same? > > > >Thank you. > > > > Here is the equation for both forward and inverse transform: > (Iam not used to typing math equations in text files, but never the > less:) > > ---------------------------------------------- > FFT: > x(F)= summation( x(n)* exp[(-j*2*pi/N)kn] > --------- > 0->N-1 > > IFFT: > x(n)= 1/N * summation( x(n)* exp[(j*2*pi/N)kn] > --------- > 0->n-1 > ------------------------------------------------- > > They are the same from a computational point of view, where one
utilizes
> the same function to perform both forward and inverse transform.
Stricktly speaking, the FFT and IFFT above are the DFT and IDFT, respectively. Apart from that, the best way to see why the interconnection between the DFT and IDFT is so close, is to write everything in terms of linear algebra. First some definitions: x - Input data signal, N x 1 vector X - DFT of x, Nx 1 vector. x(n) - n'th coefficient of x X(k) - k'th coefficient of X w_k - N x 1 vector W - N x N matrix. I am using matlab's notation where x' means "the conjugated transposed of x". x^T means "x transposed". OK, first find element X(k) in the sepctrum: X(k) = w'_k * x [1] where w_k=[1 exp(j2pi*f_k), exp(j2pi*2f_k),...,exp(j2pi(N-1)*f_k)]^T [2] /sqrt(N) and f_k = k/N, k integer < N. [3] With these definitions, the DFT becomes X = Wx [4] and the IDFT becomes x = W^{-1}X. [5] The interesting point is that W is unitary, i.e. W'W = WW' = I [6] which in turn means that W^{-1} = W' [7.a] W'^{-1} = W [7.b] which is easily verified by investigating the inner product c_pq = w_p'*w_q [8] for various combinations of p and q. More specifiucally, c_pq = 1 p==q [9.a] c_pq = 0 p=/=q [9.b] So the reason why the DFT and IDFT (and hence the FFT and the IFFT algorithms) are so similar, is the transform matrix W being unitary, as seen in equation [6] above. It is obvious from [6] that the choise of signum, +j or -j, in the forward transform has no significance for the maths. HTH, Rune
Sorry. I missed one step / definition, that has been inserted below.
Rune
Rune Allnor wrote:
> bhooshaniyer wrote: > > >I used to think the operations are the same? > > > > > >Thank you. > > > > > > > Here is the equation for both forward and inverse transform: > > (Iam not used to typing math equations in text files, but never the > > less:) > > > > ---------------------------------------------- > > FFT: > > x(F)= summation( x(n)* exp[(-j*2*pi/N)kn] > > --------- > > 0->N-1 > > > > IFFT: > > x(n)= 1/N * summation( x(n)* exp[(j*2*pi/N)kn] > > --------- > > 0->n-1 > > ------------------------------------------------- > > > > They are the same from a computational point of view, where one > utilizes > > the same function to perform both forward and inverse transform. > > Stricktly speaking, the FFT and IFFT above are the DFT and IDFT, > respectively. > > Apart from that, the best way to see why the interconnection between > the DFT and IDFT is so close, is to write everything in terms of
linear
> > algebra. > > First some definitions: > > x - Input data signal, N x 1 vector > X - DFT of x, Nx 1 vector. > x(n) - n'th coefficient of x > X(k) - k'th coefficient of X > w_k - N x 1 vector > W - N x N matrix. > > I am using matlab's notation where x' means "the conjugated > transposed of x". x^T means "x transposed". > > OK, first find element X(k) in the sepctrum: > > X(k) = w'_k * x [1] > > where > > w_k=[1 exp(j2pi*f_k), exp(j2pi*2f_k),...,exp(j2pi(N-1)*f_k)]^T [2] > /sqrt(N) > > and > > f_k = k/N, k integer < N. [3] > > With these definitions, the DFT becomes > > X = Wx [4] > > and the IDFT becomes > > x = W^{-1}X. [5]
where W = [w_0, w_1, ... , w_(N-1)].
> The interesting point is that W is unitary, i.e. > > W'W = WW' = I [6] > > which in turn means that > > W^{-1} = W'
[7.a]
> W'^{-1} = W
[7.b]
> > which is easily verified by investigating the inner product > > c_pq = w_p'*w_q [8] > > for various combinations of p and q. More specifiucally, > > c_pq = 1 p==q
[9.a]
> c_pq = 0 p=/=q
[9.b]
> > So the reason why the DFT and IDFT (and hence the FFT and the IFFT > algorithms) are so similar, is the transform matrix W being unitary, > as seen in equation [6] above. It is obvious from [6] that the choise > of signum, +j or -j, in the forward transform has no significance > for the maths. > > HTH, > > Rune
