> The board comes with VisualDSP++ Ver 4.0. The version we ship includes an > EZ-Kit License. An EZ-Kit License works like a full version with no > restrictions for 90 Days after which it limits you to a maximum program > size of 1/4 the memory. From a VDSP point of view, our cards look like a > EZ-Kit. > > I am very pleased to announce that we just got a license from ADI to use > the EZ-Kit debugger on our dspstak SHARC based boards. This means that > our boards work just like an EZ-Kit. We currently can support the ADSP- > 21261, ADSP-21262 & ADSP-21364. You can use VisualDSP with the same > restrictions that any other EZ-Kit has.Al, And (I suppose), if you already have a full license, you can take full advantage of it, no need to install restricted licenses... Am I right?> The Altera Tools are Quartus II Web Edition and an Altera ByteBlaster.As for the FPGA toolset, I'd like tou to clarify something to me: the Web Edition of Quartus (from Altera) is free, but only functional for 150 days. What happens nect? Someone at comp.arch.fpga mentioned that simply asking for a web edition license works just fine, and that it takes just one day, two at most. Is that true? Would I need to reinstall the tools? Would I need to format the hard drive where it is installed, in order to clean up registry entries? Somewhere (maybe comp.dsp?) I read that for example, If you want to reinstall a Test Drive (which means: evaluation) version of VisualDSP++ on the same computer, you'd had to reformat your hard drive, because any newer installation will recognize that a previous installation expired. Is it the same as with Altera? -- ------------------------------ Jaime Andr�s Aranguren Cardona jaac@sanjaac.com SanJaaC Electronics Soluciones en DSP www.sanjaac.com
Serial Digital Audio filtering B.Eng Project HW help?
Started by ●March 25, 2005
Reply by ●March 30, 20052005-03-30
Reply by ●March 31, 20052005-03-31
Al Clark wrote:> The SHARC has > a fairly large memory. You may find that your programs don't grow large > enough to matter.Very good point. If you wanted to use one of these for prototyping it would probably be a _lot_ less expensive overpopulating the memory by a factor of four than it would be to buy the unencumbered tools. Do I understand correctly that the limitation is to 1/4 of whatever amount of program memory is installed, that you can increase that with this kit, and that that is the only limit placed on the software? Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
The program memory is DSP internal and can't be extended --- however, the internal memory of these processors is gigantic (if you program in assembler). The limit of 1/4 program memory might become a problem is you use C/C++. However, it would be nice of Al the state what 1/4 program memory specifically amounts to for each chip (saving us the time to download and scan all of the datasheets). Regards, Andor
