Hi all I'm looking at some code that is supposed to be estimating (coarsely) the frequency error of a GSM signal (that is basically a bursted GMSK modulated signal). The algorithm that I gleaned out of the code is as follows (in pseudo code with some matlab notations). input is baseband (I,Q) data. I_temp = I.^2 - Q.^2 Q_temp = I.*Q fft_out = fft(I_temp + j*Q_temp); CenterPoint = mod(floor(270833/2/fft_resolution), Nfft) %270833 is the GSM symbol rate Search for peak power +/- 1000 points around CenterPoint of fft_out and record PeakPowerPoint CoarseFreqError = (PeakPowerPoint - CenterPoint)*fft_resolution/2; I'm hoping someone can shed some light on this algorithm and how and why it works. Here is my interpretation of it, The first step seems to be squaring of the complex baseband signal (I+jQ)^2 The constellation of a GMSK signal has 4 points with pi/4 offsets (well, a GSM signal ends up with more points on the constellation due to ISI I guess). By squaring the signal, the constellation folds into 2 points (on a line). Taking an FFT of this results in 2 peaks that correspond to the input signal frequency and since we know where an ideal signal would be located we can then get the delta_frequency from ideal?? I'm not sure I'm making much sense and I can't find any references that come close. BTW, you can consider me to be a beginner when it comes to digital (de)modulation and digital communications in general. I suspect this is a "Oh yeah - here is how it works..." kinda deal for someone like Eric. I'd appreciate any pointers or explanation from anyone. Note - the algorithm then goes on to use this coarse freq estimate, multiply the raw baseband data with a complex exponential that uses this coarse estimate (thereby removing the coarse error), repeats this squaring operation to arrive at a fine freq error estimate. Cheers Bhaskar
freq error estimation of GMSK (GSM) signals
Started by ●March 25, 2005
Reply by ●March 28, 20052005-03-28
BTW, does anyone have a electronic copy of Peter Kootsookos' paper on frequency estimation? All links I could find to his web page don't work anymore - so I'm hoping one of you downloaded a pdf at some point. Cheers Bhaskar "Bhaskar Thiagarajan" <bhaskart@deja.com> wrote in message news:3ajqofF6acgpjU1@individual.net...> Hi all > > I'm looking at some code that is supposed to be estimating (coarsely) the > frequency error of a GSM signal (that is basically a bursted GMSKmodulated> signal). > The algorithm that I gleaned out of the code is as follows (in pseudo code > with some matlab notations). > > input is baseband (I,Q) data. > I_temp = I.^2 - Q.^2 > Q_temp = I.*Q > > fft_out = fft(I_temp + j*Q_temp); > > CenterPoint = mod(floor(270833/2/fft_resolution), Nfft) %270833 is the > GSM symbol rate > > Search for peak power +/- 1000 points around CenterPoint of fft_out and > record PeakPowerPoint > > CoarseFreqError = (PeakPowerPoint - CenterPoint)*fft_resolution/2; > > I'm hoping someone can shed some light on this algorithm and how and whyit> works. > > Here is my interpretation of it, > The first step seems to be squaring of the complex baseband signal(I+jQ)^2> The constellation of a GMSK signal has 4 points with pi/4 offsets (well, a > GSM signal ends up with more points on the constellation due to ISI I > guess). > By squaring the signal, the constellation folds into 2 points (on a line). > Taking an FFT of this results in 2 peaks that correspond to the inputsignal> frequency and since we know where an ideal signal would be located we can > then get the delta_frequency from ideal?? > I'm not sure I'm making much sense and I can't find any references thatcome> close. > BTW, you can consider me to be a beginner when it comes to digital > (de)modulation and digital communications in general. > > I suspect this is a "Oh yeah - here is how it works..." kinda deal for > someone like Eric. I'd appreciate any pointers or explanation from anyone. > > Note - the algorithm then goes on to use this coarse freq estimate,multiply> the raw baseband data with a complex exponential that uses this coarse > estimate (thereby removing the coarse error), repeats this squaring > operation to arrive at a fine freq error estimate. > > Cheers > Bhaskar > > >
Reply by ●March 29, 20052005-03-29
Bhaskar Thiagarajan wrote:> I'm looking at some code that is supposed to be estimating (coarsely)the> frequency error of a GSM signal (that is basically a bursted GMSKmodulated> signal). > The algorithm that I gleaned out of the code is as follows (in pseudocode> with some matlab notations). > > input is baseband (I,Q) data. > I_temp = I.^2 - Q.^2 > Q_temp = I.*Q > > fft_out = fft(I_temp + j*Q_temp); > > CenterPoint = mod(floor(270833/2/fft_resolution), Nfft) %270833 isthe> GSM symbol rate > > Search for peak power +/- 1000 points around CenterPoint of fft_outand> record PeakPowerPoint > > CoarseFreqError = (PeakPowerPoint - CenterPoint)*fft_resolution/2; > > I'm hoping someone can shed some light on this algorithm and how andwhy it> works.I = cos(blah) Q = sin(blah) I.^2 - Q.^2 = cos^2(blah) - sin^2(blah) = cos(2*blah) I.*Q = 0.5*sin(2*blah) Are you sure there is not a 2 in front of I.*Q?> Here is my interpretation of it, > The first step seems to be squaring of the complex baseband signal(I+jQ)^2> The constellation of a GMSK signal has 4 points with pi/4 offsets(well, a> GSM signal ends up with more points on the constellation due to ISI I > guess). > By squaring the signal, the constellation folds into 2 points (on aline).> Taking an FFT of this results in 2 peaks that correspond to the inputsignal> frequency and since we know where an ideal signal would be located wecan> then get the delta_frequency from ideal?? > I'm not sure I'm making much sense and I can't find any referencesthat come> close. > BTW, you can consider me to be a beginner when it comes to digital > (de)modulation and digital communications in general. > > I suspect this is a "Oh yeah - here is how it works..." kinda dealfor> someone like Eric. I'd appreciate any pointers or explanation fromanyone.> > Note - the algorithm then goes on to use this coarse freq estimate,multiply> the raw baseband data with a complex exponential that uses thiscoarse> estimate (thereby removing the coarse error), repeats this squaring > operation to arrive at a fine freq error estimate.OK. It doesn't seem very refined... but if it works, what the hey. Ciao, Peter K.
Bhaskar Thiagarajan wrote:> BTW, does anyone have a electronic copy of Peter Kootsookos' paper on > frequency estimation? All links I could find to his web page don't > work anymore - so I'm hoping one of you downloaded a pdf at some > point.Still looking at the options for hosting. The report you're after is available from UQ's eprint archive: http://eprint.uq.edu.au/archive/00000955/ Ciao, Peter K.
Reply by ●March 31, 20052005-03-31
On Fri, 25 Mar 2005 17:03:37 -0800, "Bhaskar Thiagarajan" <bhaskart@deja.com> wrote:>Hi all > >I'm looking at some code that is supposed to be estimating (coarsely) the >frequency error of a GSM signal (that is basically a bursted GMSK modulated >signal). >The algorithm that I gleaned out of the code is as follows (in pseudo code >with some matlab notations). > >input is baseband (I,Q) data. >I_temp = I.^2 - Q.^2 >Q_temp = I.*Q > >fft_out = fft(I_temp + j*Q_temp); > >CenterPoint = mod(floor(270833/2/fft_resolution), Nfft) %270833 is the >GSM symbol rate > >Search for peak power +/- 1000 points around CenterPoint of fft_out and >record PeakPowerPoint > >CoarseFreqError = (PeakPowerPoint - CenterPoint)*fft_resolution/2; > >I'm hoping someone can shed some light on this algorithm and how and why it >works. > >Here is my interpretation of it, >The first step seems to be squaring of the complex baseband signal (I+jQ)^2 >The constellation of a GMSK signal has 4 points with pi/4 offsets (well, a >GSM signal ends up with more points on the constellation due to ISI I >guess). >By squaring the signal, the constellation folds into 2 points (on a line). >Taking an FFT of this results in 2 peaks that correspond to the input signal >frequency and since we know where an ideal signal would be located we can >then get the delta_frequency from ideal??Yeah, that seems to be basically it, but the squaring results in a decrease in SNR. Are you trying to get initial offset from a burst or track frequency through a signal? I don't recall what the GSM bursts look like but usually the preamble in a bursty system is designed to allow this sort of thing to be estimated well enough.>I'm not sure I'm making much sense and I can't find any references that come >close. >BTW, you can consider me to be a beginner when it comes to digital >(de)modulation and digital communications in general. > >I suspect this is a "Oh yeah - here is how it works..." kinda deal for >someone like Eric. I'd appreciate any pointers or explanation from anyone. > >Note - the algorithm then goes on to use this coarse freq estimate, multiply >the raw baseband data with a complex exponential that uses this coarse >estimate (thereby removing the coarse error), repeats this squaring >operation to arrive at a fine freq error estimate.Is this post processing once the burst has been received? That sounds workable if that's the case, but there are other methods. Frequency tracking methods in comm signals often depend on the type of modulation used. I'm not a GSM expert, but IIRC it uses pi/4-QPSK or something like that...no? In any case, frequency can be estimated from the average phase increment from symbol-to-symbol once the modulation has been detected or removed. Does that make sense? Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Reply by ●April 1, 20052005-04-01
"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message news:424c9467.249355890@news.west.cox.net...> On Fri, 25 Mar 2005 17:03:37 -0800, "Bhaskar Thiagarajan" > <bhaskart@deja.com> wrote: > > >Hi all > > > >I'm looking at some code that is supposed to be estimating (coarsely) the > >frequency error of a GSM signal (that is basically a bursted GMSKmodulated> >signal). > >The algorithm that I gleaned out of the code is as follows (in pseudocode> >with some matlab notations). > > > >input is baseband (I,Q) data. > >I_temp = I.^2 - Q.^2 > >Q_temp = I.*Q > > > >fft_out = fft(I_temp + j*Q_temp); > > > >CenterPoint = mod(floor(270833/2/fft_resolution), Nfft) %270833 is the > >GSM symbol rate > > > >Search for peak power +/- 1000 points around CenterPoint of fft_out and > >record PeakPowerPoint > > > >CoarseFreqError = (PeakPowerPoint - CenterPoint)*fft_resolution/2; > > > >I'm hoping someone can shed some light on this algorithm and how and whyit> >works. > > > >Here is my interpretation of it, > >The first step seems to be squaring of the complex baseband signal(I+jQ)^2> >The constellation of a GMSK signal has 4 points with pi/4 offsets (well,a> >GSM signal ends up with more points on the constellation due to ISI I > >guess). > >By squaring the signal, the constellation folds into 2 points (on aline).> >Taking an FFT of this results in 2 peaks that correspond to the inputsignal> >frequency and since we know where an ideal signal would be located we can > >then get the delta_frequency from ideal?? > > Yeah, that seems to be basically it, but the squaring results in a > decrease in SNR.Hi Eric Is this a 'standard' technique? I've seen ().^4 being used for QPSK signals as well. Is there some material that explains why this works or this is based more on intuition (I can't claim to possess much of this in this new area)? I understand that it decreases SNR but perhaps it isnt' critical to maintain SNR to get a coarse estimate of the frequency error.> Are you trying to get initial offset from a burst or track frequency > through a signal? > > I don't recall what the GSM bursts look like but usually the preamble > in a bursty system is designed to allow this sort of thing to be > estimated well enough.Firstly, I'm looking at someone else's code and I'm trying to understand what it does. I think this section is used to estimate the carrier frequency error of the received signal and use this information to 'lock' to the carrier (basically perform carrier recovery?).> >I'm not sure I'm making much sense and I can't find any references thatcome> >close. > >BTW, you can consider me to be a beginner when it comes to digital > >(de)modulation and digital communications in general. > > > >I suspect this is a "Oh yeah - here is how it works..." kinda deal for > >someone like Eric. I'd appreciate any pointers or explanation fromanyone.> > > >Note - the algorithm then goes on to use this coarse freq estimate,multiply> >the raw baseband data with a complex exponential that uses this coarse > >estimate (thereby removing the coarse error), repeats this squaring > >operation to arrive at a fine freq error estimate. > > Is this post processing once the burst has been received? That sounds > workable if that's the case, but there are other methods.Yes, this is post processing after a burst(s) has been received - typically 1-2 frame's worth of data is acquired. This code is used in a measurement system that tries to generate metrics for the transmitter (it doesn't run on a cell phone). Can you provide a brief introduction to said other methods? I found a reference after much searching that seemed to summarize several techniques - I guess it would be beneficial for me to go over these techniques (even though they seem fairly theoretical to me). http://tinyurl.com/5sx6g> Frequency tracking methods in comm signals often depend on the type of > modulation used. I'm not a GSM expert, but IIRC it uses pi/4-QPSK or > something like that...no? In any case, frequency can be estimated > from the average phase increment from symbol-to-symbol once the > modulation has been detected or removed. Does that make sense?yes - I can understand how the type of modulation used will affect the frequency tracking. GSM uses GMSK (not pi/4-QPSK which is what the old IS-136 used I think). Your last statement of average phase increment from symbol-to-symbol being used for frequency estimation makes partial sense - if the modulation needs to be removed, then don't you need carrier lock first - which means wouldn't you need to estimate this *before* demodulation? Perhaps I need to read up a lot more on my fundamentals before posing such questions...but I find I learn a lot more by asking stupid questions here. I did find a few related comp.dsp threads - I hope to pore over them in the hope of enlightenment... http://tinyurl.com/542by http://tinyurl.com/5kfvg http://tinyurl.com/5auxa Cheers Bhaskar> Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.org
Reply by ●April 2, 20052005-04-02
On Fri, 1 Apr 2005 12:00:21 -0800, "Bhaskar Thiagarajan" <bhaskart@deja.com> wrote:>> Yeah, that seems to be basically it, but the squaring results in a >> decrease in SNR. > >Hi Eric >Is this a 'standard' technique? I've seen ().^4 being used for QPSK signals >as well. Is there some material that explains why this works or this is >based more on intuition (I can't claim to possess much of this in this new >area)? I understand that it decreases SNR but perhaps it isnt' critical to >maintain SNR to get a coarse estimate of the frequency error.Demodulation algorithms are almost never standardized, so I guess it's not a standard technique. It's not unheard of, but I wouldn't call it common, either, because of the noise and spur amplification problems. The problem with the spurs as the order of the nonlinearity increases (say from two to three or four) is that the spurs become as large as the tone that you're trying to find. Once it's to the point where you're losing reliability in being able to detect the signal tone and start getting false detections on spurs it starts to lose utility. FWIW I've always gotten by with other algorithms that work as well or better and are simpler. If the code you're looking at is for testing a modulator then it's not a bad assumption that the SNR will be very high and this may be a non-issue. In a demodulator where noise is a significant impairment you need to worry about the nonlinearity, but for testing a modulator with a super-clean signal it may be a non-issue.>> Are you trying to get initial offset from a burst or track frequency >> through a signal? >> >> I don't recall what the GSM bursts look like but usually the preamble >> in a bursty system is designed to allow this sort of thing to be >> estimated well enough. > >Firstly, I'm looking at someone else's code and I'm trying to understand >what it does. >I think this section is used to estimate the carrier frequency error of the >received signal and use this information to 'lock' to the carrier (basically >perform carrier recovery?).Oh, that may be a little bit different than just frequency estimation, then. Sometimes a sliding block estimate of phase is made (to increase detector SNR) in order to estimate the phase of the signal in the middle of the block in order to demodulate it. Maybe that's what they're doing rather than just frequency estimation. i.e., estimating phase over a block rather than frequency.>> Is this post processing once the burst has been received? That sounds >> workable if that's the case, but there are other methods. > >Yes, this is post processing after a burst(s) has been received - typically >1-2 frame's worth of data is acquired. This code is used in a measurement >system that tries to generate metrics for the transmitter (it doesn't run on >a cell phone). >Can you provide a brief introduction to said other methods? >I found a reference after much searching that seemed to summarize several >techniques - I guess it would be beneficial for me to go over these >techniques (even though they seem fairly theoretical to me). >http://tinyurl.com/5sx6gWow. Apparently it's easier to get a PhD at V. Polytech than I ever thought. :( Again, it depends on what you really want to do. Do you really want frequency or phase? They're related, but which you want may affect how you go about getting them. You're right that you need to remove the modulation to really get frequency using symbol-to-symbol phase increment, and that may require an estimate of the phase if you don't want to use the nonlinearity. You can use a block estimator (there's a famous short paper by Andrew Viterbi and his daughter, called Viterbi-and-Viterbi, that describes a very simple short block estimator), obtain initial phase estimates and use those to not only demodulate but estimate phase increment and therefore frequency. It's not hard to see that you can then go back and remove the frequency estimate and do it again interatively. Or use the nonlinearity, take an FFT, and see what you get. Or run a carrier-phase-tracking loop and see if there's a bias in the output.... ...etc., etc. I think you start to see the dimensionality of the possible solutions. People get really creative with this stuff.>> Frequency tracking methods in comm signals often depend on the type of >> modulation used. I'm not a GSM expert, but IIRC it uses pi/4-QPSK or >> something like that...no? In any case, frequency can be estimated >> from the average phase increment from symbol-to-symbol once the >> modulation has been detected or removed. Does that make sense? > >yes - I can understand how the type of modulation used will affect the >frequency tracking. GSM uses GMSK (not pi/4-QPSK which is what the old >IS-136 used I think). >Your last statement of average phase increment from symbol-to-symbol being >used for frequency estimation makes partial sense - if the modulation needs >to be removed, then don't you need carrier lock first - which means wouldn't >you need to estimate this *before* demodulation?Yeah, sorta, just covered that above.>Perhaps I need to read up a lot more on my fundamentals before posing such >questions...but I find I learn a lot more by asking stupid questions here. > >I did find a few related comp.dsp threads - I hope to pore over them in the >hope of enlightenment... >http://tinyurl.com/542by >http://tinyurl.com/5kfvg >http://tinyurl.com/5auxa > >Cheers >BhaskarI hope that gets you going in the right direction. This is one of those things where after staring at it long enough the lights just come on and it becomes pretty easy after that. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Reply by ●April 4, 20052005-04-04
"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message news:424f306e.420371359@news.west.cox.net...> On Fri, 1 Apr 2005 12:00:21 -0800, "Bhaskar Thiagarajan" > <bhaskart@deja.com> wrote: > > >> Yeah, that seems to be basically it, but the squaring results in a > >> decrease in SNR. > > > >Hi Eric > >Is this a 'standard' technique? I've seen ().^4 being used for QPSKsignals> >as well. Is there some material that explains why this works or this is > >based more on intuition (I can't claim to possess much of this in thisnew> >area)? I understand that it decreases SNR but perhaps it isnt' criticalto> >maintain SNR to get a coarse estimate of the frequency error. > > Demodulation algorithms are almost never standardized, so I guess it's > not a standard technique. It's not unheard of, but I wouldn't call > it common, either, because of the noise and spur amplification > problems.<lotsa technical details snipped>> Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.orgMany thanks for taking the time to respond Eric. Your responses certainly help(ed). The light hasn't turned on yet, but there might be a little flicker once in a while. One thing that your post made clear was that I need to familiarize myself with the digital comms language a lot better if I want to ask better questions and understand answers better. Cheers Bhaskar
