>Use the number of populated subcarriers from the link above, and take >the next largest power-of-two N for the FFT size. e.g., for the 5MHz >BW case there are 301 subcarriers. Use NQ2, populate the 301 >subcarriers around DC, and leave the remaining 211 subcarriers as >zeros for guard band.Dear Eric, All, I have a follow-up question on the FFT used in OFDM. A typical OFDM scheme shows, taking N complex inputs and then multiplying each input with a specific sub-carrier frequency. Since LTE works with either 15 KHz or 7.5 KHz sub-carriers, does the FFT need to be designed specifically for these sub-carrier frequencies? if not, how exactly is the sub-carrier frequency taken care? --------------------------------------- Posted through http://www.DSPRelated.com
LTE, FFT, OFDM
Started by ●November 15, 2015
Reply by ●November 24, 20152015-11-24
>>Use the number of populated subcarriers from the link above, and take >>the next largest power-of-two N for the FFT size. e.g., for the 5MHz >>BW case there are 301 subcarriers. Use NQ2, populate the 301 >>subcarriers around DC, and leave the remaining 211 subcarriers as >>zeros for guard band. > >Dear Eric, All, > >I have a follow-up question on the FFT used in OFDM. >A typical OFDM scheme shows, taking N complex inputs and thenmultiplying>each input with a specific sub-carrier frequency. Since LTE works with >either 15 KHz or 7.5 KHz sub-carriers, does the FFT need to be designed >specifically for these sub-carrier frequencies? if not, how exactly isthe>sub-carrier frequency taken care? >--------------------------------------- >Posted through http://www.DSPRelated.com15KHz comes from 7.68MHz/512 (for lte 5MHz as example) if there is 7.5KHz (and I don't know about this) then either reduce sampling rate by half or increase ifft to 1024 Kaz --------------------------------------- Posted through http://www.DSPRelated.com
On Tue, 24 Nov 2015 07:45:45 -0600, "Sharan123" <99077@DSPRelated> wrote:>>Use the number of populated subcarriers from the link above, and take >>the next largest power-of-two N for the FFT size. e.g., for the 5MHz >>BW case there are 301 subcarriers. Use NQ2, populate the 301 >>subcarriers around DC, and leave the remaining 211 subcarriers as >>zeros for guard band. > >Dear Eric, All, > >I have a follow-up question on the FFT used in OFDM. >A typical OFDM scheme shows, taking N complex inputs and then multiplying >each input with a specific sub-carrier frequency. Since LTE works with >either 15 KHz or 7.5 KHz sub-carriers, does the FFT need to be designed >specifically for these sub-carrier frequencies? if not, how exactly is the >sub-carrier frequency taken care?Not sure what you mean by "multiplying each input with a specific sub-carrier frequency". The FFT does that for you. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Reply by ●November 27, 20152015-11-27
>15KHz comes from 7.68MHz/512 (for lte 5MHz as example) > >if there is 7.5KHz (and I don't know about this) then either reduce >sampling rate by half or increase ifft to 1024Dear Kaz, Probably a basic question. I assume that, specifically referring to LTE/OFDM, when we refer to sub-carrier spacing of 15 KHz, we also mean that sub-carriers themselves are 15 KHz wide. Is this correct? --------------------------------------- Posted through http://www.DSPRelated.com
On Fri, 27 Nov 2015 09:23:12 -0600, "Sharan123" <99077@DSPRelated> wrote:>>15KHz comes from 7.68MHz/512 (for lte 5MHz as example) >> >>if there is 7.5KHz (and I don't know about this) then either reduce >>sampling rate by half or increase ifft to 1024 > >Dear Kaz, > >Probably a basic question. I assume that, specifically referring to >LTE/OFDM, when we refer to sub-carrier spacing of 15 KHz, we also mean >that sub-carriers themselves are 15 KHz wide. Is this correct?They're generated with an FFT, so it is the effective bin spacing in the FFT. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
On Fri, 27 Nov 2015 09:23:12 -0600, "Sharan123" <99077@DSPRelated>> I assume that, specifically referring to LTE/OFDM, when > we refer to sub-carrier spacing of 15 KHz, we also mean that > sub-carriers themselves are 15 KHz wide. Is this correct?Depends what you mean by "width". If each subcarrier is modulated using QAM (as is typical), then the details of this modulation define the width of the subcarrier. (Given that an unmodulated subcarrier has zero bandwidth...) Typically the baud length is slightly longer than the inverse of the subcarrier spacing due to the so-called cyclic prefix. And a mild window (such as a trapezoidal window) is usually applied to each baud. You could define width however you like, but the inverse of the baud length is one possible defintion. The 20 dB bandwidth is another possible definition. Probably (but not certainly) you end up with a value slightly less than the subcarrier spacing. Steve
On Fri, 27 Nov 2015 21:10:11 +0000 (UTC), spope33@speedymail.org (Steve Pope) wrote:>On Fri, 27 Nov 2015 09:23:12 -0600, "Sharan123" <99077@DSPRelated> > >> I assume that, specifically referring to LTE/OFDM, when >> we refer to sub-carrier spacing of 15 KHz, we also mean that >> sub-carriers themselves are 15 KHz wide. Is this correct? > >Depends what you mean by "width". > >If each subcarrier is modulated using QAM (as is typical), then >the details of this modulation define the width of the subcarrier. >(Given that an unmodulated subcarrier has zero bandwidth...) >Typically the baud length is slightly longer than the inverse of >the subcarrier spacing due to the so-called cyclic prefix. >And a mild window (such as a trapezoidal window) is usually applied >to each baud. > >You could define width however you like, but the inverse of the >baud length is one possible defintion. The 20 dB bandwidth is >another possible definition. Probably (but not certainly) you >end up with a value slightly less than the subcarrier spacing. > >SteveIt doesn't matter how the subcarriers are modulated because their values are static for the duration of the symbol (and therefore the DFT length). The output is just the DFT of an array of arbitrary input values, so the output subcarriers have the same characteristics as the bins of any DFT. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Eric Jacobsen <eric.jacobsen@ieee.org> wrote:>On Fri, 27 Nov 2015 21:10:11 +0000 (UTC), spope33@speedymail.org>>On Fri, 27 Nov 2015 09:23:12 -0600, "Sharan123" <99077@DSPRelated>>>> I assume that, specifically referring to LTE/OFDM, when >>> we refer to sub-carrier spacing of 15 KHz, we also mean that >>> sub-carriers themselves are 15 KHz wide. Is this correct?>>Depends what you mean by "width".>>If each subcarrier is modulated using QAM (as is typical), then >>the details of this modulation define the width of the subcarrier. >>(Given that an unmodulated subcarrier has zero bandwidth...) >>Typically the baud length is slightly longer than the inverse of >>the subcarrier spacing due to the so-called cyclic prefix. >>And a mild window (such as a trapezoidal window) is usually applied >>to each baud.>>You could define width however you like, but the inverse of the >>baud length is one possible defintion. The 20 dB bandwidth is >>another possible definition. Probably (but not certainly) you >>end up with a value slightly less than the subcarrier spacing.>It doesn't matter how the subcarriers are modulated because their >values are static for the duration of the symbol (and therefore the >DFT length). The output is just the DFT of an array of arbitrary >input values, so the output subcarriers have the same characteristics >as the bins of any DFT.I agree it doesn't matter, however, the OP asked what is the "width" of the subcarrier. The answer to this is that the "width" (however defined) is the same as that of any carrier modulated in the same manner. Steve
On Sat, 28 Nov 2015 00:12:03 +0000 (UTC), spope33@speedymail.org (Steve Pope) wrote:>Eric Jacobsen <eric.jacobsen@ieee.org> wrote: > >>On Fri, 27 Nov 2015 21:10:11 +0000 (UTC), spope33@speedymail.org > >>>On Fri, 27 Nov 2015 09:23:12 -0600, "Sharan123" <99077@DSPRelated> > >>>> I assume that, specifically referring to LTE/OFDM, when >>>> we refer to sub-carrier spacing of 15 KHz, we also mean that >>>> sub-carriers themselves are 15 KHz wide. Is this correct? > >>>Depends what you mean by "width". > >>>If each subcarrier is modulated using QAM (as is typical), then >>>the details of this modulation define the width of the subcarrier. >>>(Given that an unmodulated subcarrier has zero bandwidth...) >>>Typically the baud length is slightly longer than the inverse of >>>the subcarrier spacing due to the so-called cyclic prefix. >>>And a mild window (such as a trapezoidal window) is usually applied >>>to each baud. > >>>You could define width however you like, but the inverse of the >>>baud length is one possible defintion. The 20 dB bandwidth is >>>another possible definition. Probably (but not certainly) you >>>end up with a value slightly less than the subcarrier spacing. > >>It doesn't matter how the subcarriers are modulated because their >>values are static for the duration of the symbol (and therefore the >>DFT length). The output is just the DFT of an array of arbitrary >>input values, so the output subcarriers have the same characteristics >>as the bins of any DFT. > >I agree it doesn't matter, however, the OP asked what is the "width" >of the subcarrier. The answer to this is that the "width" (however >defined) is the same as that of any carrier modulated in the same >manner.The modulation type doesn't matter. The subcarrier width is determined solely by the FFT size and sample rate, which determines the bin width. Does a subcarrier width shrink if it's a constant (CW)? If it updates at half, or some other fraction, of the OFDM symbol rate? Ans: no. That being said, the subcarrier sinx/x spectrum is consistent with an NRZ signal at a symbol period equal to the FFT length (in time), so from that perspective there is consistency. The realized width is only proportional to the FFT transmit time, though, not including the cyclic prefix, so from that perspective the subcarrier is actually a little wider than an NRZ signal with a symbol rate equal to the OFDM symbol rate. So from that perspective there is not consistency, and the width will not be the same as another carrier modulated in the same manner. The subcarrier width is entirely independent of the subcarrier modulation type. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Reply by ●November 28, 20152015-11-28
>The modulation type doesn't matter. The subcarrier width is >determined solely by the FFT size and sample rate, which determines >the bin width. > >Does a subcarrier width shrink if it's a constant (CW)? If it updates >at half, or some other fraction, of the OFDM symbol rate? Ans: no.Dear Eric, Steve, Thanks for the comments. I have one question, especially pertaining to LTE. In case of OFDM, there are multiple sub-carriers and spacing between consecutive sub-carriers is (say) 15 KHz. Hence isn't bandwidth of each sub-carrier 15 KHz? --------------------------------------- Posted through http://www.DSPRelated.com
