Orthogonol signals
Started by Sharan123 ●November 24, 2015
Hello,
I would like to know definition of orthogonal signals and why they are
significant in communication?
Thanks,
Posted through http://www.DSPRelated.com
Sharan123 <99077@dsprelated> wrote:
> I would like to know definition of orthogonal signals and why they are > significant in communication?
Orthogonal means that if you multiply them, multiply by a weight function (which might be one) and integrate over the appropriate interval, the result is zero. In the case of signals, it makes them easy to separate. -- glen
On Tue, 24 Nov 2015 07:50:30 -0600, Sharan123 wrote:
> Hello, > > I would like to know definition of orthogonal signals and why they are > significant in communication? >
Two signals are orthogonal if you can multiply them together, average the result, and get exactly zero. (This is what Glen said, but I like my wording better). In radio you can use this by generating a bunch of orthogonal signals at the transmitter, then have a bunch of different receivers that each multiply the signal at their antenna by their one desired signal -- the result is that all the other signals are rejected, but the one desired signal is received. The superheterodyne receiver (like a broadcast-band AM or FM receiver) is just one way of achieving this -- digital cell phones have another way that's far more complicated (and uses different signals) but has significant advantages for cell phones. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On Tue, 24 Nov 2015 07:50:30 -0600, "Sharan123" <99077@DSPRelated>
wrote:
>Hello, > >I would like to know definition of orthogonal signals and why they are >significant in communication? > >Thanks,
The upshot of orthogonality is that if you do something (filter, multiply, amplify, attenuate, equalize, rhinoplasty, whatever), a signal that is orthogonal to another signal, only the signal being operated on is affected. Orthogonality makes things functionally independent, and in communications this means that information put in one signal is not disturbed or affected by the other signals, and vice versa. There are many, many types of orthogonality. A simple one is orthogonality in time, where one signal is transmitted during a particular time slot, and a different signal in a different time slot. Frequency orthogonality is also pretty simple, where (usually) one TV station on a particular channel isn't interfered with by signals on other channels. In a much more detailed sense, the I and Q channels of a single signal are orthogonal, and carry independent information. Likewise the subcarriers of an OFDM signal, or CDMA signals spread with codes that are all mutually orthogonal to each other. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
On Tuesday, November 24, 2015 at 8:50:34 AM UTC-5, Sharan123 wrote:
> Hello, > > I would like to know definition of orthogonal signals and why they are > significant in communication? > > Thanks, > --------------------------------------- > Posted through http://www.DSPRelated.com
The definition involves a stupid integral, but you can look that up. The relevance is independence, but you will need to spend a lot of time thinking about that
well, here's my spin: first consider a "signal" as an element of a set of signals we call a "metric space", more specifically a "Hilbert space". a metric space is a mathematical construct where an individual "signal" (in our case a discrete-time or continuous-time function) is like a single "point" in the space and there is a means of measuring the distance between points such that if the two signals are identical, the distance is zero. a "Hilbert space" is a metric space that has this thing called an "inner product" which is very similar to the "dot product" we see in cartesian space. two signals are "orthogonal" if their inner product is zero. just like in cartesian space, two vectors are orthogonal if their dot product is zero. that's my spin. [sorry i have to use Google Groups for a while. it's what happens when i change computers. i also have to use my webmail for email. no mail client. i **hate** "progress".] r b-j
On Tuesday, November 24, 2015 at 5:00:36 PM UTC-5, robert bristow-johnson wrote:
> On Tuesday, November 24, 2015 at 8:50:34 AM UTC-5, Sharan123 wrote: > > Hello, > > > > I would like to know definition of orthogonal signals and why they are > > significant in communication? > > > > Thanks, > > --------------------------------------- > > Posted through http://www.DSPRelated.com > > > well, here's my spin: > > first consider a "signal" as an element of a set of signals we call a "metric space", more specifically a "Hilbert space". > > a metric space is a mathematical construct where an individual "signal" (in our case a discrete-time or continuous-time function) is like a single "point" in the space and there is a means of measuring the distance between points such that if the two signals are identical, the distance is zero. > > a "Hilbert space" is a metric space that has this thing called an "inner product" which is very similar to the "dot product" we see in cartesian space. > > two signals are "orthogonal" if their inner product is zero. just like in cartesian space, two vectors are orthogonal if their dot product is zero. > > that's my spin. > > [sorry i have to use Google Groups for a while. it's what happens when i change computers. i also have to use my webmail for email. no mail client. i **hate** "progress".] > > r b-j
OK I modify my advice.... you need to think about this stuff while on drugs
>> I would like to know definition of orthogonal signals and why they are >> significant in communication?
> Two signals are orthogonal if you can multiply them together, average the > result, and get exactly zero. (This is what Glen said, but I like my > wording better).
In the more general case, you have to allow for a weight function. For signals on wires, that will normally be one. In cylindrical coordinates, Bessel functions are often needed for the radial term, and the weight function is usually r. (That is, the radial coordinate.) There are also functions that are orthogonal in spherical coordinates, such as those used to describe bonding electrons in chemistry. I suspect that spherical and cylindrical coordinates come up in radio transmission, but for signal on wires they shouldn't be needed.
> In radio you can use this by generating a bunch of orthogonal signals at > the transmitter, then have a bunch of different receivers that each > multiply the signal at their antenna by their one desired signal -- the > result is that all the other signals are rejected, but the one desired > signal is received. The superheterodyne receiver (like a broadcast-band > AM or FM receiver) is just one way of achieving this -- digital cell > phones have another way that's far more complicated (and uses different > signals) but has significant advantages for cell phones.
Also for the FM stereo subcarrier and NTSC color subcarriers. -- glen
On Wed, 25 Nov 2015 01:52:53 +0000, glen herrmannsfeldt wrote:
> Tim Wescott <seemywebsite@myfooter.really> wrote: >> On Tue, 24 Nov 2015 07:50:30 -0600, Sharan123 wrote: > >>> I would like to know definition of orthogonal signals and why they are >>> significant in communication? > >> Two signals are orthogonal if you can multiply them together, average >> the result, and get exactly zero. (This is what Glen said, but I like >> my wording better). > > In the more general case, you have to allow for a weight function. For > signals on wires, that will normally be one.
You're thinking orthonormal. Orthogonality just demands zero between signals. Orthonormal demands zero between signals, and a unity result from multiplying a signal by itself. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
(Tim wrote)
>>> Two signals are orthogonal if you can multiply them together, average >>> the result, and get exactly zero. (This is what Glen said, but I like >>> my wording better).
>> In the more general case, you have to allow for a weight function. For >> signals on wires, that will normally be one.
> You're thinking orthonormal. Orthogonality just demands zero between > signals. Orthonormal demands zero between signals, and a unity result > from multiplying a signal by itself.
Well, that, too. But for example, finding the vibrational modes of a circular drum, you need a Bessel function expansion, with orthogonality \integral_0^1 J_m(ar) J_m(br) r dr = 0 a not equal to b. With J_m(a) = J_m(b) = 0. The extra r comes from doing the integral in cylindrical coordinates. (Or radial coordinates, same r.) http://www.hit.ac.il/staff/benzionS/Differential.Equations/Orthogonality_of_Bessel_functions.htm -- glen
