Does anyone know if there is a way to compute an IFFT over a log scale of sampled frequencies? In other words if I have a frequency response that is on a log scale (base 10) what does this mean in the time domain? This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Log Scale FFT ?
Started by ●April 4, 2005
Reply by ●April 4, 20052005-04-04
edwardehopkins wrote:> Does anyone know if there is a way to compute an IFFT over a log scale of > sampled frequencies? In other words if I have a frequency response that > is on a log scale (base 10) what does this mean in the time domain? > > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.comWhat would a logarithmic IFFT be? Log-spaced time ticks? For an FFT (amplitude only), you can do a very fine-grained one, then lump the results into log-spaced chunks. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"edwardehopkins" <edward.e.hopkins@dartmouth.edu> wrote in message news:jqKdnYjDaOiAoszfRVn-3Q@giganews.com...> Does anyone know if there is a way to compute an IFFT over a log scale of > sampled frequencies? In other words if I have a frequency response that > is on a log scale (base 10) what does this mean in the time domain?How strict is the log-scale criteria? Would an approx do? If so do a search on warped fft. Second google result: http://www.acoustics.hut.fi/~aqi/papers/waspaa01.pdf cheers, Lars
