"Jon Harris" <goldentully@hotmail.com> wrote in message news:<2pjm2kFlrvruU1@uni-berlin.de>...> "Stan Pawlukiewicz" <spam@spam.mitre.org> wrote in message > news:ch24rc$4v6$1@newslocal.mitre.org...> > IMHO the last significant paper on window filter synthesis was > > written by Kaiser back in the 50's where he introduced the Kaiser window > > as as an approximation of the zeroth order spherical prolate window. > > That may be true, but the windowing technique can be very useful when you need > to calculate filter coefficients "on the fly". Computationally, it is much > simpler than the optimized methods. So while it might be sub-optimal, I > wouldn't say it is obsolete.Yes, Jon, that's why I'm playing with the windows. The Remez algorithm is available under matlab, but you need matlab to use it, one doesn't learn much DSP by plugging in the numbers, and it's a bit too complicated for me to attempt to implement it myself. I am in the process of learning how to use some new toys of mine, more specifically a C++ compiler under windows. I have used C++ before, but only under UNIX. The main reason is that a couple of other threads recently have made it clear to me that I'm not quite as up-to-date on the trivial details on filter design by windosws, that I might have wanted to... Anyway, I thought that I could use an example program that forces me to learn the basics of the compiler, and that even might be useful afterwards without me getting bogged down with all sorts of numerical subtleties in the mean time. Hence a program for design and analysis of filters designed by windowing. I have the basics up and running (although there are stiil a few flies and other bugs left in the code), so I thought "why not try to include these awkward windows, if it's not too much fuzz". Rune
Window functions
Started by ●August 31, 2004
Reply by ●September 1, 20042004-09-01
Jerry Avins <jya@ieee.org> wrote in message news:<4134a7c1$0$19705$61fed72c@news.rcn.com>...> Stan Pawlukiewicz wrote:> > IMHO the last significant paper on window filter synthesis was written > > by Kaiser back in the 50's where he introduced the Kaiser window as as > > an approximation of the zeroth order spherical prolate window. > > But Stan, windows are used for more than filter design. The prime > example is windowing a set of samples to minimize the artifacts caused > by non-periodicity. The sidelobe width that is readily seen in a filter > also characterizes the way a window in that use trades resolution for > artifact reduction. > > Rune knows how to design filters. It's my guess that he's looking at > windows for their effect on data.That too (I made some comments on my purposes in a reply to Jon Harris). There *is* the slightly embarrasing point that an MSc student took me completely by surprise a few months ago, when he worked with the same data I had used in my PhD thesis. As you know, I work with seismic data. These data are already collected, and all data are available to me when I first sit down to do whatever processing on them. So all those concerns about causality and efficient implementations of filters that are so crucial in on-line applications, don't really apply to my application. This leaves me with a certain degree of freedom others might not have, but more importanntly, it causes me to get sloppy. More specifically, instead of making a low-pass filter with cutoff at 10 Hz, I used to compute the spectrum of the data by FFT, zero out all the coefficients above 10 Hz, and transform back to time domain. This "filter" was only a means for visual inspection of the data, in order to identify certain waves and decide if subsequent analysis steps were possible. In that respect, my crude "filter" worked well. The results of my attempts at filtering are seen in figure 3.7 of my PhD thesis, of which a PDF version is supposed to be available here: http://www.fysel.ntnu.no/~allnor/thesis/thesis.pdf Now, last spring a student worked with the same data and wanted to reproduce the same plots I had made, and he (well with good help from his supervisor, who happened to have written a PhD thesis on filter banks) actually *designed* a filter to my crude spec, and applied it to the data. Suffice it to say that I got very embarrased when I saw the filtered data this student got out of it. There were nothing visible in his plots that I did not see in my own, but his looked much more "crisp" while mine were very crude. So yes, I'd like to make design tools that allow me to design and test filters in my own "outside-matlab" data processing flows, and see what effects they have on the data... Rune
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:<3YudnT5_xdBRbKncRVn-gw@centurytel.net>...> "Rune Allnor" <allnor@tele.ntnu.no> wrote in message > news:f56893ae.0408310548.8ba60b4@posting.google.com... > > Hi all. > > > > I'm playing a bit with window functions in filter design etc, and > > have come across a couple of gruelling expressions. More specifically, > > the Chebychev window [1, eq. 5-17], the Tukey window [2, table 8.1] > > and the Lanczos window, [2, table 8.1]. > > > > I would like to know how one estimates the width of the main lobe > > for these filters, and how one uses the various control parameters. > > Table 8.1 in P&M seems to contain quite a few typos, which does not > > exactly help me understand what's going on. > > Rune, > > I'm going to note that you said "etc." and not worry about what you're going > to do with the windows. You may peek through them for all I care! :-) > > I don't recall a general method or figure or table that compares them - > although fred harris or Al Nuttall may have done so. I have a more > arm-waving method..... > > 1) First you need to define how main lobe width will be measured. -3dB > points? first zero points? etc. Note that they are all pretty much the > same at -3dB and can be quite different at the first zero point.I think the first zero is a good way of doing things. It's fairly easy to find (at least for the "trivial" windows...), and as you say, the numbers can be very different for different windows. In practice, I suspect some sort of compromise would be more useful.> 2) Then, realize that the van der Maas functin provides the lowest > (minimax) sidelobe for a given main lobe width - exept it's not physically > realizable and the end points of the window are infinite as I recall. > Nonetheless, it's a good data point.Ouch! van der who? Never heard of neither the guy or his funcion. Oh well...> 3) Also, realize that the rectangular window "sinc" isn't optimum in > frequency in any particular way - regarding main lobe width or sidelobes. > So this one isn't interesting.No, not as such... (you might want to read my reply to Jerry...) but it's a good refernce for comparision.> 4) The Dolph-Chebyshev window is an approximation to the van der Maas and > is physically realizable. So, presumably, this is the best you can do in > combination of main lobe width vs. side lobe level.I note that Rick uses the Chebychev quite a lot in his book. Which is why I got interested. The problem is how to use it. The maths is there, but I would like to see some cook-book rules of thumb. If one needs a numerical (or manual) optimization routine, I'm not quite that interested. For now.> 5) All of the others have some nice properties of their own but are less > "good" in combination - wider main lobe / higher sidelobes - but perhaps > with rapid sidelobe decay, easy to compute, etc. Lyon's Figure 5-26 gives a > pretty good idea of what's possible in the minimax case. Everything else > will be "worse" in the strict main lobe / sidelobe comparison. Compare > Kaiser beta=4 to gamma=1.5 for Dolph-Chebyshev. The first sidelobes are > nearly the same and the Kaiser main lobe is wider...Exactly. That's the sort of things I'd be interested in checking out. The equations are OK and appear (I haven't attempted to implement them yet) to be easy to implement, given N, gamma, beta and what have you. I try to take the more design-oriented approach, in the sense that one provides a spec like type of window, cut-off frequency for pass band and stop-band, and other relevant parameters where such apply, and compute filter parameters from there. What I would like, is to get from this spec to at least an initial estimate for the filter, where perhaps some details can be adjusted to tweak the performance, but that does not completely depend on an iterative trial'n error approach. Rune
Jerry Avins wrote:> Stan Pawlukiewicz wrote: > > > Jon Harris wrote: > > ... > > >> That may be true, but the windowing technique can be very useful when > >> you need > >> to calculate filter coefficients "on the fly". Computationally, it is > >> much > >> simpler than the optimized methods. So while it might be sub-optimal, I > >> wouldn't say it is obsolete. > >> > >> > > > > Signal Processing with flies should be called FSP ;) > > The dyslexics among us sometimes store data in flies.I once saw a very neat cartoon, which somehow captured the conept of (non-)commutativity very nicely. It contained two displays, which were labeled: "Fly on a banana" and "Banana on a fly" (with appropriate drawings, of course). (She's sleeping now, so I have a moment of spare time :-)
Rune Allnor wrote:> Suffice it to say that I got very embarrased when I saw the filtered > data this student got out of it. There were nothing visible in his > plots that I did not see in my own, but his looked much more "crisp" > while mine were very crude.Sounds to me like: a) this student was standing on the shoulders of giants, and b) Rune is one of the giants. It's great that you see (and take) an opportunity to improve your knowledge, but I don't think you should be embarrassed. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 A pessimist is an optimist with experience
Andor wrote: ...> (She's sleeping now, so I have a moment of spare time :-)Those who didn't understand the reference should go to http://users.erols.com/jyavins/bariska Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jim Thomas wrote:> Rune Allnor wrote: > >> Suffice it to say that I got very embarrased when I saw the filtered >> data this student got out of it. There were nothing visible in his >> plots that I did not see in my own, but his looked much more "crisp" >> while mine were very crude. > > > Sounds to me like: > a) this student was standing on the shoulders of giants, and > b) Rune is one of the giants. > > It's great that you see (and take) an opportunity to improve your > knowledge, but I don't think you should be embarrassed.I don't know about that. I'm always embarrassed about how na�ve I was last week. It won't surprise me if this message embarrasses me tomorrow. Rune, There are a number of free P-M filter design programs available, Scilab's and Octave's among them. The latest one I found is at http://www.winfilter.20m.com/ and I'm sure you know that ScopeFIR from http://www.iowegian.com/ has a free trial version. For off-line use, window performance is really only important for analysis. For filters, there are optimizing methods -- at least equiripple and least squares -- and performance lost by using a window design can be bought back with a few extra taps. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Rune Allnor" <allnor@tele.ntnu.no> wrote in message news:f56893ae.0408312254.750357e4@posting.google.com...> "Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in messagenews:<3YudnT5_xdBRbKncRVn-gw@centurytel.net>...> > "Rune Allnor" <allnor@tele.ntnu.no> wrote in message > > news:f56893ae.0408310548.8ba60b4@posting.google.com... > > > Hi all. > > > > > > I'm playing a bit with window functions in filter design etc, and > > > have come across a couple of gruelling expressions. More specifically, > > > the Chebychev window [1, eq. 5-17], the Tukey window [2, table 8.1] > > > and the Lanczos window, [2, table 8.1]. > > > > > > I would like to know how one estimates the width of the main lobe > > > for these filters, and how one uses the various control parameters. > > > Table 8.1 in P&M seems to contain quite a few typos, which does not > > > exactly help me understand what's going on. > > > > Rune, > > > > I'm going to note that you said "etc." and not worry about what you'regoing> > to do with the windows. You may peek through them for all I care! :-) > > > > I don't recall a general method or figure or table that compares them - > > although fred harris or Al Nuttall may have done so. I have a more > > arm-waving method..... > > > > 1) First you need to define how main lobe width will be measured. -3dB > > points? first zero points? etc. Note that they are all pretty much the > > same at -3dB and can be quite different at the first zero point. > > I think the first zero is a good way of doing things. It's fairly easy > to find (at least for the "trivial" windows...), and as you say, > the numbers can be very different for different windows. In practice, > I suspect some sort of compromise would be more useful. > > > 2) Then, realize that the van der Maas functin provides the lowest > > (minimax) sidelobe for a given main lobe width - exept it's notphysically> > realizable and the end points of the window are infinite as I recall. > > Nonetheless, it's a good data point. > > Ouch! van der who? Never heard of neither the guy or his funcion. > Oh well... > > > 3) Also, realize that the rectangular window "sinc" isn't optimum in > > frequency in any particular way - regarding main lobe width orsidelobes.> > So this one isn't interesting. > > No, not as such... (you might want to read my reply to Jerry...) > but it's a good refernce for comparision. > > > 4) The Dolph-Chebyshev window is an approximation to the van der Maasand> > is physically realizable. So, presumably, this is the best you can doin> > combination of main lobe width vs. side lobe level. > > I note that Rick uses the Chebychev quite a lot in his book. Which is > why I got interested. The problem is how to use it. The maths is there, > but I would like to see some cook-book rules of thumb. If one needs a > numerical (or manual) optimization routine, I'm not quite that interested. > For now. > > > 5) All of the others have some nice properties of their own but are less > > "good" in combination - wider main lobe / higher sidelobes - but perhaps > > with rapid sidelobe decay, easy to compute, etc. Lyon's Figure 5-26gives a> > pretty good idea of what's possible in the minimax case. Everythingelse> > will be "worse" in the strict main lobe / sidelobe comparison. Compare > > Kaiser beta=4 to gamma=1.5 for Dolph-Chebyshev. The first sidelobes are > > nearly the same and the Kaiser main lobe is wider... > > Exactly. That's the sort of things I'd be interested in checking out. > The equations are OK and appear (I haven't attempted to implement them > yet) to be easy to implement, given N, gamma, beta and what have you. > I try to take the more design-oriented approach, in the sense that one > provides a spec like type of window, cut-off frequency for pass band > and stop-band, and other relevant parameters where such apply, and > compute filter parameters from there. > > What I would like, is to get from this spec to at least an initial > estimate for the filter, where perhaps some details can be adjusted to > tweak the performance, but that does not completely depend on an > iterative trial'n error approach.Rune, The windowing approach doesn't lend itself to going directly to filter characteristics. The windowing approach is handy in some situations but imprecise. That's why the Parks-McClellan program is so prevalent. The paper I wrote with Temes and Barcilon dealt with things like rise time, rise time without over/undershoot, etc. Otherwise, I view the minimax design of windows as exactly the same problem as the minimax design of filters. If you can design a window using a numerical method, then you can just as easily design a filter. Maybe looking more carefully at the Kaiser window and its parameters would give you more insight. I often think of the windowing process as a convolution in frequency. Start with a "perfect" lowpass filter with response 1 1 1 1 1 0 0 0 0 0 0 0 1 1 1 1. You know that the time window is a sinc and that's probably not what you want because there will be temporal aliasing. Thus the need for a window. By windowing in time, you will convolve the frequency response with the frequency sinc-like function that has a time "window" of the sort we're discussing here. If you can envision the convolution being computed, you can envision how sidelobes in the window frequency response affect the resulting filter response. - It's just not a very precise picture..... Here's what I glean from this: - the higher the sidelobes of the frequency domain version of the window, the higher the ripples resulting in the convolved filter. - the wider the main lobe of the frequency domain version of the window, the wider the transition regions of the convolved filter. Because the result is a convolution, the window characteristics in frequency are averaged out by the ideal filter function. So, precise window characteristics are softened by that "filtering" process. In other words, maybe it doesn't matter as much as one might think - unless you have very precise filter specifications indeed! I hope this helps.... PS: van der Maas derived a continuous function that starts with a given main lobe width between first zeros and computes the minimax sidelobe level going to +/- infinity. The sidelobes going to infinity are a sinusoid - so the edges of the window have corresponding dirac functions. Because this isn't physically realizable, Dolph and Taylor and others came up with approximations to the van der Maas function that *are* physically realizable. And, was Dolph doing it for discrete arrays? I think so .... Most of the literature is in antenna theory. Fred
"Jerry Avins" <jya@ieee.org> wrote in message news:4135f7f8$0$19704$61fed72c@news.rcn.com...> Rune, > > There are a number of free P-M filter design programs available, > Scilab's and Octave's among them. The latest one I found is at > http://www.winfilter.20m.com/ and I'm sure you know that ScopeFIR from > http://www.iowegian.com/ has a free trial version. >Hello Rune et. al., With a little proding I can make my "c" source code for a P-M algo available. It was one of my earliest "c" programs. But it works quite well. Plus the Remez portion operates in a stand alone fashion. Clay
On 31 Aug 2004 06:48:59 -0700, allnor@tele.ntnu.no (Rune Allnor) wrote:>Hi all. > >I'm playing a bit with window functions in filter design etc, and >have come across a couple of gruelling expressions. More specifically, >the Chebychev window [1, eq. 5-17], the Tukey window [2, table 8.1] >and the Lanczos window, [2, table 8.1]. > >I would like to know how one estimates the width of the main lobe >for these filters, and how one uses the various control parameters. >Table 8.1 in P&M seems to contain quite a few typos, which does not >exactly help me understand what's going on. > >Any comments or opinions are most welcome. > >Rune > >[1] Lyons: Understanding DSP. 2nd ed., > Prentice-Hall, 2004 > >[2] Proakis & Manolakis: Digital Signal Processin - Principles, > Algorithms and Applications. 3rd ed., Prentice-Hall, 1996.Hi Rune, if you're looking for an equation that you can use to estimate mainlobe width, as a function of the Chebyshev gamma control parameter, I don't know of any such equation. Sorry. But speaking of windows, I'm beginning to believe that my equations for the Hanning and Hamming windows are incorrect! My N-point Hamming equation, for example, is: w1(n) = 0.54 - 0.46*cos(2*pi*n/(N-1)) [1] for n = 0,1,2,...,N-1. My Eq. [1] agrees, by the way, with Proakis & Manolakis, Opp & Schafer, MATLAB, etc. If you plot the w1(n) samples in [1] give ya' this nice symmetrical window sequence where the first and last samples are both zero-valued. However, I just discovered (maybe I knew this years ago and forgot) that the Fourier transform of Eq. [1]'s w1(n) does *not* give us the correct Fourier transform of a Hamming window!! The correct N-point discrete Fourier transform (DFT) of an N-point Hamming window is three real non-zero samples. The amplitudes of those samples are 0.23N, 0.54N, and 0.23N. The imaginary part of the correct N-point DFT of an N-point Hamming window is all zeros. The DFT of Eq. [1]'s w1(n) is neither real-only nor does it's freq-domain samples have the correct amplitudes. I now think the correct N-point Hamming equation should be: w2(n) = 0.54 - 0.46*cos(2*pi*n/(N)) [2] for n = 0,1,2,...,N-1. If you plot w2(n) in the time domain it does not "look symmetric". The w2(n) sequence's first and last samples are not equal. But the DFT of Eq. [2]'s w2(n) is real-only and it's freq-domain samples do have the correct amplitudes (0.23N, 0.54N, and 0.23N). I want to call w2(n) "DFT symmetric", because if we circularize (is that a word) it, by repeating it over and over, making it periodic, then it becomes symmetrical. I know I know, the difference between w1(n) and w2(n) becomes smaller and smaller as N becomes larger. Anyway, I'm thinking that there are two different types of symmetry: "linear symmetry" and "DFT symmetry". And that window functions should always be "DFT Symmetric". And maybe I should change the equations in my book with regard to the Hanning and Hamming windows. OK, this my rant of the day. See Ya', [-Rick-]
