Hello everyone. I'm looking for the DSP Texas Instruments and Analog Devices libraries for audio. Can someone help me to find the source files or the list of the procedures available? Thank you! --------------------------------------- Posted through http://www.DSPRelated.com
TEXAS INSTRUMENTS & ANALOG DEVICES AUDIO DSP LIBRARIES
Started by ●December 17, 2015
Reply by ●December 17, 20152015-12-17
rickowens <110888@DSPRelated> wrote:>Hello everyone. I'm looking for the DSP Texas Instruments and Analog >Devices libraries for audio. Can someone help me to find the source files >or the list of the procedures available? >Thank you!I googled up the following, which has many links to zipped-up source code. You-all will probably have to plow through it to determine what-all is there. http://www.ti.com/sc/docs/general/dsp/programs/shareware/c6000.htm There are also other similar links on the TI site. S.
Reply by ●December 18, 20152015-12-18
>rickowens <110888@DSPRelated> wrote: > >>Hello everyone. I'm looking for the DSP Texas Instruments and Analog >>Devices libraries for audio. Can someone help me to find the sourcefiles>>or the list of the procedures available? >>Thank you! > >I googled up the following, which has many links to zipped-up >source code. You-all will probably have to plow through it to >determine what-all is there. > >http://www.ti.com/sc/docs/general/dsp/programs/shareware/c6000.htm > >There are also other similar links on the TI site. > > > >S.Thank you for your answer. Unfortunately when I click on the zips file it tells me "file not found.." I read that there are SPECIFIC TI (and AD) libraries for audio and I want to read all the main procedures (filters, time stretching, ecc.).. maybe there is a list somewhere. hope you can help me! --------------------------------------- Posted through http://www.DSPRelated.com
On Friday, December 18, 2015 at 5:58:27 AM UTC-8, rickowens wrote:> >rickowens <110888@DSPRelated> wrote: > > > >>Hello everyone. I'm looking for the DSP Texas Instruments and Analog > >>Devices libraries for audio. Can someone help me to find the source > files > >>or the list of the procedures available? > >>Thank you! > > > >I googled up the following, which has many links to zipped-up > >source code. You-all will probably have to plow through it to > >determine what-all is there. > > > >http://www.ti.com/sc/docs/general/dsp/programs/shareware/c6000.htm > > > >There are also other similar links on the TI site. > > > > > > > >S. > > Thank you for your answer. Unfortunately when I click on the zips file it > tells me "file not found.." > > I read that there are SPECIFIC TI (and AD) libraries for audio and I want > to read all the main procedures (filters, time stretching, ecc.).. maybe > there is a list somewhere. hope you can help me! > --------------------------------------- > Posted through http://www.DSPRelated.comYou could try and find an old version of AD Visual Audio. If I remember correctly it used RBJ's cookbook code in it and included both C and asm versions. I don't remember if the vendor libraries witch come with VisualDSP++ have their source available.
