Hi, with respect to your community, I'm just starting my journey with signal processing topic. I'm currently working on small voice activity detection (VAD) C++ code snippet. After reading .wav file, passing it trough FFT and feeding with obtained data MFCC algorithm I got my MFCC coefficients. Now I'm little confused. How should I calculate modulation energy in 4Hz frequency (and in bandwith from, for example, 200Hz to 600Hz) from this coefficients? I assume, that I need only two or three first only for that. Do I have to apply bandpass filter centered on 4Hz frequency and then compute the magnitude from filtered amplitudes (as, as far I know, MFCC coefficients stores information about it)? --------------------------------------- Posted through http://www.DSPRelated.com
4Hz modulation energy from MFCC coefficients
Started by ●January 1, 2016
