Hi there. I am currently persuing a Msc Eng degree from the university of Natal,Durban, South Africa. Recently I have been working on a system of which the simulation results are given for the Edge standard. The author of this paper however specifies that the 8psk modulation is infact used for the results. He does however add that the channel is that of a typical urban (TU) channnel with linearized GMSK pulse shaping. It is a rayleigh fading frequency selective channel. The part that is troubling me is how the GMSK pulse shaping used to generate the channel. If you have any code (matlab or c) for GMSK specifically, it would really help. Thank you for your time. Regards Jerry G. Mathew Student Member IEEE Research Centre for Radio Access Technologies University of KwaZulu-Natal, Durban School of Electrical, Electronic and Computer Engineering 5th floor Room: CAD 5 South Africa Contact details e-mail : mathew@ukzn.ac.za Work: +27-31-260-2736 Cell: +27-721251247 This message was sent using the Comp.DSP web interface on www.DSPRelated.com
GMSK pulse shaping
Started by ●April 24, 2005
Reply by ●April 26, 20052005-04-26
"mathew" <mathew@ukzn.ac.za> wrote in message news:s-qdnZjOvef_qfHfRVn-3w@giganews.com...> Hi there. > > I am currently persuing a Msc Eng degree from the university of > Natal,Durban, South Africa. Recently I have been working on a system of > which the simulation results are given for the Edge standard. The author > of this paper however specifies that the 8psk modulation is infact used > for the results. He does however add that the channel is that of a typical > urban (TU) channnel with linearized GMSK pulse shaping. It is a rayleigh > fading frequency selective channel. The part that is troubling me is how > the GMSK pulse shaping used to generate the channel. If you have any code > (matlab or c) for GMSK specifically, it would really help. Thank you for > your time. > > Regards > > Jerry G. Mathew > Student Member IEEE > Research Centre for Radio Access Technologies > University of KwaZulu-Natal, Durban > School of Electrical, Electronic and Computer Engineering > 5th floor > Room: CAD 5 > South Africa > > Contact details > e-mail : mathew@ukzn.ac.za > Work: +27-31-260-2736 > Cell: +27-721251247 > > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.comJerry Good luck with your MSc. I used to work in Durbs, alongside someone else who was doing his MSc through Natal Varsity. Anyway.... How about just writing your own - GMSK (in a GSM sense) can easily be found in the GSM recommendation 05.04, available at www.3gpp.org (for free too!). Only a few equations I'm sure you can massage into your Matlab simulation. Rich
Jerry- The link below would show you the process of Gaussian pulse shaping. http://www.emc.york.ac.uk/reports/linkpcp/appD.pdf I used this document to simulate the GMSK modulation scheme just for better understanding of the concept (CPM modulations in general and GMSK in particular), when I was in school. The shortcut would be to use the gaussfir function in MATLAB I guess. I did not use that as I did not know about it before:) Good luck Regards Nithin
