On 4/24/2016 7:07 AM, radams2000@gmail.com wrote:> The marketing department may have mangled the language, but generating anti-noise through the audio speakers is now common , even in low-end cars. It allows them to remove a lot of heavy sound-dampening materials, so they get slightly better mpg (and it's cheaper, the speakers are already there, you just need to add DSP mips ). > Personally I'm uncomfortable knowing that if I cut my speaker wires, my car will sound like a tin can.How much of this do you know for a fact? So the car stereo is on all the time the engine is running? Or turning off the stereo makes your vehicle noisy? -- Rick
[HUMOR?] "Madison Ave" meets DSP
Started by ●April 22, 2016
Reply by ●April 24, 20162016-04-24
Yes I know this for a fact and have worked on various algorithms for that m= arket.=20 Yes the anti-noise is on all the time. It's mostly effective below 200hz or= so.=20 The most common approach synthesizes sine waves based on tachometer pulses = and adjusts the amplitude and phase of each harmonic to achieve a null. The= re are one or more error microphones in the roof liner to generate an error= signal that drives the additive algorithm.=20 More advanced algorithms use a signal from an accelerometer mounted in the = engine compartment as the reference signal, and use some form of the FXLMS = algorithm to generate the anti-noise.=20 There are many real-world complications, and everyone who naively ventures = into this area is pretty humble after a year or so of trying to achieve goo= d results.=20 Bob
