On Thu, 19 May 2016 10:54:03 -0700, gyansorova wrote:> On Thursday, May 19, 2016 at 4:58:38 PM UTC+12, Tim Wescott wrote: >> On Wed, 18 May 2016 14:44:23 -0700, gyansorova wrote: >> >> > On Thursday, May 19, 2016 at 9:35:10 AM UTC+12, Phil Hobbs wrote: >> >> On 05/18/2016 05:12 PM, Tim Wescott wrote: >> >> > On Wed, 18 May 2016 10:05:16 +1000, Clifford Heath wrote: >> >> > >> >> >> On 18/05/16 01:54, Tim Wescott wrote: >> >> >>> On Tue, 17 May 2016 08:15:42 -0500, John S wrote: >> >> >>>> For your next demo, use an electromagnet to lift a metal ball >> >> >>>> and hold it suspended. Sense the height with a light sensor. >> >> >>>> Use PID to achieve stability. >> >> >>> I've done that. You need a honkin' big electromagnet to make it >> >> >>> work with a plain steel load. >> >> >> >> >> >> Could you use a smaller electromagnet below, partly canceling the >> >> >> pull of a rare-earth magnet from above? >> >> > >> >> > Yes. IMHO, a thingie that's hanging suspended from a point looks >> >> > more impressive than a thingie that's hanging suspended between >> >> > two points. >> >> > >> >> > A thingie that's floating _above_ a point is more impressive yet, >> >> > but if you do that then all of a sudden you have to control it in >> >> > three dimensions instead of one (or perhaps six if you can't make >> >> > it inherently stable in rotation). You can float an aluminum pan >> >> > above an electromagnet and have it be stable, but you can't do the >> >> > same thing with plain old magnets. >> >> > >> >> > >> >> You can, actually, if the object is sufficiently diamagnetic, such >> >> as pyrolytic graphite. I have a little demo on the shelf over my >> >> lab bench that levitates a small sheet of graphite over four NdFeB >> >> magnets arranged in a quadrupole. I posted a video a few years >> >> back. >> >> >> >> When physicists visit, I give them a spiel about room temperature >> >> superconductors and the Meissner effect...the size of the >> >> double-take goes linearly with how much physics they know. ;) >> >> >> >> Cheers >> >> >> >> Phil Hobbs >> >> >> >> -- >> >> Dr Philip C D Hobbs Principal Consultant ElectroOptical Innovations >> >> LLC Optics, Electro-optics, Photonics, Analog Electronics >> >> >> >> 160 North State Road #203 Briarcliff Manor NY 10510 >> >> >> >> hobbs at electrooptical dot net http://electrooptical.net >> > >> > PID is quick and nasty but good to get something working. Proper >> > classical way is by lag-lead controllers and integrators all cascaded >> > and by using a Bode plot, phase margin etc. >> >> Terminology, terminology. >> >> Give me a transfer function of your "lag-lead controllers and >> integrators all cascaded". >> >> It's of the form >> >> a2 * s^2 + a1 * s + a0 >> H(s) = ---------------------- >> s ( s + b ) >> >> right? >> >> So -- that's the transfer function for a PID, with a band-limited >> derivative term. Plain ol' PID. Nuthin' special about it except for >> the fancified language you want to use to describe it. >> >> Same thing. Different words. Words are nothing. Reality is >> everything. PID = "lag-lead controllers and integrators all cascaded", >> only "PID" is shorter. >> >> Now, a PID that's _tuned_ using the seat-of-the-pants method -- that >> can be improved on with the classical Bode plot method using gain & >> phase margins. But it's still a PID -- or a lead-lag controller with >> an integrator, all cascaded, if that's the only way you can retain your >> sanity. But no matter what words you use, the resistors and caps do >> not change: the description does not change the circuit, or the code, >> or the pneumatic cylinders, or whatever you use to implement the >> controller. >> >> -- >> >> Tim Wescott Wescott Design Services http://www.wescottdesign.com >> >> I'm looking for work -- see my website! > > Wrong! It is more than ordinary PID. Of course you can emulate a PID > that way as you point out, but that is just the starting point. Much os > this stuff is not generally not understood by the great unwashed and > does not appear in the text books. Here goes. > > What is an ideal Bode plot? That is the first question to ask > > Second question is what limits the bandwidth of say an > electro-mechanical system? > > An idea Bode plot would be a vertical straight line 9except the close > look system woudl be unstable) > > Limiting factor on bandwidth is structural resonance(s). > > > Hence you need multiple integrators at low frequency to make your Bode > plot as steep as possible. Likewise you can use multiple phase-advances > too but with caution since you disrupt the structural resonance. (phase > advance has high frequency gain of course). > > So a PID is rather limited. The order of a controller could be much > higher depending on just how many integrators you can squeeze in at low > frequency and how many phase advances. If you can't fit an integrator in > then you need a phase-lag which has less phase problems. > > Anyway, this is the art of the control engineer which has been around > since the 70s or so but is kind of lost with todays PID thinking. > Nothing wrong with PID of course if you are happy with the result and > like second best, but you can do so much better. > > There is not enough time or space to explain all of it. I only know it > myself because an old hard disk designer explained it to me thirty years > ago. I and you know the theory already, it's just the art of it all that > is pretty smart. > It's like lego, putting in extra terms here and there and watching your > phase budget - push up bandwidth like a violin string. None of it is in > textbooks because such people don't write text books, they like keeping > it trade secret!Semantics again. With the exception of a double integrator (which isn't always a good idea) you're describing my "PID with decoration" and saying "that's not PID". And just as a note: multiple lead-lags only work to the extent that the high-frequency behavior of the plant is consistent and well-mannered. You can easily design monstrously frustrating lab queen if you don't pay attention to this. Systems that only work at room temperature, or when they're freshly maintained, or when the operator doesn't bang on them too hard are not systems that make the people who sign checks happy. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com I'm looking for work -- see my website!
Stability and Insanity
Started by ●May 17, 2016
Reply by ●May 19, 20162016-05-19
Sometimes in order to get the low-frequency loop gain you need, you are forced to design high-order loops that are conditionally stable. It's always fun to explain to people why the loop will oscillate if the loop gain is reduced, which is against intuition. In these cases talking about the phase margin , as estimated from a Bode plot, is dangerous. I have designed conditionally stable systems where the loop filter is dynamically altered as you approach saturation, so you have a gradual reduction of order. That's fun but should only be done if you have no other choice! Bob
On Friday, May 20, 2016 at 7:49:55 AM UTC+12, Tim Wescott wrote:> On Thu, 19 May 2016 10:54:03 -0700, gyansorova wrote: > > > On Thursday, May 19, 2016 at 4:58:38 PM UTC+12, Tim Wescott wrote: > >> On Wed, 18 May 2016 14:44:23 -0700, gyansorova wrote: > >> > >> > On Thursday, May 19, 2016 at 9:35:10 AM UTC+12, Phil Hobbs wrote: > >> >> On 05/18/2016 05:12 PM, Tim Wescott wrote: > >> >> > On Wed, 18 May 2016 10:05:16 +1000, Clifford Heath wrote: > >> >> > > >> >> >> On 18/05/16 01:54, Tim Wescott wrote: > >> >> >>> On Tue, 17 May 2016 08:15:42 -0500, John S wrote: > >> >> >>>> For your next demo, use an electromagnet to lift a metal ball > >> >> >>>> and hold it suspended. Sense the height with a light sensor. > >> >> >>>> Use PID to achieve stability. > >> >> >>> I've done that. You need a honkin' big electromagnet to make it > >> >> >>> work with a plain steel load. > >> >> >> > >> >> >> Could you use a smaller electromagnet below, partly canceling the > >> >> >> pull of a rare-earth magnet from above? > >> >> > > >> >> > Yes. IMHO, a thingie that's hanging suspended from a point looks > >> >> > more impressive than a thingie that's hanging suspended between > >> >> > two points. > >> >> > > >> >> > A thingie that's floating _above_ a point is more impressive yet, > >> >> > but if you do that then all of a sudden you have to control it in > >> >> > three dimensions instead of one (or perhaps six if you can't make > >> >> > it inherently stable in rotation). You can float an aluminum pan > >> >> > above an electromagnet and have it be stable, but you can't do the > >> >> > same thing with plain old magnets. > >> >> > > >> >> > > >> >> You can, actually, if the object is sufficiently diamagnetic, such > >> >> as pyrolytic graphite. I have a little demo on the shelf over my > >> >> lab bench that levitates a small sheet of graphite over four NdFeB > >> >> magnets arranged in a quadrupole. I posted a video a few years > >> >> back. > >> >> > >> >> When physicists visit, I give them a spiel about room temperature > >> >> superconductors and the Meissner effect...the size of the > >> >> double-take goes linearly with how much physics they know. ;) > >> >> > >> >> Cheers > >> >> > >> >> Phil Hobbs > >> >> > >> >> -- > >> >> Dr Philip C D Hobbs Principal Consultant ElectroOptical Innovations > >> >> LLC Optics, Electro-optics, Photonics, Analog Electronics > >> >> > >> >> 160 North State Road #203 Briarcliff Manor NY 10510 > >> >> > >> >> hobbs at electrooptical dot net http://electrooptical.net > >> > > >> > PID is quick and nasty but good to get something working. Proper > >> > classical way is by lag-lead controllers and integrators all cascaded > >> > and by using a Bode plot, phase margin etc. > >> > >> Terminology, terminology. > >> > >> Give me a transfer function of your "lag-lead controllers and > >> integrators all cascaded". > >> > >> It's of the form > >> > >> a2 * s^2 + a1 * s + a0 > >> H(s) = ---------------------- > >> s ( s + b ) > >> > >> right? > >> > >> So -- that's the transfer function for a PID, with a band-limited > >> derivative term. Plain ol' PID. Nuthin' special about it except for > >> the fancified language you want to use to describe it. > >> > >> Same thing. Different words. Words are nothing. Reality is > >> everything. PID = "lag-lead controllers and integrators all cascaded", > >> only "PID" is shorter. > >> > >> Now, a PID that's _tuned_ using the seat-of-the-pants method -- that > >> can be improved on with the classical Bode plot method using gain & > >> phase margins. But it's still a PID -- or a lead-lag controller with > >> an integrator, all cascaded, if that's the only way you can retain your > >> sanity. But no matter what words you use, the resistors and caps do > >> not change: the description does not change the circuit, or the code, > >> or the pneumatic cylinders, or whatever you use to implement the > >> controller. > >> > >> -- > >> > >> Tim Wescott Wescott Design Services http://www.wescottdesign.com > >> > >> I'm looking for work -- see my website! > > > > Wrong! It is more than ordinary PID. Of course you can emulate a PID > > that way as you point out, but that is just the starting point. Much os > > this stuff is not generally not understood by the great unwashed and > > does not appear in the text books. Here goes. > > > > What is an ideal Bode plot? That is the first question to ask > > > > Second question is what limits the bandwidth of say an > > electro-mechanical system? > > > > An idea Bode plot would be a vertical straight line 9except the close > > look system woudl be unstable) > > > > Limiting factor on bandwidth is structural resonance(s). > > > > > > Hence you need multiple integrators at low frequency to make your Bode > > plot as steep as possible. Likewise you can use multiple phase-advances > > too but with caution since you disrupt the structural resonance. (phase > > advance has high frequency gain of course). > > > > So a PID is rather limited. The order of a controller could be much > > higher depending on just how many integrators you can squeeze in at low > > frequency and how many phase advances. If you can't fit an integrator in > > then you need a phase-lag which has less phase problems. > > > > Anyway, this is the art of the control engineer which has been around > > since the 70s or so but is kind of lost with todays PID thinking. > > Nothing wrong with PID of course if you are happy with the result and > > like second best, but you can do so much better. > > > > There is not enough time or space to explain all of it. I only know it > > myself because an old hard disk designer explained it to me thirty years > > ago. I and you know the theory already, it's just the art of it all that > > is pretty smart. > > It's like lego, putting in extra terms here and there and watching your > > phase budget - push up bandwidth like a violin string. None of it is in > > textbooks because such people don't write text books, they like keeping > > it trade secret! > > Semantics again. With the exception of a double integrator (which isn't > always a good idea) you're describing my "PID with decoration" and saying > "that's not PID". > > And just as a note: multiple lead-lags only work to the extent that the > high-frequency behavior of the plant is consistent and well-mannered. > You can easily design monstrously frustrating lab queen if you don't pay > attention to this. Systems that only work at room temperature, or when > they're freshly maintained, or when the operator doesn't bang on them too > hard are not systems that make the people who sign checks happy. > > -- > > Tim Wescott > Wescott Design Services > http://www.wescottdesign.com > > I'm looking for work -- see my website!Double integrators are always a good idea. The have an enormous gain at low frequencies and hence reject disturbances. What you are talking about is process control of relatively slow processes - which is fair enough. I am talking high speed elec mech drives like a hard disk head. Speed is of the essence and you must maximize the bandwidth.
On Friday, May 20, 2016 at 8:38:01 AM UTC+12, radam...@gmail.com wrote:> Sometimes in order to get the low-frequency loop gain you need, you are forced to design high-order loops that are conditionally stable. It's always fun to explain to people why the loop will oscillate if the loop gain is reduced, which is against intuition. > In these cases talking about the phase margin , as estimated from a Bode plot, is dangerous. > I have designed conditionally stable systems where the loop filter is dynamically altered as you approach saturation, so you have a gradual reduction of order. That's fun but should only be done if you have no other choice! > > BobYou can always phase-advance out any stability problems and trade that off against bandwith.
Tim Wescott wrote:> On Wed, 18 May 2016 21:46:07 +0000, Eric Jacobsen wrote: > >> On Tue, 17 May 2016 10:54:48 -0500, Tim Wescott <tim@seemywebsite.com> >> wrote: >> >>> On Tue, 17 May 2016 08:15:42 -0500, John S wrote: >>> >>>> On 5/17/2016 1:41 AM, Tim Wescott wrote: >>>>> I've just spent over two weeks getting ready to do my next video. It >>>>> was a combination of one of those vast underestimations one >>>>> occasionally makes, combined with falling into a bit of an obsession. >>>>> >>>>> I am, at this point, not only wondering if it was worth it, but >>>>> questioning my sanity in carrying on even when the going went beyond >>>>> tough to just plain crazy. >>>>> >>>>> At any rate, a good video needs a visual aid, and I decided that my >>>>> video needed to demonstrate stability with a pendulum. Moreover, it >>>>> needed a pendulum that could be worked electronically. So, I've >>>>> >>>>> * Disassembled a hard drive for it's head positioner. This took a >>>>> day or two. >>>>> >>>>> * Decided that wasn't good enough and wound my own custom coil (220 >>>>> feet of #40 wire, woo hoo!). This took a false start (18 feet of #34 >>>>> wire) and several days. >>>>> >>>>> * Mounted the coil into a custom pendulum, running on Real Ball >>>>> Bearings. Several more days, and if you touch it wrong the Q goes >>>>> down from about 80 to about 10, then you have to fiddle with it for >>>>> several minutes so the moving parts don't rub. >>>>> >>>>> * Built an oscillator that uses the pendulum as its resonator (this >>>>> is where stability comes in -- is an oscillator stable? How is it >>>>> stable? >>>>> What if it's showing chaotic behavior?). This was astonishingly >>>>> frustrating, and didn't finally work until I carefully modeled the >>>>> pendulum as a resonator AND took the coil inductance into account in >>>>> the circuit. This part too about a week. >>>>> >>>>> And for all that, I now have the time base for an exceptionally >>>>> inaccurate electro-mechanical clock! Check out the picture. That's >>>>> one cycle of the pendulum, running off of a "tick-toc" circuit that >>>>> (A) >>>>> minimizes the load on the pendulum (to give a high loaded Q, >>>>> essential for wringing as much accuracy as possible out of a >>>>> pendulum, never mind that it's made of wood, masking tape, and car >>>>> parts that I picked up off the floor), and (B) has to be started by >>>>> hand (I wanted to demonstrate a hard limit cycle). >>>>> >>>>> http://wescottdesign.com/movies/stability_teaser.gif >>>>> >>>>> More on all of this when I post the video. >>>>> >>>>> >>>> For your next demo, use an electromagnet to lift a metal ball and hold >>>> it suspended. Sense the height with a light sensor. Use PID to achieve >>>> stability. >>>> >>>> I saw an article that did this 30 or so years ago. They used a hollow >>>> steel ball with a map of the earth painted on. Can't remember the >>>> diameter of the ball, but maybe 1". >>> >>> I've done that. You need a honkin' big electromagnet to make it work >>> with a plain steel load. >>> >>> The executive desk-toys with the floating globes use big (30mm dia x >>> 10mm) rare-earth magnets, and float the ball a little bit below the >>> neutral point. I believe that they use hall effect sensors to detect >>> the magnet proximity. >> >> I'm coming in a little late, but last week I was at ISEF (a very large >> international high-school level science fair), and one of the kids was >> levitating a small (about 1/2" dia) steel sphere. He had a hall effect >> sensor underneath and an electromagnet above. He ran into trouble with >> random spin in the ball that would make it difficult to control in one >> dimension. The spin was presumably due to eddy currents in the ball >> since it was solid. He solved that by 3D-printing a cage that would >> stabilize the ball after he glued two toothpicks to it. That stopped >> the spin and the levitation worked pretty well after that. >> >> His innovation was really that he used a self-developed conrol technique >> after he couldn't get PID to work. A couple other judges who were PhD >> candidates in control at ASU pointed out that his new technique was also >> PID, but it was pretty cool that he had derived he whole thing himself >> and got it into a form that worked. >> >> Anyway, I'm guessing that's why hollow spheres are usually used. > > Get that kid into a graduate program! >But maybe not a control theory grad program so much... -- Les Cargill
Reply by ●May 20, 20162016-05-20
On Thu, 19 May 2016 13:37:58 -0700, radams2000 wrote:> Sometimes in order to get the low-frequency loop gain you need, you are > forced to design high-order loops that are conditionally stable. It's > always fun to explain to people why the loop will oscillate if the loop > gain is reduced, which is against intuition. > In these cases talking about the phase margin , as estimated from a Bode > plot, is dangerous.<snip> I dunno -- I just report as many phase and gain margins as there are gain and phase crossings. Seems to work. If someone has trouble but knows Bode plots, I share the Bode plot, and then things are clear. -- Tim Wescott Control systems, embedded software and circuit design I'm looking for work! See my website if you're interested http://www.wescottdesign.com
On Thu, 19 May 2016 15:40:51 -0700, gyansorova wrote:> On Friday, May 20, 2016 at 7:49:55 AM UTC+12, Tim Wescott wrote: >> On Thu, 19 May 2016 10:54:03 -0700, gyansorova wrote: >> >> > On Thursday, May 19, 2016 at 4:58:38 PM UTC+12, Tim Wescott wrote: >> >> On Wed, 18 May 2016 14:44:23 -0700, gyansorova wrote: >> >> >> >> > On Thursday, May 19, 2016 at 9:35:10 AM UTC+12, Phil Hobbs wrote: >> >> >> On 05/18/2016 05:12 PM, Tim Wescott wrote: >> >> >> > On Wed, 18 May 2016 10:05:16 +1000, Clifford Heath wrote: >> >> >> > >> >> >> >> On 18/05/16 01:54, Tim Wescott wrote: >> >> >> >>> On Tue, 17 May 2016 08:15:42 -0500, John S wrote: >> >> >> >>>> For your next demo, use an electromagnet to lift a metal >> >> >> >>>> ball and hold it suspended. Sense the height with a light >> >> >> >>>> sensor. Use PID to achieve stability. >> >> >> >>> I've done that. You need a honkin' big electromagnet to make >> >> >> >>> it work with a plain steel load. >> >> >> >> >> >> >> >> Could you use a smaller electromagnet below, partly canceling >> >> >> >> the pull of a rare-earth magnet from above? >> >> >> > >> >> >> > Yes. IMHO, a thingie that's hanging suspended from a point >> >> >> > looks more impressive than a thingie that's hanging suspended >> >> >> > between two points. >> >> >> > >> >> >> > A thingie that's floating _above_ a point is more impressive >> >> >> > yet, but if you do that then all of a sudden you have to >> >> >> > control it in three dimensions instead of one (or perhaps six >> >> >> > if you can't make it inherently stable in rotation). You can >> >> >> > float an aluminum pan above an electromagnet and have it be >> >> >> > stable, but you can't do the same thing with plain old magnets. >> >> >> > >> >> >> > >> >> >> You can, actually, if the object is sufficiently diamagnetic, >> >> >> such as pyrolytic graphite. I have a little demo on the shelf >> >> >> over my lab bench that levitates a small sheet of graphite over >> >> >> four NdFeB magnets arranged in a quadrupole. I posted a video a >> >> >> few years back. >> >> >> >> >> >> When physicists visit, I give them a spiel about room temperature >> >> >> superconductors and the Meissner effect...the size of the >> >> >> double-take goes linearly with how much physics they know. ;) >> >> >> >> >> >> Cheers >> >> >> >> >> >> Phil Hobbs >> >> >> >> >> >> -- >> >> >> Dr Philip C D Hobbs Principal Consultant ElectroOptical >> >> >> Innovations LLC Optics, Electro-optics, Photonics, Analog >> >> >> Electronics >> >> >> >> >> >> 160 North State Road #203 Briarcliff Manor NY 10510 >> >> >> >> >> >> hobbs at electrooptical dot net http://electrooptical.net >> >> > >> >> > PID is quick and nasty but good to get something working. Proper >> >> > classical way is by lag-lead controllers and integrators all >> >> > cascaded and by using a Bode plot, phase margin etc. >> >> >> >> Terminology, terminology. >> >> >> >> Give me a transfer function of your "lag-lead controllers and >> >> integrators all cascaded". >> >> >> >> It's of the form >> >> >> >> a2 * s^2 + a1 * s + a0 >> >> H(s) = ---------------------- >> >> s ( s + b ) >> >> >> >> right? >> >> >> >> So -- that's the transfer function for a PID, with a band-limited >> >> derivative term. Plain ol' PID. Nuthin' special about it except >> >> for the fancified language you want to use to describe it. >> >> >> >> Same thing. Different words. Words are nothing. Reality is >> >> everything. PID = "lag-lead controllers and integrators all >> >> cascaded", >> >> only "PID" is shorter. >> >> >> >> Now, a PID that's _tuned_ using the seat-of-the-pants method -- that >> >> can be improved on with the classical Bode plot method using gain & >> >> phase margins. But it's still a PID -- or a lead-lag controller >> >> with an integrator, all cascaded, if that's the only way you can >> >> retain your sanity. But no matter what words you use, the resistors >> >> and caps do not change: the description does not change the circuit, >> >> or the code, or the pneumatic cylinders, or whatever you use to >> >> implement the controller. >> >> >> >> -- >> >> >> >> Tim Wescott Wescott Design Services http://www.wescottdesign.com >> >> >> >> I'm looking for work -- see my website! >> > >> > Wrong! It is more than ordinary PID. Of course you can emulate a PID >> > that way as you point out, but that is just the starting point. Much >> > os this stuff is not generally not understood by the great unwashed >> > and does not appear in the text books. Here goes. >> > >> > What is an ideal Bode plot? That is the first question to ask >> > >> > Second question is what limits the bandwidth of say an >> > electro-mechanical system? >> > >> > An idea Bode plot would be a vertical straight line 9except the close >> > look system woudl be unstable) >> > >> > Limiting factor on bandwidth is structural resonance(s). >> > >> > >> > Hence you need multiple integrators at low frequency to make your >> > Bode plot as steep as possible. Likewise you can use multiple >> > phase-advances too but with caution since you disrupt the structural >> > resonance. (phase advance has high frequency gain of course). >> > >> > So a PID is rather limited. The order of a controller could be much >> > higher depending on just how many integrators you can squeeze in at >> > low frequency and how many phase advances. If you can't fit an >> > integrator in then you need a phase-lag which has less phase >> > problems. >> > >> > Anyway, this is the art of the control engineer which has been around >> > since the 70s or so but is kind of lost with todays PID thinking. >> > Nothing wrong with PID of course if you are happy with the result and >> > like second best, but you can do so much better. >> > >> > There is not enough time or space to explain all of it. I only know >> > it myself because an old hard disk designer explained it to me thirty >> > years ago. I and you know the theory already, it's just the art of it >> > all that is pretty smart. >> > It's like lego, putting in extra terms here and there and watching >> > your phase budget - push up bandwidth like a violin string. None of >> > it is in textbooks because such people don't write text books, they >> > like keeping it trade secret! >> >> Semantics again. With the exception of a double integrator (which >> isn't always a good idea) you're describing my "PID with decoration" >> and saying "that's not PID". >> >> And just as a note: multiple lead-lags only work to the extent that the >> high-frequency behavior of the plant is consistent and well-mannered. >> You can easily design monstrously frustrating lab queen if you don't >> pay attention to this. Systems that only work at room temperature, or >> when they're freshly maintained, or when the operator doesn't bang on >> them too hard are not systems that make the people who sign checks >> happy. >> >> -- >> >> Tim Wescott Wescott Design Services http://www.wescottdesign.com >> >> I'm looking for work -- see my website! > > Double integrators are always a good idea. The have an enormous gain at > low frequencies and hence reject disturbances.Whilst, and at the same time, causing enhanced disturbance response somewhere else. See Bode's Sensitivity Integral for details.> What you are talking > about is process control of relatively slow processes - which is fair > enough.I'm so happy for you that you're psychic. But maybe you need to brush up on the mind-reading. Read on...> I am talking high speed elec mech drives like a hard disk head. > Speed is of the essence and you must maximize the bandwidth.I'm talking about high precision electromechanical drives that actually have to work over the full military temperature range, in high vibration environments, while mounted onto a variety of platforms. -- Tim Wescott Control systems, embedded software and circuit design I'm looking for work! See my website if you're interested http://www.wescottdesign.com
On Friday, May 20, 2016 at 5:57:43 PM UTC+12, Tim Wescott wrote:> On Thu, 19 May 2016 15:40:51 -0700, gyansorova wrote: > > > On Friday, May 20, 2016 at 7:49:55 AM UTC+12, Tim Wescott wrote: > >> On Thu, 19 May 2016 10:54:03 -0700, gyansorova wrote: > >> > >> > On Thursday, May 19, 2016 at 4:58:38 PM UTC+12, Tim Wescott wrote: > >> >> On Wed, 18 May 2016 14:44:23 -0700, gyansorova wrote: > >> >> > >> >> > On Thursday, May 19, 2016 at 9:35:10 AM UTC+12, Phil Hobbs wrote: > >> >> >> On 05/18/2016 05:12 PM, Tim Wescott wrote: > >> >> >> > On Wed, 18 May 2016 10:05:16 +1000, Clifford Heath wrote: > >> >> >> > > >> >> >> >> On 18/05/16 01:54, Tim Wescott wrote: > >> >> >> >>> On Tue, 17 May 2016 08:15:42 -0500, John S wrote: > >> >> >> >>>> For your next demo, use an electromagnet to lift a metal > >> >> >> >>>> ball and hold it suspended. Sense the height with a light > >> >> >> >>>> sensor. Use PID to achieve stability. > >> >> >> >>> I've done that. You need a honkin' big electromagnet to make > >> >> >> >>> it work with a plain steel load. > >> >> >> >> > >> >> >> >> Could you use a smaller electromagnet below, partly canceling > >> >> >> >> the pull of a rare-earth magnet from above? > >> >> >> > > >> >> >> > Yes. IMHO, a thingie that's hanging suspended from a point > >> >> >> > looks more impressive than a thingie that's hanging suspended > >> >> >> > between two points. > >> >> >> > > >> >> >> > A thingie that's floating _above_ a point is more impressive > >> >> >> > yet, but if you do that then all of a sudden you have to > >> >> >> > control it in three dimensions instead of one (or perhaps six > >> >> >> > if you can't make it inherently stable in rotation). You can > >> >> >> > float an aluminum pan above an electromagnet and have it be > >> >> >> > stable, but you can't do the same thing with plain old magnets. > >> >> >> > > >> >> >> > > >> >> >> You can, actually, if the object is sufficiently diamagnetic, > >> >> >> such as pyrolytic graphite. I have a little demo on the shelf > >> >> >> over my lab bench that levitates a small sheet of graphite over > >> >> >> four NdFeB magnets arranged in a quadrupole. I posted a video a > >> >> >> few years back. > >> >> >> > >> >> >> When physicists visit, I give them a spiel about room temperature > >> >> >> superconductors and the Meissner effect...the size of the > >> >> >> double-take goes linearly with how much physics they know. ;) > >> >> >> > >> >> >> Cheers > >> >> >> > >> >> >> Phil Hobbs > >> >> >> > >> >> >> -- > >> >> >> Dr Philip C D Hobbs Principal Consultant ElectroOptical > >> >> >> Innovations LLC Optics, Electro-optics, Photonics, Analog > >> >> >> Electronics > >> >> >> > >> >> >> 160 North State Road #203 Briarcliff Manor NY 10510 > >> >> >> > >> >> >> hobbs at electrooptical dot net http://electrooptical.net > >> >> > > >> >> > PID is quick and nasty but good to get something working. Proper > >> >> > classical way is by lag-lead controllers and integrators all > >> >> > cascaded and by using a Bode plot, phase margin etc. > >> >> > >> >> Terminology, terminology. > >> >> > >> >> Give me a transfer function of your "lag-lead controllers and > >> >> integrators all cascaded". > >> >> > >> >> It's of the form > >> >> > >> >> a2 * s^2 + a1 * s + a0 > >> >> H(s) = ---------------------- > >> >> s ( s + b ) > >> >> > >> >> right? > >> >> > >> >> So -- that's the transfer function for a PID, with a band-limited > >> >> derivative term. Plain ol' PID. Nuthin' special about it except > >> >> for the fancified language you want to use to describe it. > >> >> > >> >> Same thing. Different words. Words are nothing. Reality is > >> >> everything. PID = "lag-lead controllers and integrators all > >> >> cascaded", > >> >> only "PID" is shorter. > >> >> > >> >> Now, a PID that's _tuned_ using the seat-of-the-pants method -- that > >> >> can be improved on with the classical Bode plot method using gain & > >> >> phase margins. But it's still a PID -- or a lead-lag controller > >> >> with an integrator, all cascaded, if that's the only way you can > >> >> retain your sanity. But no matter what words you use, the resistors > >> >> and caps do not change: the description does not change the circuit, > >> >> or the code, or the pneumatic cylinders, or whatever you use to > >> >> implement the controller. > >> >> > >> >> -- > >> >> > >> >> Tim Wescott Wescott Design Services http://www.wescottdesign.com > >> >> > >> >> I'm looking for work -- see my website! > >> > > >> > Wrong! It is more than ordinary PID. Of course you can emulate a PID > >> > that way as you point out, but that is just the starting point. Much > >> > os this stuff is not generally not understood by the great unwashed > >> > and does not appear in the text books. Here goes. > >> > > >> > What is an ideal Bode plot? That is the first question to ask > >> > > >> > Second question is what limits the bandwidth of say an > >> > electro-mechanical system? > >> > > >> > An idea Bode plot would be a vertical straight line 9except the close > >> > look system woudl be unstable) > >> > > >> > Limiting factor on bandwidth is structural resonance(s). > >> > > >> > > >> > Hence you need multiple integrators at low frequency to make your > >> > Bode plot as steep as possible. Likewise you can use multiple > >> > phase-advances too but with caution since you disrupt the structural > >> > resonance. (phase advance has high frequency gain of course). > >> > > >> > So a PID is rather limited. The order of a controller could be much > >> > higher depending on just how many integrators you can squeeze in at > >> > low frequency and how many phase advances. If you can't fit an > >> > integrator in then you need a phase-lag which has less phase > >> > problems. > >> > > >> > Anyway, this is the art of the control engineer which has been around > >> > since the 70s or so but is kind of lost with todays PID thinking. > >> > Nothing wrong with PID of course if you are happy with the result and > >> > like second best, but you can do so much better. > >> > > >> > There is not enough time or space to explain all of it. I only know > >> > it myself because an old hard disk designer explained it to me thirty > >> > years ago. I and you know the theory already, it's just the art of it > >> > all that is pretty smart. > >> > It's like lego, putting in extra terms here and there and watching > >> > your phase budget - push up bandwidth like a violin string. None of > >> > it is in textbooks because such people don't write text books, they > >> > like keeping it trade secret! > >> > >> Semantics again. With the exception of a double integrator (which > >> isn't always a good idea) you're describing my "PID with decoration" > >> and saying "that's not PID". > >> > >> And just as a note: multiple lead-lags only work to the extent that the > >> high-frequency behavior of the plant is consistent and well-mannered. > >> You can easily design monstrously frustrating lab queen if you don't > >> pay attention to this. Systems that only work at room temperature, or > >> when they're freshly maintained, or when the operator doesn't bang on > >> them too hard are not systems that make the people who sign checks > >> happy. > >> > >> -- > >> > >> Tim Wescott Wescott Design Services http://www.wescottdesign.com > >> > >> I'm looking for work -- see my website! > > > > Double integrators are always a good idea. The have an enormous gain at > > low frequencies and hence reject disturbances. > > Whilst, and at the same time, causing enhanced disturbance response > somewhere else. See Bode's Sensitivity Integral for details. > > > What you are talking > > about is process control of relatively slow processes - which is fair > > enough. > > I'm so happy for you that you're psychic. But maybe you need to brush up > on the mind-reading. Read on... > > > I am talking high speed elec mech drives like a hard disk head. > > Speed is of the essence and you must maximize the bandwidth. > > I'm talking about high precision electromechanical drives that actually > have to work over the full military temperature range, in high vibration > environments, while mounted onto a variety of platforms. > > -- > Tim Wescott > Control systems, embedded software and circuit design > I'm looking for work! See my website if you're interested > http://www.wescottdesign.comWell you are not doing your best with a PID, that is for sure. I assume speed is not an issue in terms of transient response and it's a don't care much about disturbance rejection. PID is ok for those that know little and want a fast and simple solution - I haven't a problem about that. You don't want to be using it for fast electro-mech drives though. Sure it will work, not the best solution by a long way though. Then when you get to system with more than one input and output then you have to throw away the PID and the lag-lead methods too.
On Fri, 20 May 2016 10:56:33 -0700, gyansorova wrote:> On Friday, May 20, 2016 at 5:57:43 PM UTC+12, Tim Wescott wrote: >> On Thu, 19 May 2016 15:40:51 -0700, gyansorova wrote: >> >> > On Friday, May 20, 2016 at 7:49:55 AM UTC+12, Tim Wescott wrote: >> >> On Thu, 19 May 2016 10:54:03 -0700, gyansorova wrote: >> >> >> >> > On Thursday, May 19, 2016 at 4:58:38 PM UTC+12, Tim Wescott wrote: >> >> >> On Wed, 18 May 2016 14:44:23 -0700, gyansorova wrote: >> >> >> >> >> >> > On Thursday, May 19, 2016 at 9:35:10 AM UTC+12, Phil Hobbs >> >> >> > wrote: >> >> >> >> On 05/18/2016 05:12 PM, Tim Wescott wrote: >> >> >> >> > On Wed, 18 May 2016 10:05:16 +1000, Clifford Heath wrote: >> >> >> >> > >> >> >> >> >> On 18/05/16 01:54, Tim Wescott wrote: >> >> >> >> >>> On Tue, 17 May 2016 08:15:42 -0500, John S wrote: >> >> >> >> >>>> For your next demo, use an electromagnet to lift a metal >> >> >> >> >>>> ball and hold it suspended. Sense the height with a light >> >> >> >> >>>> sensor. Use PID to achieve stability. >> >> >> >> >>> I've done that. You need a honkin' big electromagnet to >> >> >> >> >>> make it work with a plain steel load. >> >> >> >> >> >> >> >> >> >> Could you use a smaller electromagnet below, partly >> >> >> >> >> canceling the pull of a rare-earth magnet from above? >> >> >> >> > >> >> >> >> > Yes. IMHO, a thingie that's hanging suspended from a point >> >> >> >> > looks more impressive than a thingie that's hanging >> >> >> >> > suspended between two points. >> >> >> >> > >> >> >> >> > A thingie that's floating _above_ a point is more impressive >> >> >> >> > yet, but if you do that then all of a sudden you have to >> >> >> >> > control it in three dimensions instead of one (or perhaps >> >> >> >> > six if you can't make it inherently stable in rotation). >> >> >> >> > You can float an aluminum pan above an electromagnet and >> >> >> >> > have it be stable, but you can't do the same thing with >> >> >> >> > plain old magnets. >> >> >> >> > >> >> >> >> > >> >> >> >> You can, actually, if the object is sufficiently diamagnetic, >> >> >> >> such as pyrolytic graphite. I have a little demo on the shelf >> >> >> >> over my lab bench that levitates a small sheet of graphite >> >> >> >> over four NdFeB magnets arranged in a quadrupole. I posted a >> >> >> >> video a few years back. >> >> >> >> >> >> >> >> When physicists visit, I give them a spiel about room >> >> >> >> temperature superconductors and the Meissner effect...the size >> >> >> >> of the double-take goes linearly with how much physics they >> >> >> >> know. ;) >> >> >> >> >> >> >> >> Cheers >> >> >> >> >> >> >> >> Phil Hobbs >> >> >> >> >> >> >> >> -- >> >> >> >> Dr Philip C D Hobbs Principal Consultant ElectroOptical >> >> >> >> Innovations LLC Optics, Electro-optics, Photonics, Analog >> >> >> >> Electronics >> >> >> >> >> >> >> >> 160 North State Road #203 Briarcliff Manor NY 10510 >> >> >> >> >> >> >> >> hobbs at electrooptical dot net http://electrooptical.net >> >> >> > >> >> >> > PID is quick and nasty but good to get something working. >> >> >> > Proper classical way is by lag-lead controllers and integrators >> >> >> > all cascaded and by using a Bode plot, phase margin etc. >> >> >> >> >> >> Terminology, terminology. >> >> >> >> >> >> Give me a transfer function of your "lag-lead controllers and >> >> >> integrators all cascaded". >> >> >> >> >> >> It's of the form >> >> >> >> >> >> a2 * s^2 + a1 * s + a0 >> >> >> H(s) = ---------------------- >> >> >> s ( s + b ) >> >> >> >> >> >> right? >> >> >> >> >> >> So -- that's the transfer function for a PID, with a band-limited >> >> >> derivative term. Plain ol' PID. Nuthin' special about it except >> >> >> for the fancified language you want to use to describe it. >> >> >> >> >> >> Same thing. Different words. Words are nothing. Reality is >> >> >> everything. PID = "lag-lead controllers and integrators all >> >> >> cascaded", >> >> >> only "PID" is shorter. >> >> >> >> >> >> Now, a PID that's _tuned_ using the seat-of-the-pants method -- >> >> >> that can be improved on with the classical Bode plot method using >> >> >> gain & phase margins. But it's still a PID -- or a lead-lag >> >> >> controller with an integrator, all cascaded, if that's the only >> >> >> way you can retain your sanity. But no matter what words you >> >> >> use, the resistors and caps do not change: the description does >> >> >> not change the circuit, >> >> >> or the code, or the pneumatic cylinders, or whatever you use to >> >> >> implement the controller. >> >> >> >> >> >> -- >> >> >> >> >> >> Tim Wescott Wescott Design Services http://www.wescottdesign.com >> >> >> >> >> >> I'm looking for work -- see my website! >> >> > >> >> > Wrong! It is more than ordinary PID. Of course you can emulate a >> >> > PID that way as you point out, but that is just the starting >> >> > point. Much os this stuff is not generally not understood by the >> >> > great unwashed and does not appear in the text books. Here goes. >> >> > >> >> > What is an ideal Bode plot? That is the first question to ask >> >> > >> >> > Second question is what limits the bandwidth of say an >> >> > electro-mechanical system? >> >> > >> >> > An idea Bode plot would be a vertical straight line 9except the >> >> > close look system woudl be unstable) >> >> > >> >> > Limiting factor on bandwidth is structural resonance(s). >> >> > >> >> > >> >> > Hence you need multiple integrators at low frequency to make your >> >> > Bode plot as steep as possible. Likewise you can use multiple >> >> > phase-advances too but with caution since you disrupt the >> >> > structural resonance. (phase advance has high frequency gain of >> >> > course). >> >> > >> >> > So a PID is rather limited. The order of a controller could be >> >> > much higher depending on just how many integrators you can squeeze >> >> > in at low frequency and how many phase advances. If you can't fit >> >> > an integrator in then you need a phase-lag which has less phase >> >> > problems. >> >> > >> >> > Anyway, this is the art of the control engineer which has been >> >> > around since the 70s or so but is kind of lost with todays PID >> >> > thinking. Nothing wrong with PID of course if you are happy with >> >> > the result and like second best, but you can do so much better. >> >> > >> >> > There is not enough time or space to explain all of it. I only >> >> > know it myself because an old hard disk designer explained it to >> >> > me thirty years ago. I and you know the theory already, it's just >> >> > the art of it all that is pretty smart. >> >> > It's like lego, putting in extra terms here and there and watching >> >> > your phase budget - push up bandwidth like a violin string. None >> >> > of it is in textbooks because such people don't write text books, >> >> > they like keeping it trade secret! >> >> >> >> Semantics again. With the exception of a double integrator (which >> >> isn't always a good idea) you're describing my "PID with decoration" >> >> and saying "that's not PID". >> >> >> >> And just as a note: multiple lead-lags only work to the extent that >> >> the high-frequency behavior of the plant is consistent and >> >> well-mannered. You can easily design monstrously frustrating lab >> >> queen if you don't pay attention to this. Systems that only work at >> >> room temperature, or when they're freshly maintained, or when the >> >> operator doesn't bang on them too hard are not systems that make the >> >> people who sign checks happy. >> >> >> >> -- >> >> >> >> Tim Wescott Wescott Design Services http://www.wescottdesign.com >> >> >> >> I'm looking for work -- see my website! >> > >> > Double integrators are always a good idea. The have an enormous gain >> > at low frequencies and hence reject disturbances. >> >> Whilst, and at the same time, causing enhanced disturbance response >> somewhere else. See Bode's Sensitivity Integral for details. >> >> > What you are talking about is process control of relatively slow >> > processes - which is fair enough. >> >> I'm so happy for you that you're psychic. But maybe you need to brush >> up on the mind-reading. Read on... >> >> > I am talking high speed elec mech drives like a hard disk head. >> > Speed is of the essence and you must maximize the bandwidth. >> >> I'm talking about high precision electromechanical drives that actually >> have to work over the full military temperature range, in high >> vibration environments, while mounted onto a variety of platforms. >> >> -- >> Tim Wescott Control systems, embedded software and circuit design I'm >> looking for work! See my website if you're interested >> http://www.wescottdesign.com > > Well you are not doing your best with a PID, that is for sure. I assume > speed is not an issue in terms of transient response and it's a don't > care much about disturbance rejection. PID is ok for those that know > little and want a fast and simple solution - I haven't a problem about > that. You don't want to be using it for fast electro-mech drives though. > Sure it will work, not the best solution by a long way though. Then when > you get to system with more than one input and output then you have to > throw away the PID and the lag-lead methods too.You have no clue what you are talking about. Try actually reading what I've been saying. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com I'm looking for work -- see my website!
On Fri, 20 May 2016 16:29:39 -0500, Tim Wescott wrote:> On Fri, 20 May 2016 10:56:33 -0700, gyansorova wrote: > >> On Friday, May 20, 2016 at 5:57:43 PM UTC+12, Tim Wescott wrote: >>> On Thu, 19 May 2016 15:40:51 -0700, gyansorova wrote: >>> >>> > On Friday, May 20, 2016 at 7:49:55 AM UTC+12, Tim Wescott wrote: >>> >> On Thu, 19 May 2016 10:54:03 -0700, gyansorova wrote: >>> >> >>> >> > On Thursday, May 19, 2016 at 4:58:38 PM UTC+12, Tim Wescott >>> >> > wrote: >>> >> >> On Wed, 18 May 2016 14:44:23 -0700, gyansorova wrote: >>> >> >> >>> >> >> > On Thursday, May 19, 2016 at 9:35:10 AM UTC+12, Phil Hobbs >>> >> >> > wrote: >>> >> >> >> On 05/18/2016 05:12 PM, Tim Wescott wrote: >>> >> >> >> > On Wed, 18 May 2016 10:05:16 +1000, Clifford Heath wrote: >>> >> >> >> > >>> >> >> >> >> On 18/05/16 01:54, Tim Wescott wrote: >>> >> >> >> >>> On Tue, 17 May 2016 08:15:42 -0500, John S wrote: >>> >> >> >> >>>> For your next demo, use an electromagnet to lift a metal >>> >> >> >> >>>> ball and hold it suspended. Sense the height with a >>> >> >> >> >>>> light sensor. Use PID to achieve stability. >>> >> >> >> >>> I've done that. You need a honkin' big electromagnet to >>> >> >> >> >>> make it work with a plain steel load. >>> >> >> >> >> >>> >> >> >> >> Could you use a smaller electromagnet below, partly >>> >> >> >> >> canceling the pull of a rare-earth magnet from above? >>> >> >> >> > >>> >> >> >> > Yes. IMHO, a thingie that's hanging suspended from a point >>> >> >> >> > looks more impressive than a thingie that's hanging >>> >> >> >> > suspended between two points. >>> >> >> >> > >>> >> >> >> > A thingie that's floating _above_ a point is more >>> >> >> >> > impressive yet, but if you do that then all of a sudden you >>> >> >> >> > have to control it in three dimensions instead of one (or >>> >> >> >> > perhaps six if you can't make it inherently stable in >>> >> >> >> > rotation). You can float an aluminum pan above an >>> >> >> >> > electromagnet and have it be stable, but you can't do the >>> >> >> >> > same thing with plain old magnets. >>> >> >> >> > >>> >> >> >> > >>> >> >> >> You can, actually, if the object is sufficiently diamagnetic, >>> >> >> >> such as pyrolytic graphite. I have a little demo on the >>> >> >> >> shelf over my lab bench that levitates a small sheet of >>> >> >> >> graphite over four NdFeB magnets arranged in a quadrupole. I >>> >> >> >> posted a video a few years back. >>> >> >> >> >>> >> >> >> When physicists visit, I give them a spiel about room >>> >> >> >> temperature superconductors and the Meissner effect...the >>> >> >> >> size of the double-take goes linearly with how much physics >>> >> >> >> they know. ;) >>> >> >> >> >>> >> >> >> Cheers >>> >> >> >> >>> >> >> >> Phil Hobbs >>> >> >> >> >>> >> >> >> -- >>> >> >> >> Dr Philip C D Hobbs Principal Consultant ElectroOptical >>> >> >> >> Innovations LLC Optics, Electro-optics, Photonics, Analog >>> >> >> >> Electronics >>> >> >> >> >>> >> >> >> 160 North State Road #203 Briarcliff Manor NY 10510 >>> >> >> >> >>> >> >> >> hobbs at electrooptical dot net http://electrooptical.net >>> >> >> > >>> >> >> > PID is quick and nasty but good to get something working. >>> >> >> > Proper classical way is by lag-lead controllers and >>> >> >> > integrators all cascaded and by using a Bode plot, phase >>> >> >> > margin etc. >>> >> >> >>> >> >> Terminology, terminology. >>> >> >> >>> >> >> Give me a transfer function of your "lag-lead controllers and >>> >> >> integrators all cascaded". >>> >> >> >>> >> >> It's of the form >>> >> >> >>> >> >> a2 * s^2 + a1 * s + a0 >>> >> >> H(s) = ---------------------- >>> >> >> s ( s + b ) >>> >> >> >>> >> >> right? >>> >> >> >>> >> >> So -- that's the transfer function for a PID, with a >>> >> >> band-limited derivative term. Plain ol' PID. Nuthin' special >>> >> >> about it except for the fancified language you want to use to >>> >> >> describe it. >>> >> >> >>> >> >> Same thing. Different words. Words are nothing. Reality is >>> >> >> everything. PID = "lag-lead controllers and integrators all >>> >> >> cascaded", >>> >> >> only "PID" is shorter. >>> >> >> >>> >> >> Now, a PID that's _tuned_ using the seat-of-the-pants method -- >>> >> >> that can be improved on with the classical Bode plot method >>> >> >> using gain & phase margins. But it's still a PID -- or a >>> >> >> lead-lag controller with an integrator, all cascaded, if that's >>> >> >> the only way you can retain your sanity. But no matter what >>> >> >> words you use, the resistors and caps do not change: the >>> >> >> description does not change the circuit, >>> >> >> or the code, or the pneumatic cylinders, or whatever you use to >>> >> >> implement the controller. >>> >> >> >>> >> >> -- >>> >> >> >>> >> >> Tim Wescott Wescott Design Services http://www.wescottdesign.com >>> >> >> >>> >> >> I'm looking for work -- see my website! >>> >> > >>> >> > Wrong! It is more than ordinary PID. Of course you can emulate a >>> >> > PID that way as you point out, but that is just the starting >>> >> > point. Much os this stuff is not generally not understood by the >>> >> > great unwashed and does not appear in the text books. Here goes. >>> >> > >>> >> > What is an ideal Bode plot? That is the first question to ask >>> >> > >>> >> > Second question is what limits the bandwidth of say an >>> >> > electro-mechanical system? >>> >> > >>> >> > An idea Bode plot would be a vertical straight line 9except the >>> >> > close look system woudl be unstable) >>> >> > >>> >> > Limiting factor on bandwidth is structural resonance(s). >>> >> > >>> >> > >>> >> > Hence you need multiple integrators at low frequency to make your >>> >> > Bode plot as steep as possible. Likewise you can use multiple >>> >> > phase-advances too but with caution since you disrupt the >>> >> > structural resonance. (phase advance has high frequency gain of >>> >> > course). >>> >> > >>> >> > So a PID is rather limited. The order of a controller could be >>> >> > much higher depending on just how many integrators you can >>> >> > squeeze in at low frequency and how many phase advances. If you >>> >> > can't fit an integrator in then you need a phase-lag which has >>> >> > less phase problems. >>> >> > >>> >> > Anyway, this is the art of the control engineer which has been >>> >> > around since the 70s or so but is kind of lost with todays PID >>> >> > thinking. Nothing wrong with PID of course if you are happy with >>> >> > the result and like second best, but you can do so much better. >>> >> > >>> >> > There is not enough time or space to explain all of it. I only >>> >> > know it myself because an old hard disk designer explained it to >>> >> > me thirty years ago. I and you know the theory already, it's just >>> >> > the art of it all that is pretty smart. >>> >> > It's like lego, putting in extra terms here and there and >>> >> > watching your phase budget - push up bandwidth like a violin >>> >> > string. None of it is in textbooks because such people don't >>> >> > write text books, they like keeping it trade secret! >>> >> >>> >> Semantics again. With the exception of a double integrator (which >>> >> isn't always a good idea) you're describing my "PID with >>> >> decoration" >>> >> and saying "that's not PID". >>> >> >>> >> And just as a note: multiple lead-lags only work to the extent that >>> >> the high-frequency behavior of the plant is consistent and >>> >> well-mannered. You can easily design monstrously frustrating lab >>> >> queen if you don't pay attention to this. Systems that only work >>> >> at room temperature, or when they're freshly maintained, or when >>> >> the operator doesn't bang on them too hard are not systems that >>> >> make the people who sign checks happy. >>> >> >>> >> -- >>> >> >>> >> Tim Wescott Wescott Design Services http://www.wescottdesign.com >>> >> >>> >> I'm looking for work -- see my website! >>> > >>> > Double integrators are always a good idea. The have an enormous gain >>> > at low frequencies and hence reject disturbances. >>> >>> Whilst, and at the same time, causing enhanced disturbance response >>> somewhere else. See Bode's Sensitivity Integral for details. >>> >>> > What you are talking about is process control of relatively slow >>> > processes - which is fair enough. >>> >>> I'm so happy for you that you're psychic. But maybe you need to brush >>> up on the mind-reading. Read on... >>> >>> > I am talking high speed elec mech drives like a hard disk head. >>> > Speed is of the essence and you must maximize the bandwidth. >>> >>> I'm talking about high precision electromechanical drives that >>> actually have to work over the full military temperature range, in >>> high vibration environments, while mounted onto a variety of >>> platforms. >>> >>> -- >>> Tim Wescott Control systems, embedded software and circuit design I'm >>> looking for work! See my website if you're interested >>> http://www.wescottdesign.com >> >> Well you are not doing your best with a PID, that is for sure. I assume >> speed is not an issue in terms of transient response and it's a don't >> care much about disturbance rejection. PID is ok for those that know >> little and want a fast and simple solution - I haven't a problem about >> that. You don't want to be using it for fast electro-mech drives >> though. >> Sure it will work, not the best solution by a long way though. Then >> when you get to system with more than one input and output then you >> have to throw away the PID and the lag-lead methods too. > > You have no clue what you are talking about. Try actually reading what > I've been saying.Let me rephrase that. You are obviously a good controls engineer, but you have trouble reading what other people write. Perhaps you've never worked outside of the industry you're in, and it has caused ossification of some of your brain cells. Try actually reading what I've been saying. Note the part that hasn't been changed. Reading comprehension often improves if you actually read what you're "reading". -- Tim Wescott Wescott Design Services http://www.wescottdesign.com I'm looking for work -- see my website!
