Hi here, I'm now simulation OFDM Systems in WLAN with Matlab. As to the Rician Fading Channel, 1. Since WLAN enrioment is a static frequency-flat channel, do you think the following clauses is enough in Channel simulation? chan = rayleighchan; signal_out = filter(chan,signal_in); 2. I also see someone using such clauses to descripe the Rician channel. Kmax = ceil(10* ExpDecayTrms*SampFreq); % what is Kmax for? the number of the path? var0 = (1 - exp( - 1/(SampFreq*ExpDecayTrms))) / (1 - exp( -1*((Kmax+1)*SampFreq/ExpDecayTrms))); % why SampFreq/ExpDecayTrms ? k = (0:Kmax); env = var0 * exp( - k/(SampFreq*ExpDecayTrms)); stdDevReOrIm = sqrt(env/2); cir = stdDevReOrIm .* (randn(1, Kmax+1) + j*randn(1, Kmax+1)); signal_out = conv(signal_in, cir); Could you explain?
Rician Channel in OFDM Simulation
Started by ●April 29, 2005
Reply by ●May 31, 20052005-05-31
Hi, I'm not sure about the first qn, but for the 2nd implementation, it's based on Naftali Chayat's channel model and it actually describes an xponentially decaying Rayleigh Fading channel. It has been mentioned here: http://www-mtl.mit.edu/~perrott/Distribution/CppSim_windows/ofdm_tutorial.pdf My knowledge is limited but hope the above helps. ..Nekiy>2. I also see someone using such clauses to descripe the Rician >channel. > >Kmax = ceil(10* ExpDecayTrms*SampFreq); >% what is Kmax for? the number of the path? >var0 = (1 - exp( - 1/(SampFreq*ExpDecayTrms))) / (1 - exp( >-1*((Kmax+1)*SampFreq/ExpDecayTrms))); >% why SampFreq/ExpDecayTrms ? > >k = (0:Kmax); >env = var0 * exp( - k/(SampFreq*ExpDecayTrms)); > >stdDevReOrIm = sqrt(env/2); >cir = stdDevReOrIm .* (randn(1, Kmax+1) + j*randn(1, Kmax+1)); > >signal_out = conv(signal_in, cir); > >Could you explain? > >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Nice reference! Naftali's work (and his minion's, ;)) did provide the basis for the 802.11a channel model (as well as a lot of other features in 802.11a). It just seemed interesting to me that this popped up here... ;) On Tue, 31 May 2005 07:05:08 -0500, "nekiy" <y_i_k_e_n@yahoo.co.uk> wrote:>Hi, > >I'm not sure about the first qn, but for the 2nd implementation, it's >based on Naftali Chayat's channel model and it actually describes an >xponentially decaying Rayleigh Fading channel. > >It has been mentioned here: >http://www-mtl.mit.edu/~perrott/Distribution/CppSim_windows/ofdm_tutorial.pdf > >My knowledge is limited but hope the above helps. > >..Nekiy > >>2. I also see someone using such clauses to descripe the Rician >>channel. >> >>Kmax = ceil(10* ExpDecayTrms*SampFreq); >>% what is Kmax for? the number of the path? >>var0 = (1 - exp( - 1/(SampFreq*ExpDecayTrms))) / (1 - exp( >>-1*((Kmax+1)*SampFreq/ExpDecayTrms))); >>% why SampFreq/ExpDecayTrms ? >> >>k = (0:Kmax); >>env = var0 * exp( - k/(SampFreq*ExpDecayTrms)); >> >>stdDevReOrIm = sqrt(env/2); >>cir = stdDevReOrIm .* (randn(1, Kmax+1) + j*randn(1, Kmax+1)); >> >>signal_out = conv(signal_in, cir); >> >>Could you explain? >> >> > > > > > >This message was sent using the Comp.DSP web interface on >www.DSPRelated.comEric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Reply by ●June 5, 20052005-06-05
