Dear all, What always read about floating and fixed point in DSP. What is that mean? What is the different between floating and fixed points in DSP hardware and DSP software design ? Thank you very much. Best wishes, estdev
Floating and fixed point
Started by ●May 15, 2005
Reply by ●May 15, 20052005-05-15
estdev wrote:> What always read about floating and fixed point in DSP. What is that > mean? > What is the different between floating and fixed points in DSP > hardware and DSP software design ? >Floating point means the sort of arithmetic you get on a standard calculator. Fixed point means, essentially, integer arithmetic scaled to a given range. When using floating point, issues like underflow (numbers becoming too small) or overflow (numbers becoming too large) are less of an issue than when using fixed point. Ciao, Peter K.
Reply by ●May 25, 20052005-05-25
Go through Proakis's book on DSP. Even Oppenheim and Schafer has a good deal on the difference between fixed and floating point math and particularly why fixed point math is commonly used for implementing most DSP algorithms. Then you can advance to some really good tutorials by Randy Yates. Google for 'Fixed point arithmetic and Randy Yates' and it should come up. T. estdev wrote:> Dear all, > > What always read about floating and fixed point in DSP. What is that > mean? > What is the different between floating and fixed points in DSP hardware > and DSP software design ? > > Thank you very much. > > > Best wishes, > estdev
