Hi all, I wanted to use bi-lateral Z-transform, and esp. I wanted to use Inverse Bilateral Z-transform... But Matlab only provides Uni-lateral Z-transform and Inverse Transofrm through its "ztrans" and "iztrans" command pair... How to do Bi-lateral Z-transfrom using Matlab? Thanks a lot!
how to do bi-lateral Z-transform in Matlab?
Started by ●May 18, 2005
Reply by ●May 18, 20052005-05-18
Hi Kiki, -> you can compute the poles using the Residue comman in MATLAB. -> Then compute the absolutely values of poles to find out which ones lie within or outside unit circle. -> inverse transform for each of these can be determined by the unilateral transform function separately (atleast for ones within unit circle). -> For ones outside the unit circle, we use the known z-transform of a left-handed exponential ->Also poles outside unit circle only contribute to the causal part at time zero... Piyush kiki wrote:> Hi all, > > I wanted to use bi-lateral Z-transform, and esp. I wanted to useInverse> Bilateral Z-transform... > > But Matlab only provides Uni-lateral Z-transform and InverseTransofrm> through its "ztrans" and "iztrans" command pair... > > How to do Bi-lateral Z-transfrom using Matlab? > > Thanks a lot!
